Setting up presets
Hi All,
After many months of designing custom chassis, soldering and replacing a burnt board, I’ve finally got everything working. Now it is time to setup the presents. Started with the default ones. They were mostly ok, but I’m not happy with the sounds. Some of the presets have a very nice roar, but the others don’t. All I want is just couple of nice presets - while, green, red and purple. Minor variance in style is ok. Would you mind sharing your presets?
Also, all presets turn on using simple “slide up/down” motion. I’ve seen some sabers do it using “blocks” that slide in and out. Not sure how that is called…
Thanks!
Here is my full config:
#define VOLUME 2200
#define CLASH_THRESHOLD_G 1.0
/* BEGIN DISPLAY */
#define ENABLE_SSD1306
/* END DISPLAY */
/* BEGIN BLUETOOTH */
#define ENABLE_SERIAL
#define BLE_PASSWORD "test"
#define BLE_NAME "Ny Saber"
#define BLE_SHORTNAME "Saber"
/* END BLUETOOTH */
/* BEGIN EDIT-MODE */
/* END EDIT-MODE */
#define FETT263_MULTI_PHASE
#define FETT263_TWIST_ON
#endif /* CONFIG_TOP */
#endif /* CONFIG_PROP */
   { "SmthJedi;common", "tracks/uranus.wav",
   { "TeensySF;common", "tracks/mercury.wav",
   { "SmthFuzz;common", "tracks/uranus.wav",
   { "SmthGrey;common", "tracks/venus.wav",
   { "TthCrstl;common", "tracks/mars.wav",
   { "TeensySF;common", "tracks/venus.wav",
   { "SmthJedi;common", "tracks/mars.wav",
   { "SmthGrey;common", "tracks/mercury.wav",
    StyleFirePtr<RED, YELLOW>(), "fire"},
   { "RgueCmdr;common", "tracks/venus.wav",
    StyleFirePtr<BLUE, CYAN>(), "blue fire"},
    &style_pov, "POV"},
   { "SmthFuzz;common", "tracks/mars.wav",
   { "RgueCmdr;common", "tracks/mercury.wav",
   { "TthCrstl;common", "tracks/uranus.wav",
 { 0, WS281XBladePtr<122 + 16, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), CONFIGARRAY(presets) },
#endif /* CONFIG_PRESETS */
#endif /* CONFIG_BUTTONS */
Go check out the Fett263 style library:
I also recommend buying a sound font or two.
I quite like Kyberphonic fonts, in particular the “Hero’s Pack” is very versatile.
I also have an OS7 library with support for new OS7 features.
https://www.fett263.com/fett263-proffieOS7-style-library.html
Thanks guys, will give it a try next few days
