ProffieOS v6.x ALPHA testing
I did some testing on a v1.5 board and it does NOT seem to be exhibiting any motion symptoms, even after leaving it sit for more than an hour.
I’m flashing four sabers with the latest update and I’ll let them sit for a couple hours and then test to see which exhibit the symptoms and which don’t.
  1. My usual test saber: 1 button v2 board, no recharge/kill, 1 blade
  2. Pach Store Fallen Fylte: 1 button v2 board, recharge port, 2 blades
  3. Crossguard v2: 2 button v1.5 board, recharge port + kill switch, 2 blades
  4. Entropy: 1 button v2 board, recharge port, 3 blades
entropy.h (6.9 KB)
fallen.h (94.5 KB)
kylo.h (29.5 KB)
mhs_1btn.h (127.6 KB)
Hello all!
I made a few tweaks to the one-button controls in fett263’s prop file. Everything seems to be working correctly on my saber. I changed the controls to enter the Preset Menu and to enter Edit Mode. My suggested controls would be:
Blade Off Hold PWR (parallel or up): Enter Preset Menu
Blade Off Hold PWR (pointing down): Enter Edit Mode
This also frees up Triple Click PWR so that Rehearsal/Choreography Mode can be added to one-button sabers! My suggested controls for that would be:
Blade Off Triple Click PWR (pointing down): Enter Rehearsal Mode
Select New: Turn Right and Click PWR
Cancel Overwrite: Click PWR
Cancel Rehearsal Mode: Double Click and Hold PWR
Save Rehearsal: Double-Click PWR
Blade Off Triple Click PWR (parallel or up): Enter Choreography Mode
Exit Chreography Mode: Double-Click PWR
As I mentioned, I’ve been testing this on my saber and everything seems to be working correctly. How should I go about sharing my edited prop file?
If I’m being honest it seems premature to be sharing modded versions of a prop that’s not finalized during Alpha testing. I still have outstanding changes and additions and we’re trying to get through Alpha and Beta testing. What you do with your personal saber is up to you but I think introducing modded versions into testing is only going to confuse or delay what we’re trying to do, plus there’s still fixes in play so your version will become outdated once they’re merged.
Also, if you have suggestions on controls based on testing and usage why not just put them in as feedback?
That’s fair. Sorry, I’m new to testing. My thought was to get it added to yours, but I didn’t want to suggest something that wasn’t doable or wouldn’t work well, so I wanted to test it out first.
With Alpha (and Beta) we’re trying to test everything in the OS, introducing more variables will complicate things, especially things not in the base OS.
As to my prop, there’s still features I have in the queue so the controls you’re trying to add may interfere with other pieces you’re not seeing yet. If after everything is finalized and released you want to change controls on things that’s all well and good but while things are still being developed, tested and in flux it’s just going to complicate things.
Once everything is done and tested if there’s reasonable alternatives I can take a look. Let’s get past Alpha and Beta first.
Understood. Thanks for clarifying. And thank you for everything you’re doing for OS6!
I found another potential issue in the i2c/motion code that might be causing the gesture problem. The fix is fairly speculative, and since I don’t know exactly what’s causing the problem, it may or may not help. sa22c, please update and try again.
Here is the latest output on the ‘pre fix’ code. I’m reflashing now to see if anything changes.
Only the saber using both fett’s prop file AND the mhs_1btn.h config has the issue. I’m going to flash my other one button saber with the same config to see if it also has the same problem.
Battery voltage: 3.86
Battery voltage: 3.85
Cycle counting enabled, top will work next time.
Playing kestis/hum/hum01.wav
channels: 1 rate: 44100 bits: 16
Ignition.
