I’m about to try out FETT263_ENABLE_SPIN_MODE
and noticed the toggle addition here. Do I toggle while the saber is on? What’s the button press or combo?
Oops, typo in the define comment. It should be FETT263_SPIN_MODE
I’ll get comment and list updated.
Controls are listed at the top of the prop file.
Thanks. I’ve tried of few things and can’t get the FETT263_SPIN_MODE toggle sound to play. Without that I’m not sure whether spin mode is on or I’m just not hitting the clash threshold when I spin and “clash through” by hitting my leg on an obi ani (most common goof) or doing simple loops or orbits and hitting it with my hand.
I disabled FETT_263_HOLD_BUTTON_LOCKUP. No luck. Then went back and also disabled FETT263_BM_CLASH_DETECT and FETT263_QUOTE_PLAYER_START_ON to see if that would help. Still cant get a .wav to play a Hold PWR + Swing.
I have both bmbegin.wav in common and force.wav in the font.
Config:
#define NUM_BLADES 2
#define VOLUME 1250
#define EXTRA_COLOR_BUFFER_SPACE 30
#define CLASH_THRESHOLD_G 3.0
#define FILTER_ORDER 8
#define MOTION_TIMEOUT 60 * 5 * 1000
#define IDLE_OFF_TIME 60 * 5 * 1000
#define FETT263_MULTI_PHASE
//#define FETT263_QUOTE_PLAYER_START_ON
//#define FETT263_HOLD_BUTTON_LOCKUP
//#define FETT263_LOCKUP_DELAY 200
//#define FETT263_BM_CLASH_DETECT 6
#define FETT263_SWING_ON
#define FETT263_SWING_ON_SPEED 200
#define FETT263_TWIST_OFF
//#define COLOR_CHANGE_DIRECT
#define FETT263_SAVE_PRESET
#define FETT263_SPIN_MODE
{ "ESB_Graflex;common", "common/tracks/Dagobah_Background.wav",
/* copyright Fett263 Rotoscope (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#Rotoscope
OS6.7 v4.021
Base Style: Hyper Responsive Rotoscope (Original Trilogy)
Base Color: Rgb<0,135,255> (0)
Preon Effect: Overload (PreOn Color)
Ignition Effect: SparkTip Ignition
PowerUp Effect: Power Burst Forward
Retraction Effect: Standard Retraction
Lockup Effect: Intensity Lockup V1, Begin Effect: Real Clash, End Effect: Full Blade Absorb
LightningBlock Effect: Responsive Lightning Block
Drag Effect: Intensity Sparking Drag
Melt Effect: Intensity Melt
Blast Effect: Responsive Blast Wave (Sound Based)
Clash Effect: Real Clash V1
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,TransitionEffectL<TrConcat<TrJoin<TrDelayX<IgnitionTime<0>>,TrInstant>,Stripes<5000,-2500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>,TrFade<800>>,EFFECT_IGNITION>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,244,157>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,244,157>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<0>>,TrWipeInX<RetractionTime<0>>,Black>,TransitionEffectL<TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<2,72,255>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,EFFECT_PREON>>>(),
/* copyright Fett263 Rotoscope (Accent LED / PCB) OS6 Style
OS6.7 v4.021
Off Behavior: Slow Run Forward
Ignition Effect: Instant
Retraction Effect: Instant
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>>,InOutTrL<TrInstant,TrInstant,TransitionLoop<Black,TrConcat<TrWipe<1000>,RgbArg<BASE_COLOR_ARG,Rgb<0,135,255>>,TrWipe<1000>>>>>>(),
"ESB_Graflex"},
{"AniKillerVader;common", "common/tracks/AniKillerVader.wav",
/* copyright Fett263 CustomBlade (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#CustomBlade
OS6.7 v4.021
Twin Suns In (50/50)
Default: AudioFlicker (Single Color (50%))
1: Fire Blade Slow (Sparking)
Base Color: Rgb<255,0,0> (0)
Ignition Effect: Twin Suns Out
Retraction Effect: Twin Suns In
Lockup Effect: Full Blade Lockup, Begin Effect: Real Clash, End Effect: Full Blade Absorb
Blast Effect: Blast Wave (Sound Based)
Clash Effect: Flash on Clash (Full Blade)
StylePtr<Layers<Remap<CenterDistF<Int<16384>>,Remap<CenterDistF<Int<8192>>,Remap<Scale<RampF,Int<0>,Int<65536>>,Mix<SmoothStep<Int<4096>,Int<16384>>,Remap<InvertF<RampF>,AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,Remap<InvertF<RampF>,StaticFire<RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,0,1,0,3000,2>>>>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<0,0,255>>,Scale<WavLen<>,Int<100>,Int<400>>,Int<100>,Scale<WavLen<>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,TransitionEffectL<TrConcat<TrJoin<TrDelay<30>,TrInstant>,RgbArg<CLASH_COLOR_ARG,Rgb<0,0,255>>,TrFade<300>>,EFFECT_CLASH>,LockupTrL<AudioFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<0,0,255>>>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,0,