Is it possible to set the ignition timing differently for a gesture ignition vs pow press? (For a casual user ) I’d like to have the button press ignition use the “0” setting in @Fett263 's library, and be able to speed up ignition during a swing-on.
I think we might be adding stuff for that in 7.x
It depends on the Prop though as the prop has to use a different type of ignition for this to work.
@Fett263 might know more.
Conditional effects in OS7 can do this. You’ll just apply a SwingSpeed to the Transition’s timing to swap.