unit = 1 vol = 0.50, Playing kestis/out/out01.wav
humstart: 1800
unit = 2 vol = 0.00, Playing kestis/swingl/swingl03.wav
unit = 3 vol = 0.00, Playing kestis/swingh/swingh03.wav
Audio DMA: 2.19%
Wav reading: 6.42%
Pixel DMA: 0.33%
LOOP: 1.06%
Motion: 0.00%
Global loops / second: 1831.93
High frequency loops / second: 2456.04
blade fps: 79.84
Acceleration measurements per second: 1650.94
Hybrid Font loop: 0.17%
WS2811_Blade loop: 7.66%
ClockControl loop: 0.69%
Booster loop: 0.46%
SDCard loop: 0.35%
Amplifier loop: 0.30%
LSM6DS3H loop: 0.35%
I2CBus loop: 0.19%
Parser loop: 75.34%
pow loop: 0.52%
SaberFett263Buttons loop: 2.44%
BatteryMonitor loop: 0.82%
Fusor loop: 0.31%
DAC loop: 0.07%
AudioDynamicMixer loop: 0.17%
MonitorHelper loop: 0.17%
I2CBUS: last_request = 4796413 (now = 4796413) i2c_detected_ = 1 used = 1
I2C STATE: 8
current: 536879528 id= 106 next= 0
LSM6DS3H: last_event_ 86252 LINE: 194
last: 536879528 id= 106 next= 0
Motion requested: 1 (millis() - last_motion_request=10704)
Whut? :fusordump
 Accel={0.85, -0.17, 0.41} (0.95) Gyro={-8.60, -2.21, 35.26} (36.36) down={0.28, -0.47, 0.70} (0.89) mss={5.53, 2.96, -2.89} (6.91)
 ready=0 swing speed=35.33 gyro slope=38.04 last_micros_ = 87252639 now = 507941329
 acceleration extrapolator data:
 START=86111407 samples=20 S(t^2)=ovf sum={2.73, -9.20, 17.81} S(.)={370028.59, -1247589.12, 2414705.25}
 start_copy=86111407 avg={0.14, -0.46, 0.89} slope={0.00, 0.00, -0.00} avg_t=135576.41
 86241827  {0.13, -0.47, 0.90}
 86242434  {0.13, -0.46, 0.89}
 86243040  {0.14, -0.47, 0.89}
 86243647  {0.14, -0.46, 0.89}
 86244254  {0.14, -0.46, 0.89}
 86244860  {0.13, -0.47, 0.89}
 86245467  {0.13, -0.46, 0.89}
 86246073  {0.13, -0.46, 0.89}
 86246680  {0.13, -0.46, 0.88}
 86247289  {0.14, -0.46, 0.89}
 86247893  {0.14, -0.45, 0.89}
 86248500  {0.14, -0.46, 0.89}
 86249106  {0.14, -0.46, 0.89}
 86249713  {0.13, -0.46, 0.89}
 86250320  {0.14, -0.46, 0.89}
 86250926  {0.14, -0.46, 0.89}
 86251533  {0.14, -0.46, 0.89}
 86252139  {0.14, -0.47, 0.90}
 86252746  {0.14, -0.46, 0.89}
 86241221  {0.13, -0.46, 0.89}
 ready=1
 gyro extrapolator data:
 START=86111419 samples=20 S(t^2)=ovf sum={-7.69, -87.16, -40.77} S(.)={-1044644.13, -11816117.00, -5518597.50}
 start_copy=86111419 avg={-0.38, -4.36, -2.04} slope={-0.00, 0.00, 0.00} avg_t=135576.91
 86241840  {-0.31, -4.27, -1.77}
 86242446  {-0.31, -4.15, -2.87}
 86243053  {-0.37, -4.64, -1.28}
 86243659  {-0.37, -4.46, -3.30}
 86244266  {-0.37, -4.21, -1.46}
 86244873  {-0.37, -4.46, -2.87}
 86245479  {-0.49, -4.33, -1.40}
 86246086  {-0.31, -4.58, -2.32}
 86246693  {-0.49, -4.09, -2.20}
 86247302  {-0.37, -4.39, -1.53}
 86247906  {-0.37, -4.15, -2.99}
 86248512  {-0.49, -4.58, -0.92}
 86249119  {-0.55, -4.15, -2.93}
 86249725  {-0.24, -4.64, -1.04}
 86250332  {-0.37, -4.39, -2.99}
 86250939  {-0.24, -4.64, -1.34}
 86251545  {-0.55, -3.85, -2.20}
 86252152  {-0.49, -4.64, -1.77}
 86252758  {-0.37, -4.15, -1.46}
 86241233  {-0.31, -4.39, -2.14}
 ready=1
unit = 1 vol = 0.50, Playing kestis/in/in01.wav
No sounds found: pstoff
So this is interesting. It means that a transfer was started, but not finished.