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<0,0,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<0,0,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrConcat<TrInstant,AlphaL<Black,LayerFunctions<LinearSectionF<Int<0>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>,LinearSectionF<Int<16384>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>,LinearSectionF<Int<32768>,Scale<Trigger<EFFECT_IGNITION,IgnitionTime<300>,Int<0>,Int<0>>,Int<16384>,Int<0>>>>>,TrDelayX<IgnitionTime<300>>>,TrConcat<TrInstant,AlphaL<Black,LayerFunctions<LinearSectionF<Int<0>,Scale<Trigger<EFFECT_RETRACTION,RetractionTime<0>,Int<0>,Int<0>>,Int<0>,Int<16384>>>,LinearSectionF<Int<16384>,Scale<Trigger<EFFECT_RETRACTION,RetractionTime<0>,Int<0>,Int<0>>,Int<0>,Int<16384>>>,LinearSectionF<Int<32768>,Scale<Trigger<EFFECT_RETRACTION,RetractionTime<0>,Int<0>,Int<0>>,Int<0>,Int<16384>>>>>,TrDelayX<RetractionTime<0>>>,Black>>>(),
/* copyright Fett263 CustomBlade (Accent LED / PCB) OS6 Style
OS6.7 v4.021
Off Behavior: Heart Beat
StylePtr<Layers<Remap<CenterDistF<Int<16384>>,Remap<CenterDistF<Int<8192>>,Remap<Scale<RampF,Int<0>,Int<65536>>,Mix<SmoothStep<Int<4096>,Int<16384>>,Remap<InvertF<RampF>,AudioFlicker<RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>>,Remap<InvertF<RampF>,StaticFire<RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<10280>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,0,0>>>,0,1,0,3000,2>>>>>>,InOutTrL<TrInstant,TrInstant,TransitionLoop<RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,TrConcat<TrBoing<1200,2>,Mix<Int<1285>,Black,RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>>,TrFade<1200>>>>>>(),
"AniKillerVader"},
{"Ronin;common", "common/tracks/RoninStrings.wav",
/* copyright Fett263 Visions (Primary Blade) OS6 Style
https://fett263.com/fett263-proffieOS6-style-library.html#Visions
OS6.7 v4.021
Base Style: The Duel: Ronin
Ignition Effect: Standard Ignition
Blast Effect: Blast Fade (Sound Based)
Swing Effect: Interactive Power Build-up (Force Recharge)
Swing Option 0- Interactive Power Build-up (Force Recharge) Interactive Control: Force to build up Power, Swing to throw, recharge after use with Force.
StylePtr<Layers<HumpFlicker<Stripes<20000,-800,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<12000>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,50>,ColorSelect<IncrementWithReset<ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<25>,Int<38000>>>,Int<0>>,Int<12000>>,ThresholdPulseF<Sum<EffectPulseF<EFFECT_IGNITION>,EffectPulseF<EFFECT_FORCE>>,Int<32000>>,Int<1>>,TrJoinR<TrDelay<300>,TrSmoothFade<500>>,AlphaL<StripesX<Int<10000>,Scale<IncrementWithReset<ThresholdPulseF<Ifon<StrobeF<Int<12>,Int<1>>,Int<0>>,Int<32000>>,ThresholdPulseF<Sum<ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<33000>>>,Int<0>>,Int<24000>>,EffectPulseF<EFFECT_FORCE>>,Int<32000>>,Int<10000>,Int<100>>,Int<-50>,Int<-8000>>,Mix<Int<10000>,Black,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>>,Mix<Int<20000>,Black,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>>,RgbArg<SWING_COLOR_ARG,Rgb<100,100,150>>>,SmoothStep<Sum<IncrementWithReset<ThresholdPulseF<StrobeF<Int<10>,Int<1>>,Int<30000>>,ThresholdPulseF<Sum<ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<38000>>>,Int<0>>,Int<16000>>,EffectPulseF<EFFECT_FORCE>>,Int<32000>>,Int<4000>,Int<100>>,IncrementWithReset<ThresholdPulseF<Ifon<HoldPeakF<SwingSpeed<400>,Int<100>,Int<33000>>,Int<0>>,Int<16000>>,ThresholdPulseF<Sum<ThresholdPulseF<Ifon<InvertF<HoldPeakF<SwingSpeed<400>,Int<100>,Int<38000>>>,Int<0>>,Int<16000>>,EffectPulseF<EFFECT_FORCE>>,Int<32000>>,Int<38000>,Int<38000>>>,Int<-2000>>>,AlphaL<RgbArg<BASE_COLOR_ARG,Red>,Int<0>>>,TransitionEffectL<TrConcat<TrInstant,AlphaMixL<Bump<EffectPosition<EFFECT_BLAST>,Scale<WavLen<>,Int<9000>,Int<12000>>>,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>,Mix<Int<16384>,Black,RgbArg<BLAST_COLOR_ARG,Rgb<191,255,255>>>>,TrFade<300>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<191,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<191,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>,BrownNoiseFlickerL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Int<200>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrJoin<TrDelay<8000>,TrInstant>,TrFade<3000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<191,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,LockupTrL<AlphaL<