Searching for a full serial monitor commands list.? I read somewhere that typing ‘help’ command would return a list but it doesn’t for me.
Also, is there a way to turn the amplifier on from the serial monitor or some other way? Serial monitor says that amplifier is off and I’m not getting sound from my saber(proffie 2.2).
Amplifier gets turned on automatically when needed, so you shouldn’t have to worry about that. The “help” command is not available if you have DISABLE_DIAGNOSTIC_COMMANDS in your config file, and it doesn’t provide a full list anyways.
There is an (incomplete) list of serial monitor commands here: Serial Monitor Commands · profezzorn/ProffieOS Wiki · GitHub
Thanks profezzorn. I must have issues with my fonts or SD card.
Does the “beep” command work?
Screenshots are not allowed when cut-n-paste will work.
Please read the rules.
“beep” is also disabled by DISABLE_DIAGNOSTIC_COMMANDS
sorry about that.