I don’t know what would cause that, but when it happens it’s supposed to cause a motion chip reset and then continue. The fix that I provided today may make that actually work the way it’s supposed to.
Well, I’m pretty sure the fix worked. Saber was working normally after an hour of sitting idle. I’ll leave it overnight and see what it does in the morning.
Cool. I’ll try it as well.
Hey all, so I connected the lightsaber with the usb and monitored it via serial monitor and it was working fine, I then flashed it with the new master and unplugged the usb, inserted my battery Swang on the lightsaber. I then go to try to twist off and it doesn’t turn off. Also the single button does not turn off.
Hum continues until I change the preset.
https://drive.google.com/file/d/1XGID-VgdxkDvkwmybSk9MxyP1MUA1uGw/view?usp=drivesdk
what’s the best way to share videos?
i was playing around with the motion gestures and and the gesture off worked but after a few attempts and trying to switch off the saber by twist off I wasn’t able to. please note that in this test the hum didn’t turn off.
unplugged the usb and plugged it back in twist on works but twist off doesn’t
23:24:53.906 -> Battery voltage: 0.15
23:24:58.486 -> EVENT: ?47 millis=329393
23:24:58.884 -> TWIST
23:24:58.884 -> EVENT: Twist millis=329800
23:24:58.884 -> Ignition.
23:24:58.917 -> unit = 0 vol = 0.50, Playing Bank16/preon1.wav
23:24:58.917 -> channels: 1 rate: 22050 bits: 16
23:24:59.481 -> EVENT: ?48 ON millis=330398
23:25:00.477 -> EVENT: ?48 ON millis=331400
23:25:03.265 -> Playing Bank16/poweron.wav
23:25:03.265 -> channels: 1 rate: 22050 bits: 16
23:25:03.265 -> unit = 1 vol = 0.00, Playing Bank16/lswing1.wav
23:25:03.265 -> unit = 2 vol = 0.00, Playing Bank16/hswing1.wav
23:25:03.397 -> EVENT: ?48 ON millis=334307
23:25:04.293 -> unit = 1 vol = 0.00, Playing Bank16/lswing1.wav
23:25:04.293 -> channels: 1 rate: 22050 bits: 16
23:25:04.293 -> unit = 2 vol = 0.00, Playing Bank16/hswing1.wav
23:25:04.758 -> Playing Bank16/hum.wav
23:25:04.758 -> channels: 1 rate: 22050 bits: 16
23:25:05.388 -> EVENT: ?48 ON millis=336303
23:25:05.554 -> unit = 1 vol = 0.00, Playing Bank16/lswing1.wav
23:25:05.554 -> channels: 1 rate: 22050 bits: 16
23:25:05.587 -> unit = 2 vol = 0.00, Playing Bank16/hswing1.wav
23:25:05.587 -> channels: 1 rate: 22050 bits: 16
23:25:05.753 -> EVENT: Swing ON millis=336653
23:25:06.052 -> EVENT: Swing ON millis=336975
23:25:06.185 -> Playing Bank16/lswing1.wav
23:25:06.185 -> channels: 1 rate: 22050 bits: 16
23:25:06.185 -> Playing Bank16/hswing1.wav
23:25:06.218 -> channels: 1 rate: 22050 bits: 16
23:25:06.483 -> EVENT: Swing ON millis=337381
23:25:06.516 -> unit = 3 vol = 0.50, Playing Bank16/swing/swing7.wav
23:25:06.516 -> channels: 1 rate: 22050 bits: 16
23:25:06.583 -> EVENT: ?47 ON millis=337490
23:25:06.881 -> EVENT: Swing ON millis=337783
23:25:07.047 -> Playing Bank16/hum.wav
23:25:07.047 -> channels: 1 rate: 22050 bits: 16