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<191,255,255>>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrConcat<TrJoin<TrDelay<4000>,TrWipeIn<200>>,AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<191,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,28000>,Int<3000>>>,TrFade<4000>>,TrFade<300>,SaberBase::LOCKUP_DRAG>,LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,Mix<TwistAngle<>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>,RotateColorsX<Int<3000>,Mix<Int<12000>,Black,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrConcat<TrWipeIn<100>,AlphaL<RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrJoin<TrDelay<4000>,TrFade<300>>,AlphaL<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,24,0>>>>,SmoothStep<IntArg<MELT_SIZE_ARG,28000>,Int<4000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,InOutTrL<TrWipeX<IgnitionTime<0>>,TrWipeInX<RetractionTime<0>>,Black>>>(),
/* copyright Fett263 (Accent LED / PCB) OS6 Style
OS6.7 v4.021
On Behavior: Vortex Bar Graph
Off Behavior: Off
StylePtr<Layers<TransitionLoop<Black,TrConcat<TrCenterWipeIn<500>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,TrCenterWipeIn<500>>>,InOutTrL<TrInstant,TrInstant,Black>>>(),
"SimpleWanderer"},
{ 0, WS281XBladePtr<125, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
WS281XBladePtr<14, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
, CONFIGARRAY(presets) },
Nice day out will test more later.
Strange, the code all looks good. Unfortunately, I won’t be near a computer until tomorrow. I’ll have a closer look when I get time. You can try hooking to Serial Monitor to see if it’s trying to play the sounds in the interim.
I just tested myself with the same defines you posted and it works fine, if you’re sure you have the sounds in your font perhaps you’re not getting the gesture correct?
- Start with the saber still (if it’s already moving too much then the Swing event will have already triggered, the saber needs to slow to nearly a rest to reset the Swing event).
- Hold down your Power Button
- Then Swing
Oy, I should read better: Standard Controls While Blade is OFF
I was trying with the blade on, assuming it was like battle mode.
It works well. 10 of 10 tries - activate, test impact, deactivate, test impact. All of the activations play bmbegin.wav and the deactivations play bmend.wav, which I really like as I use the old “Boots to the Head” pack there. No force.wav playback.
With swing-on defined you get a good ignition and the wav files play at a good mix. Pretty cool!!!
What define is needed for Force / Quote to be played while OFF?
None, its built in.
Sweet. Thanks!
Under the new BattleMode define list can we also do the following? *I don’t specifically see these listed but it does compile.
#define FETT263_BATTLE_MODE_SWING_ON
#define FETT263_BATTLE_MODE_TWIST_ON
Here’s the current config section.
#define FETT263_BATTLE_MODE_START_ON
#define FETT263_TWIST_ON
That we’d like to change to
You can’t just make up defines. They’ll compile but they don’t do anything. The top section of the prop contains all supported defines.
Thanks, I’m glad I asked first.
It would be sweet to be able to have those for dueling.
Just read the existing defines, that’s been a thing since OS5.
Yup, saw that. Much appreciated!
In OS6, I changed the “400” value to “100” in the prop_base code below on your instruction to allow for clashes to be recognized faster. Will this still be required going forward? In my testing thus far, I am noticing I cannot engage repetitive clashes at the same speed as I did with OS6.
Thanks!
virtual void Clash2(bool stab, float strength) {
SaberBase::SetClashStrength(strength);
if (Event(BUTTON_NONE, stab ? EVENT_STAB : EVENT_CLASH)) {
IgnoreClash(400);
} else {
IgnoreClash(100);
// Saber must be on and not in lockup mode for stab/clash.
if (SaberBase::IsOn() && !SaberBase::Lockup()) {
if (stab) {
SaberBase::DoStab();
} else {
SaberBase::DoClash();
Alreasy handled, see first post.
Prop Updates
Removed delay between Clashes (for Clash Spamming)
I saw that, but in my testing of OS7, the delay remains.
It shouldn’t it was resolved and tested months ago, post your config and Serial Monitor output.
Alright, as soon as I plug it in again, I’ll upload.
Just FYI, when changing that 400 value to 100 for the first IgnoreClash, like I did in OS6, it works as it did in OS6.
The prop already overrides that exact same setting right here:
