CenterDistF should be fixed now.
Also added an “Argify” button, it doesn’t catch nearly everything yet though.
TrExtend should be fixed now.
ClashImpactF should be fixed now.
Thanks these are working, didn’t test Argify
CenterDistF
TrExtend
ClashImpactF
TrSparkX doesn’t appear to be working.
TransitionEffectL<TrSparkX<White>,EFFECT_BLAST>
How do we Arg-ify? The Step-by-Step please. Highlighting the code in the window and hitting Argify or simply just hitting Argify gave no result. I’d like to try converting this the “easy” way.
StylePtr<
Layers<
RotateColorsX<Variation,Black>,
AudioFlickerL<RotateColorsX<Variation,Rgb<108,108,108>>>,
AudioFlickerL<RotateColorsX<Variation,Rgb<0,0,158>>>,
AlphaL<Stripes<10000,-2000,HumpFlicker<Rgb<0,0,40>,Rgb<20,30,0>,50>,HumpFlicker<Blue,NavajoWhite,50>,HumpFlicker<Rgb<0,0,80>,Rgb<40,60,0>,50>>,SwingSpeed<600>>,
TransitionLoopL<TrConcat<TrDelayX<Scale<Sin<Int<12>>,Int<400>,Int<100>>>,AlphaL<Black,Int<0>>,TrWaveX<BrownNoiseFlicker<White,Rgb<50,50,255>,50>,Scale<Sin<Int<10>>,Int<500>,Int<1500>>,Int<100>,Scale<SlowNoise<Int<1200>>,Int<600>,Int<1200>>,Int<0>>>>,
TransitionEffectL<TrConcat<TrFade<600>,RandomFlicker<ColorChange<TrInstant,Rgb<0,0,100>>,ColorChange<TrInstant,Rgb<0,0,255>>>,TrDelay<30000>>,EFFECT_FORCE>,
TransitionEffectL<TrConcat<TrInstant,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrSmoothFade<600>>,EFFECT_LOCKUP_END>,
LockupTrL<Layers<
AlphaL<AudioFlickerL<White>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<90,890>,Int<25>,Int<8000>>,Int<800>>,Scale<SwingSpeed<100>,Int<8>,Int<100>>>>,
AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<40>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,Red,TrFade<400>>,TrConcat<TrInstant,Red,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveStabL<Red>,
ResponsiveBlastL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_BLAST>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>>,
ResponsiveClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
LockupTrL<AlphaL<Mix<TwistAngle<>,Stripes<1000,3000,Cyan,White,Rgb<0,50,50>,Rgb<75,75,75>>,Stripes<2000,3000,Rgb<75,75,75>,Rgb<75,75,75>,Rgb<100,100,100>,Rgb<60,60,60>>>,SmoothStep<Scale<TwistAngle<>,Int<29000>,Int<26000>>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Mix<TwistAngle<>,Stripes<1000,3000,Red,Black,Rgb<200,0,0>,Rgb<90,0,0>>,Stripes<2000,3000,Rgb<255,200,0>,Rgb<100,75,0>,Rgb<200,160,0>,Rgb<60,40,0>>>,SmoothStep<Scale<TwistAngle<>,Int<29000>,Int<26000>>,Int<5000>>>,TrWipeIn<600>,TrFade<300>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrWipe<300>,TrWipeIn<500>>,
TransitionEffectL<TrConcat<TrDelay<1500>,Black,TrFade<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<Int<0>,Int<6000>>>,TrFade<3000>>,EFFECT_BOOT>,TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<-4000>>>,TrDelay<2000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Int<4000>,Int<4000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>,AlphaL<Black,Scale<IsLessThan<BatteryLevel,Int<11000>>,Int<0>,Int<11000>>>>>(),
I did a little testing on “Argify”, just a note for Edit Mode and my prop, Variation and RgbArg<> do not really work together. We don’t want to mix Variation and RgbArg in styles because it will give really odd results, particularly when used with the ColorList. My prop prevents changing Variation on styles with RgbArg, but if users create styles with RotateColorsX<Variation and RgbArg together they may start getting strange combinations of colors and have no way to fix them without wiping out their presets.ini and getting rid of all edits they’ve made, so I think the Argify needs to completely remove “RotateColorsX<Variation” from styles when you “Argify” them, especially since most styles built for OS4 & 5 use RotateColorsX a lot.
When I’m converting my library styles to OS6 syntax I remove all instances of “RotateColorsX<Variation,” and “>” (the closing bracket for RotateColorsX) myself, so we probably want the editor to do this as well to avoid color issues for users.
There is no MELT_COLOR_ARG, STAB_COLOR_ARG is used for both Stab/Melt, we consolidated during development. It looks like “Argify” is trying to convert EFFECT_MELT and getting hung up.
This is the issue with Shane’s style above not converting and other styles from OS5 library.