23:25:07.180 -> unit = 2 vol = 0.00, Playing Bank16/lswing1.wav
23:25:07.180 -> channels: 1 rate: 22050 bits: 16
23:25:07.213 -> unit = 1 vol = 0.00, Playing Bank16/hswing1.wav
23:25:07.213 -> channels: 1 rate: 22050 bits: 16
23:25:07.279 -> EVENT: Swing ON millis=338193
23:25:08.209 -> unit = 2 vol = 0.00, Playing Bank16/lswing1.wav
23:25:08.209 -> channels: 1 rate: 22050 bits: 16
23:25:08.209 -> unit = 1 vol = 0.00, Playing Bank16/hswing1.wav
23:25:09.137 -> Battery voltage: 0.24
23:25:09.436 -> unit = 2 vol = 0.00, Playing Bank16/lswing1.wav
23:25:09.436 -> channels: 1 rate: 22050 bits: 16
23:25:09.436 -> unit = 1 vol = 0.00, Playing Bank16/hswing1.wav
23:25:09.801 -> Playing Bank16/hum.wav
23:25:09.801 -> channels: 1 rate: 22050 bits: 16
23:25:10.199 -> EVENT: ?47 ON millis=341117
23:25:10.730 -> unit = 1 vol = 0.00, Playing Bank16/lswing1.wav
23:25:10.730 -> channels: 1 rate: 22050 bits: 16
23:25:10.730 -> unit = 2 vol = 0.00, Playing Bank16/hswing1.wav
23:25:10.963 -> TWIST
23:25:10.963 -> EVENT: Twist ON millis=341872
23:25:10.963 -> unit = 4 vol = 0.50, Playing Bank16/poweroff.wav
23:25:10.963 -> channels: 1 rate: 22050 bits: 16
23:25:11.195 -> EVENT: ?48 millis=342119
23:25:11.593 -> No sounds found: pstoff
23:25:12.855 -> EVENT: ?47 millis=343779
23:25:14.845 -> Playing Bank16/hum.wav
23:25:14.845 -> channels: 1 rate: 22050 bits: 16
23:25:16.604 -> EVENT: ?47 millis=347520
23:25:17.201 -> EVENT: Swing millis=348115
23:25:17.201 -> Ignition.
23:25:17.201 -> unit = 3 vol = 0.50, Playing Bank16/poweron.wav
23:25:17.201 -> channels: 1 rate: 22050 bits: 16
23:25:17.201 -> unit = 2 vol = 0.00, Playing Bank16/lswing1.wav
23:25:17.201 -> unit = 1 vol = 0.00, Playing Bank16/hswing1.wav
23:25:17.234 -> channels: 1 rate: 22050 bits: 16
23:25:17.602 -> EVENT: ?48 ON millis=348522
23:25:18.696 -> Playing Bank16/hum.wav
23:25:18.696 -> channels: 1 rate: 22050 bits: 16
23:25:19.559 -> unit = 1 vol = 0.00, Playing Bank16/lswing1.wav
23:25:19.559 -> channels: 1 rate: 22050 bits: 16
23:25:19.559 -> unit = 2 vol = 0.00, Playing Bank16/hswing1.wav
23:25:19.890 -> Playing Bank16/hum.wav
23:25:19.890 -> channels: 1 rate: 22050 bits: 16
23:25:20.554 -> unit = 1 vol = 0.00, Playing Bank16/lswing1.wav
23:25:20.554 -> channels: 1 rate: 22050 bits: 16
23:25:20.554 -> unit = 2 vol = 0.00, Playing Bank16/hswing1.wav
23:25:21.682 -> EVENT: ?47 ON millis=352583
23:25:21.748 -> unit = 1 vol = 0.00, Playing Bank16/lswing1.wav
23:25:21.748 -> channels: 1 rate: 22050 bits: 16
23:25:21.748 -> unit = 2 vol = 0.00, Playing Bank16/hswing1.wav
23:25:22.014 -> TWIST
23:25:22.014 -> EVENT: Twist ON millis=352930
23:25:22.014 -> unit = 4 vol = 0.50, Playing Bank16/poweroff.wav
23:25:22.014 -> channels: 1 rate: 22050 bits: 16
23:25:22.644 -> No sounds found: pstoff
23:25:22.678 -> EVENT: ?48 millis=353584
23:25:24.337 -> EVENT: ?47 millis=355265
23:25:24.702 -> TWIST
23:25:24.702 -> EVENT: Twist millis=355625
23:25:24.702 -> Ignition.
