Randomize Quote Player Define Issue
I added the additional define, FETT263_RANDOMIZE_QUOTE_PLAYER but I’m still getting the quotes sequentially.
Is there something else I need to do to make this define work as designed?
I have force files and quote files in their respective folders and I can toggle force/quotes by pointing the blade down with a long press of the power button. So the quote player is working fine. I’m running OS 6.7 with 2 button setup.
There’s no such define in OS6. All valid defines are listed at the top of the prop file or on this page. If you want quotes to be random then just set them up as force.wav instead.
Understood. Thanks for clearing that up.
