for OS6, a new feature has come out about font effect volume adjustment:
# Set the volume for each effect individually, in percent.
# 50 makes it half as loud. 200 makes it twice as loud.
# Maximum allowed value is currently 255. The default is 100.
# EFFECTNAME can be "clash", “preon”, “out”, “pstoff”, etc.
# ProffieOS.SFX.EFFECTNAME.volume=100
So im assuming a typical entry in a config.ini font file would be:
ProffieOS.SFX.CLASH.volume=100
ProffieOS.SFX.BLST.volume=100
ProffieOS.SFX.LOCK.volume=100
ProffieOS.SFX.ENDLOCK.volume=100
ProffieOS.SFX.IN.volume=100
ProffieOS.SFX.OUT.volume=100
etc
etc
But my question is, what happens when you have an entry for
ProffieOS.SFX.PREON.volume=100
…but dont have any preon sound/wav files in your font folder? Does this entry in the font config.ini simply get ignored? or does it create some sort of error?
Also, what happens if you created an entry for:
ProffieOS.SFX.SWNG.volume=100
Seeing as accent swings volumes are controlled in other various parameters (thresholds), does this volume adjustment for SWNG get ignored?