23:25:24.702 -> unit = 3 vol = 0.50, Playing Bank16/preon1.wav
23:25:24.702 -> channels: 1 rate: 22050 bits: 16
23:25:24.934 -> Playing Bank16/hum.wav
23:25:24.934 -> channels: 1 rate: 22050 bits: 16
23:25:25.365 -> EVENT: ?48 ON millis=356266
23:25:28.783 -> EVENT: ?48 ON millis=359706
23:25:29.048 -> Playing Bank16/poweron.wav
23:25:29.048 -> channels: 1 rate: 22050 bits: 16
23:25:29.048 -> unit = 2 vol = 0.00, Playing Bank16/lswing1.wav
23:25:29.048 -> unit = 1 vol = 0.00, Playing Bank16/hswing1.wav
23:25:29.148 -> Battery voltage: 0.23
23:25:29.977 -> Playing Bank16/hum.wav
23:25:29.977 -> channels: 1 rate: 22050 bits: 16
23:25:30.542 -> Playing Bank16/hum.wav
23:25:30.542 -> channels: 1 rate: 22050 bits: 16
23:25:32.399 -> EVENT: ?47 ON millis=363323
23:25:33.527 -> EVENT: ?48 ON millis=364447
23:25:33.626 -> unit = 2 vol = 0.00, Playing Bank16/lswing1.wav
23:25:33.626 -> channels: 1 rate: 22050 bits: 16
23:25:33.626 -> unit = 1 vol = 0.00, Playing Bank16/hswing1.wav
23:25:34.655 -> EVENT: ?47 ON millis=365570
23:25:34.887 -> unit = 2 vol = 0.00, Playing Bank16/lswing1.wav
23:25:34.887 -> channels: 1 rate: 22050 bits: 16
23:25:34.887 -> unit = 1 vol = 0.00, Playing Bank16/hswing1.wav
23:25:35.020 -> Playing Bank16/hum.wav
23:25:35.020 -> channels: 1 rate: 22050 bits: 16
23:25:35.086 -> Playing Bank16/lswing1.wav
23:25:35.086 -> channels: 1 rate: 22050 bits: 16
23:25:35.086 -> Playing Bank16/hswing1.wav
23:25:35.584 -> Playing Bank16/hum.wav
23:25:35.584 -> channels: 1 rate: 22050 bits: 16
23:25:35.949 -> unit = 1 vol = 0.00, Playing Bank16/lswing1.wav
23:25:35.949 -> channels: 1 rate: 22050 bits: 16
23:25:35.949 -> unit = 2 vol = 0.00, Playing Bank16/hswing1.wav
23:25:40.070 -> Playing Bank16/hum.wav
23:25:40.070 -> channels: 1 rate: 22050 bits: 16
23:25:40.635 -> Playing Bank16/hum.wav
23:25:40.635 -> channels: 1 rate: 22050 bits: 16
23:25:44.720 -> Playing Bank16/lswing1.wav
23:25:44.720 -> channels: 1 rate: 22050 bits: 16
23:25:44.720 -> Playing Bank16/hswing1.wav
23:25:45.119 -> Playing Bank16/hum.wav
23:25:45.119 -> channels: 1 rate: 22050 bits: 16
23:25:45.686 -> Playing Bank16/hum.wav
23:25:45.686 -> channels: 1 rate: 22050 bits: 16
23:25:49.143 -> Battery voltage: 0.24
23:25:50.172 -> Playing Bank16/hum.wav
23:25:50.172 -> channels: 1 rate: 22050 bits: 16
23:25:50.736 -> Playing Bank16/hum.wav
23:25:50.736 -> channels: 1 rate: 22050 bits: 16
23:25:54.357 -> Playing Bank16/lswing1.wav
23:25:54.357 -> channels: 1 rate: 22050 bits: 16
23:25:54.357 -> Playing Bank16/hswing1.wav
23:25:55.220 -> Playing Bank16/hum.wav
23:25:55.220 -> channels: 1 rate: 22050 bits: 16
23:25:55.785 -> Playing Bank16/hum.wav
23:25:55.785 -> channels: 1 rate: 22050 bits: 16
23:26:00.269 -> Playing Bank16/hum.wav
23:26:00.269 -> channels: 1 rate: 22050 bits: 16
23:26:00.845 -> Playing Bank16/hum.wav
23:26:00.845 -> channels: 1 rate: 22050 bits: 16
23:26:03.967 -> Playing Bank16/lswing1.wav
23:26:03.967 -> channels: 1 rate: 22050 bits: 16
23:26:04.000 -> Playing Bank16/hswing1.wav
23:26:04.000 -> channels: 1 rate: 22050 bits: 16
