I’m doing an install that’s going to be tricky to access the board once it’s built, so I want to get the config right first time. The thing is I’ve never had to use SubBladeReverse before (needed in this case as there’s an accent strip that needs to be wired front-to-back).
Can someone who has used it just cast an eye over my blade array please. It compiles fine - I just want to be sure that it will do what it says on the tin.
Thanks.
{ 0,
// Main Blade:
WS281XBladePtr<132, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>(),
// Crystal Chamber:
WS281XBladePtr<1, bladePin, Color8::GRB, PowerPINS<bladePowerPin1>>(),
// Accent Strips, Short, Front:
SubBladeReverse (0, 3, WS281XBladePtr<4, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3>>()),
// Accent Strips, Long, Rear:
WS281XBladePtr<9, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin4>>(),
// Motor:
SimpleBladePtr<Motor, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(),
CONFIGARRAY(presets) },
