Asking for someone.
I tried to search on TRA because I remember there was this issue a few times before, but no luck finding the discussions.
Do we remember what the cause of/fix for audio sounding like very low sample rate was?
An OS update?
If it’s the problem I think it is, then this is caused by using an old version of the OS (4.8 or older I think) with a new version of the plugin. There was a piece non-portable coding in there that the new compiler didn’t like. There are three possible ways to work around it:
- upgrade your OS to a newer version
- downgrade your plugin to an older version
- Apply the fix manually:
