The blade isn’t being recognized and isn’t illuminating, nor making any change blade sounds. Can you help me understand why?
What do you mean by recognised? Are you using blade detect and what version are you running ProffieOS.
Thanks for the quick response. I actually figured out it was the Blade Detect Pin. I had not set it properly, and was using an outdated config’s pin.
MTFBWY
Was that pin17 vs pin3
I used pin1. Interestingly enough, that lights up the in-hilt LEDs when no blade is inserted.