23:26:05.329 -> Playing Bank16/hum.wav
23:26:05.329 -> channels: 1 rate: 22050 bits: 16
23:26:05.860 -> Playing Bank16/hum.wav
23:26:05.860 -> channels: 1 rate: 22050 bits: 16
23:26:09.149 -> Battery voltage: 0.25
23:26:10.379 -> Playing Bank16/hum.wav
23:26:10.379 -> channels: 1 rate: 22050 bits: 16
23:26:10.910 -> Playing Bank16/hum.wav
23:26:10.910 -> channels: 1 rate: 22050 bits: 16
23:26:13.598 -> Playing Bank16/lswing1.wav
23:26:13.598 -> channels: 1 rate: 22050 bits: 16
23:26:13.632 -> Playing Bank16/hswing1.wav
23:26:13.632 -> channels: 1 rate: 22050 bits: 16
23:26:15.425 -> Playing Bank16/hum.wav
23:26:15.425 -> channels: 1 rate: 22050 bits: 16
23:26:15.956 -> Playing Bank16/hum.wav
23:26:15.956 -> channels: 1 rate: 22050 bits: 16
23:26:20.471 -> Playing Bank16/hum.wav
23:26:20.471 -> channels: 1 rate: 22050 bits: 16
23:26:21.002 -> Playing Bank16/hum.wav
23:26:21.002 -> channels: 1 rate: 22050 bits: 16
23:26:23.259 -> Playing Bank16/lswing1.wav
23:26:23.259 -> channels: 1 rate: 22050 bits: 16
23:26:23.259 -> Playing Bank16/hswing1.wav
23:26:25.517 -> Playing Bank16/hum.wav
23:26:25.517 -> channels: 1 rate: 22050 bits: 16
23:26:26.049 -> Playing Bank16/hum.wav
23:26:26.049 -> channels: 1 rate: 22050 bits: 16
23:26:29.137 -> Battery voltage: 0.26
23:26:30.564 -> Playing Bank16/hum.wav
23:26:30.564 -> channels: 1 rate: 22050 bits: 16
23:26:31.095 -> Playing Bank16/hum.wav
23:26:31.095 -> channels: 1 rate: 22050 bits: 16
23:26:32.888 -> Playing Bank16/lswing1.wav
23:26:32.888 -> channels: 1 rate: 22050 bits: 16
23:26:32.888 -> Playing Bank16/hswing1.wav
23:26:35.610 -> Playing Bank16/hum.wav
23:26:35.610 -> channels: 1 rate: 22050 bits: 16
23:26:36.142 -> Playing Bank16/hum.wav
23:26:36.142 -> channels: 1 rate: 22050 bits: 16
23:26:40.658 -> Playing Bank16/hum.wav
23:26:40.658 -> channels: 1 rate: 22050 bits: 16
23:26:41.190 -> Playing Bank16/hum.wav
23:26:41.190 -> channels: 1 rate: 22050 bits: 16
23:26:42.518 -> Playing Bank16/lswing1.wav
23:26:42.518 -> channels: 1 rate: 22050 bits: 16
23:26:42.518 -> Playing Bank16/hswing1.wav
23:26:45.704 -> Playing Bank16/hum.wav
23:26:45.704 -> channels: 1 rate: 22050 bits: 16
23:26:46.235 -> Playing Bank16/hum.wav
23:26:46.235 -> channels: 1 rate: 22050 bits: 16
23:26:49.123 -> Battery voltage: 0.26
23:26:50.750 -> Playing Bank16/hum.wav
23:26:50.750 -> channels: 1 rate: 22050 bits: 16
23:26:51.314 -> Playing Bank16/hum.wav
23:26:51.314 -> channels: 1 rate: 22050 bits: 16
23:26:52.145 -> Playing Bank16/lswing1.wav
23:26:52.145 -> channels: 1 rate: 22050 bits: 16
23:26:52.145 -> Playing Bank16/hswing1.wav
23:26:55.797 -> Playing Bank16/hum.wav
23:26:55.797 -> channels: 1 rate: 22050 bits: 16
23:26:56.362 -> Playing Bank16/hum.wav
23:26:56.362 -> channels: 1 rate: 22050 bits: 16
23:27:00.845 -> Playing Bank16/hum.wav
23:27:00.845 -> channels: 1 rate: 22050 bits: 16
23:27:01.409 -> Playing Bank16/hum.wav
23:27:01.409 -> channels: 1 rate: 22050 bits: 16
23:27:01.775 -> Playing Bank16/lswing1.wav
23:27:01.775 -> channels: 1 rate: 22050 bits: 16