Sorry, one more note - “Black” isn’t an editable color in Edit Mode, we may want to consider not letting “Black” get an argument for any style. When users go into Edit Mode if the argument color is Black there is nothing in the preview for Color Editing so the menu prevents going to “Black” so we may want to do the same to prevent users getting confused if they try to use Color Editing on styles with Black as an editable color.
Is “Argify” a way to upgrade old styles for edit mode?
In a “simple” way, yes. It puts the color arguments in to let you do basic color editing.
The more advanced Edit Mode portions you’d have to build from scratch, because they require “planning out” what should be edited in each style, so not sure if it could be automated easily.
But as a starting point, it will help with getting some of the color arguments added to older styles.
From my point of view, to get full editing you’ll need to rebuild styles as this is what I have to do for each library style, because what can be edited varies greatly style-to-style.
Argify isn’t really done yet, which is why it doesn’t work very well on this style.
Basically, it should be just a matter of pasting a style in there, submit, and then click “argify” to add RgbArg<> in most places where it makes sense. But it will probably never be perfect. There may be times where it will add it in the wrong place or times when it will miss something. It all depends on how complicated the styles are. Since OS5-library styles are some of the most complex styles available, they might be some of the hardest for argify to work on as well.
Either way, I will let everybody know when I make progress on making Argify better.
Yes.
It won’t support all the edit mode options, but the idea is to make the styles you already have and love more versatile by letting you edit the colors in edit mode or with the ProffieOS Workbench.
I’ll end up layering this out by hand but since it shows and it’s been mentioned here’s the result.
648 options weren’t good enough, I went for 23k. Hahaha!
Unknown identifier:STYLE_OPTION_ARG
/* copyright Fett263 UnstableBlades (Primary Blade) OS6 Style
https://fett263.s3.us-east-2.amazonaws.com/fett263-proffieOS6-style-library.html#UnstableBlades
OS6.5 v1.0182
This Style Contains 23328 Unique Combinations
Style Options:
Default (0): Random Pulse
1: Unstable Pulse
2: Unstable Unleashed
3: Unstable Erratic
Preon Effect Options: Default (0): Disable, 1: Faulty Ignition (PreOn Color), 2: Faulty Ignition (Base Color), 3: Rey TROS Spark, 4: Pulsing (Base Color), 5: Pilot Light (Base Color)
Ignition Effect Options: Default (0): Standard Ignition, 1: Dual Mode Wipe (Up = Fast), 2: Glitch On
PowerUp Effect Options: Default (0): Disable, 1: Power Burst Forward, 2: Power Burst Emitter, 3: Rey TROS Spark
Retraction Effect Options: Default (0): Standard Retraction, 1: Cycle Down, 2: Dual Mode Wipe In (Down = Fast)
CoolDown Effect Options: Default (0): Disable, 1: Power Flash, 2: Power Burst Reverse
PostOff Effect Options: Default (0): Disable, 1: Emitter Cool Off (Emitter Size), 2: Exit Hyperspace
Lockup Effect: Intensity Lockup V1
Melt Effect: Intensity Melt
Clash Effect: Real Clash V1
Swing Effect Options: Default (0): Disable, 1: Force Boost Aura, 2: Force Slow
Battery Level: Emitter Effect (Green to Red)
StylePtr<Layers<ColorSelect<IntArg<STYLE_OPTION_ARG,0>,TrInstant,StripesX<Int<6000>,Scale<SlowNoise<Int<2000>>,Int<-1600>,Int<-3200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,BrownNoiseFlicker<Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,300>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<Black,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,StripesX<Int<6000>,Scale<SlowNoise<Int<2000>>,Int<-1600>,Int<-3200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,BrownNoiseFlicker<Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,300>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RandomPerLEDFlicker<Black,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,StaticFire<Stripes<2500,-5000,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Black,20>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb<255,25,25>>,70>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,0,5,2,3000,0>,StaticFire<StripesX<Int<3000>,Scale<SlowNoise<Int<2000>>,Int<-1000>,Int<-5000>>,BrownNoiseFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Black,100>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Mix<Int<1285>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RotateColorsX<Variation,Rgb<255,25,25>>,Mix<Int<16384>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,Mix<Int<10280>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,0,5,3,3000,0>>,ColorSelect<IntArg<SWING_OPTION_ARG,0>,TrInstant,AlphaL<Black,Int<0>>,TransitionEffectL<TrConcat<TrExtend<30000,TrFade<300>>,AudioFlickerL<RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,TrFade<300>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrExtend<30000,TrFade<300>>,Pulsing<RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<16384>,Black,RgbArg<SWING_COLOR_ARG,Rgb<255,255,255>>>,3000>,TrFade<300>>,EFFECT_FORCE>>,TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrInstant,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,AlphaL<Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<500>>,TrConcat<TrExtend<200,TrInstant>,AlphaL<Green,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<300>,AlphaL<Blue,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-500>>>,TrFade<500>>>,EFFECT_IGNITION>,TransitionEffectL<TrSelect<IntArg<RETRACTION_COOL_DOWN_ARG,0>,TrInstant,TrConcat<TrExtendX<RetractionTime<0>,TrInstant>,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrFade<1000>>,TrConcat<TrExtendX<RetractionTime<0>,TrInstant>,Stripes<5000,2500,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrExtendX<WavLen<>,TrWipeIn<200>>,AlphaL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<2000>>>,TrWipe<200>>,EFFECT_STAB>,MultiTransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,26000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrExtend<4000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<IgnitionTime<300>>,TrWipeX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,Mult<IgnitionTime<300>,Int<16384>>,IgnitionTime<300>>>,TrConcat<TrExtendX<Mult<IgnitionTime<300>,Int<16384>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>,Mix<SmoothStep<NoisySoundLevel,Int<-1>>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrWipeX<Mult<IgnitionTime<300>,Int<16384>>>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<0>>,TrColorCycleX<RetractionTime<0>>,TrWipeInX<Scale<IsLessThan<BladeAngle<>,Int<16000>>,RetractionTime<0>,Mult<RetractionTime<0>,Int<16384>>>>>,Black>,TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,255,255>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrInstant,AlphaL<RandomPerLEDFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Black>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrExtendX<Int<100>,TrInstant>,AlphaL<Green,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrWipe<300>,AlphaL<DodgerBlue,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrFadeX<Mult<Int<4096>,WavLen<EFFECT_PREON>>>,AlphaL<PulsingL<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Int<800>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrDelayX<Mult<Int<28672>,WavLen<EFFECT_PREON>>>>,TrConcat<TrInstant,AlphaL<BlinkingL<Mix<Int<16384>,White,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Int<300>,Int<500>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-2000>>>,TrBoingX<Mult<WavLen<EFFECT_PREON>,Int<2458>>,3>,AlphaL<BlinkingL<Mix<Int<8192>,White,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,Int<200>,Int<500>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrExtendX<Mult<WavLen<EFFECT_PREON>,Int<29082>>,TrBoingX<Mult<WavLen<EFFECT_PREON>,Int<1638>>,3>>>>,EFFECT_PREON>,TransitionEffectL<TrSelect<IntArg<OFF_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<White,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Orange,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>,AlphaL<Red,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-2000>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<10923>>>>,TrConcat<TrExtendX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8192>>,TrCenterWipeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8192>>>>,Remap<CenterDistF<>,Stripes<2000,-1500,Black,Rgb<100,100,150>>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8192>>>,Remap<CenterDistF<>,Stripes<1000,-500,Black,Rgb<100,100,150>,Black>>,TrFadeX<Mult<Scale<IsLessThan<WavLen<EFFECT_POSTOFF>,Int<200>>,WavLen<EFFECT_POSTOFF>,Int<4000>>,Int<8192>>>>>,EFFECT_RETRACTION>,TransitionEffectL<TrConcat<TrExtend<2000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<IntArg<EMITTER_SIZE_ARG,2000>,Int<-4000>>>,TrFade<300>>,EFFECT_BATTERY_LEVEL>>>(),
I just want to say thanks to @profezzorn for the effort to update the Style Editor.
It is such a pleasure to drop a full blown style in there, hit submit and it just takes it without editing WavLen, EffectSequence, PowerSave, EFFECT_BATTERY_LEVEL etc… to substituted things it would like.
Just… Thanks!
Oh, and just bumping this:
Percentage is fixed now.
Awesome, thanks!
Would it be too much to ask for a TransitionEffect button/template?
Not the Layer version, regular ol’:
TransitionEffect<COLOR, EFFECT_COLOR, TRANSITION1, TRANSITION2, EFFECT>
While on the subject of the Layer version, I’m curious about the template in Style editor compared to the file’s usage description.
Editor gives the default example of:
TransitionEffectL<TrConcat<TrWipe<50>,White,TrWipe<50>>,EFFECT_BLAST>
so that would be Usage:
TransitionEffectL<TRANSITION1,EFFECT>
But the file’s description says it needs to be:
TransitionEffectL<EFFECT_COLOR, TRANSITION1, TRANSITION2, EFFECT>
confused.
Not sure why, but this style doesn’t work, no errors, it just doesn’t run.
TrCenterWipeX<IgnitionTime<>,Scale<TwistAngle<1>,Int<6000>,Int<27000>>>
using as ignition transition in this type of style.
StylePtr<Layers<RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>>,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>>>,RgbArg<BASE_COLOR_ARG,Rgb<30,60,200>>>,InOutTrL<TrCenterWipeX<IgnitionTime<300>,Scale<TwistAngle<1>,Int<6000>,Int<27000>>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
if you expand IgnitionTime, it’s coming in as
Scale<IsLessThan<IntArg<5,300>,Int<1>>,IntArg<5,300>,WavLen<12>>
Should it be?:
Scale<IsLessThan<IntArg<IGNITION_TIME_ARG,300>,Int<1>>,IntArg<IGNITION_TIME_ARG,300>,WavLen<EFFECT_IGNITION>>
Yes, so the editor is changing the arguments incorrectly.