23:27:01.775 -> Playing Bank16/hswing1.wav
23:27:05.889 -> Playing Bank16/hum.wav
23:27:05.889 -> channels: 1 rate: 22050 bits: 16
23:27:06.453 -> Playing Bank16/hum.wav
23:27:06.453 -> channels: 1 rate: 22050 bits: 16
23:27:09.146 -> Battery voltage: 0.27
23:27:10.937 -> Playing Bank16/hum.wav
23:27:10.937 -> channels: 1 rate: 22050 bits: 16
23:27:11.405 -> Playing Bank16/lswing1.wav
23:27:11.405 -> channels: 1 rate: 22050 bits: 16
23:27:11.405 -> Playing Bank16/hswing1.wav
23:27:11.500 -> Playing Bank16/hum.wav
23:27:11.500 -> channels: 1 rate: 22050 bits: 16
23:27:15.982 -> Playing Bank16/hum.wav
23:27:15.982 -> channels: 1 rate: 22050 bits: 16
23:27:16.546 -> Playing Bank16/hum.wav
23:27:16.546 -> channels: 1 rate: 22050 bits: 16
23:27:21.030 -> Playing Bank16/lswing1.wav
23:27:21.030 -> channels: 1 rate: 22050 bits: 16
23:27:21.030 -> Playing Bank16/hum.wav
23:27:21.030 -> Playing Bank16/hswing1.wav
23:27:21.594 -> Playing Bank16/hum.wav
23:27:21.594 -> channels: 1 rate: 22050 bits: 16
23:27:23.253 -> EVENT: Clash ON millis=474191
23:27:23.253 -> unit = 5 vol = 0.50, Playing Bank16/clsh/clsh02.wav
23:27:23.253 -> channels: 1 rate: 22050 bits: 16
in this monitor I changed preset and it turned off and twist on and twist off worked,
I may have found the cause (or at least a contributing factor). I had made DetectMenuTwist() available outside the menu a little while back but it appears it’s interfering with EVENT_TWIST in certain scenarios and the 1 button additions were missing the reset on last_twist_millis_ which is used to prevent multiple twist events triggering from users twisting back and forth more than once to perform action. It may have been causing certain Twist events shared by one and two buttons to act differently. I added to the existing PR for the saber_off_time_millis_ reset as this also was causing some motion troubles. If you can merge I’d like to have Matt and Max give the changes a try. I had some odd behavior on Twist events but it wasn’t consistent so I looked at the code itself and these fixes seem to have done it for me but since was an inconsistent problem I’d like more testing.
To clarify, download the latest prop file and flash the board, right?
Not until it’s merged.
I’m watching the github as we speak and I’ll monitor it for now
The “ALPHA exit criteria” list is done.
This the last call for new features in ProffieOS v6.x.
Unless something comes up, ProffieOS v6.x will go from ALPHA to BETA tomorrow.
(Assuming I have the time to make zip files and stuff.)
Going to beta will mean two things:
  1. I will make zip files available, to make it easier for people to try it.
  2. The bar for adding new features is raised, generally, after tomorrow, any new features we want to add to ProffieOS should go to ProffieOS 7.x instead of ProffieOS 6.x.
I have 2 helper functions I need to add to my prop, just need to resynch the prop with the recent fixes and I’ll submit.
This thread is ending. I’m creating a new thread for BETA testing.
(Long threads are hard to navigate…)
