Not without re-coding how it works. You do know you just turn left or right to select the starting track you want, right? It let’s you pick any track you want to play, you’re not stuck with one.
How do I comment out a color?
Two slashes “//” in front
{ Red::color(), COLOR_RED },
// { OrangeRed::color(), COLOR_ORANGERED },
{ DarkOrange::color(), COLOR_DARKORANGE },
Navajowhite and Moccasin have been commented out and will let you know...
It works and no problems encountered
Great, thanks for confirming.
Just checking you saw this reply on using Track Player.
When cycling style options in edit mode, after 5 what should the next turn yield? It seems to keep counting up but repeat the 0-5 options in the same order. Is that correct?
Edit: I’m using the Fett263’s Rotoscope test style.
That depends on the style itself, in your config it lists the options for the style available.
It’s your OS6 rotoscope test style as directed from the Edit Mode section on your website. I’m having trouble reading the code directly to see what the style options are. Maybe you’d be willing to point that out during your youtube broadcast?
With the style as it is here, should the style options and effects options have a maximum value (of 5 I think, looking at the documentation)?
StylePtr<Layers<
ColorSelect<IntArg<STYLE_OPTION_ARG, 0>,TrInstant,RandomFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<10000,-2600,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<14000,-4000,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<14000,-4000,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<11565>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>,RandomFlicker<Stripes<24000,-1400,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<16448>,Black,RgbArg<ALT_COLOR_ARG,Rgb<255,68,0>>>>,RgbArg<BASE_COLOR_ARG,Rgb<255,0,0>>>>,
ColorSelect<IntArg<SWING_OPTION_ARG, 0>,TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Int<0>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,SwingSpeed<600>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,TrDelay<30000>>,EFFECT_FORCE>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<SWING_COLOR_ARG,Rgb<125,125,125>>,SwingSpeed<600>>,TrDelay<30000>>,EFFECT_FORCE>>,
TransitionEffectL<TrSelect<IntArg<IGNITION_POWER_UP_ARG,0>,TrInstant,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,Stripes<3000,-3500,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,RandomPerLEDFlicker<Mix<Int<7710>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Black>,BrownNoiseFlicker<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,200>,RandomPerLEDFlicker<Mix<Int<10280>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,Mix<Int<3855>,Black,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>>>,TrFadeX<IgnitionTime<300>>>,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,TrFadeX<IgnitionTime<300>>>,TrConcat<TrExtendX<IgnitionTime<300>,TrInstant>,AudioFlickerL<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>>,TrFadeX<IgnitionTime<300>>>>,EFFECT_IGNITION>,
TransitionEffectL<TrSelect<IntArg<RETRACTION_COOL_DOWN_ARG,0>,TrInstant,TrConcat<TrInstant,HumpFlickerL<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,40>,TrDelayX<RetractionTime<0>>>,TrConcat<TrInstant,RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,TrDelayX<RetractionTime<0>>>>,EFFECT_RETRACTION>,
LockupTrL<AlphaL<Remap<CenterDistF<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,StripesX<Int<1800>,Scale<NoisySoundLevel,Int<-3500>,Int<-5000>>,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<16000>>>,TrConcat<TrExtend<50,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrExtend<3000,TrFade<300>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<10280>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump< Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Int<13000>>>,TrFade<3000>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrSelect<Scale<IsLessThan<ClashImpactF<>,Int<20000>>,Int<1>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>, Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,TrSparkX<Remap<CenterDistF< Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>> ,Stripes<1200,-3600,Mix<Int<6425>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12850>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>>,Int<30>,Scale<Sum<ClashImpactF<>,SwingSpeed<600>>,Int<100>,Int<400>>, Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>>>,SaberBase::LOCKUP_NORMAL>,
ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrInstant,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Int<12000>,Int<18000>>>,TrFade<200>>,TrConcat<TrInstant,HumpFlickerL<AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Int<16000>>,30>,TrSmoothFade<600>>>,
EffectSequence<EFFECT_BLAST,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,BlastF<200,200>>,TrFade<300>>,EFFECT_BLAST>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Int<400>,Scale<SwingSpeed<200>,Int<100>,Int<400>>,Int<400>>,ResponsiveBlastWaveL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<500>,Int<200>>,Scale<SwingSpeed<400>,Int<100>,Int<400>>>,ResponsiveBlastFadeL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<6000>,Int<12000>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>>,ResponsiveBlastL<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<SwingSpeed<400>,Int<400>,Int<100>>,Scale<SwingSpeed<400>,Int<200>,Int<100>>,Scale<SwingSpeed<400>,Int<400>,Int<200>>>>,
Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,ResponsiveBlastWaveL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<50>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<500>,Int<300>>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>,EFFECT_CLASH>>,
LockupTrL<AlphaL<BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,SmoothStep<IntArg<DRAG_SIZE_ARG,31000>,Int<2000>>>,TrWipeIn<400>,TrFade<300>,SaberBase::LOCKUP_DRAG>,
LockupTrL<AlphaL<Remap<Scale<RampF,Int<65536>,Int<0>>,StaticFire<Mix<TwistAngle<>,OrangeRed,DarkOrange>,Mix<TwistAngle<>,OrangeRed,Orange>,0,3,5,3000,10>>,SmoothStep<IntArg<MELT_SIZE_ARG,26000>,Int<6000>>>,TrConcat<TrWipeIn<100>,AlphaL<Red,SmoothStep<Int<29000>,Int<8000>>>,TrExtend<2000,TrFade<300>>,AlphaL<Mix<TwistAngle<>,Red,Orange>,SmoothStep<Int<29000>,Int<8000>>>,TrFade<3000>>,TrWipe<200>,SaberBase::LOCKUP_MELT>,
InOutTrL<TrSelect<IntArg<IGNITION_OPTION_ARG,0>,TrWipeX<IgnitionTime<300>>,TrWipeInX<IgnitionTime<300>>,TrColorCycleX<IgnitionTime<300>>,TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,Rgb<255,255,255>>,IgnitionTime<300>>,TrCenterWipeX<IgnitionTime<300>,Int<16384>>,TrCenterWipeInX<IgnitionTime<300>,Int<16384>>>,TrSelect<IntArg<RETRACTION_OPTION_ARG,0>,TrWipeInX<RetractionTime<0>>,TrWipeX<RetractionTime<0>>,TrColorCycleX<RetractionTime<0>>,TrWipeInSparkTipX<RgbArg<RETRACTION_COLOR_ARG,Rgb<255,255,255>>,RetractionTime<0>>,TrCenterWipeInX<RetractionTime<0>,Int<16384>>,TrCenterWipeX<RetractionTime<0>,Int<16384>>>,RotateColorsX<Variation,Black>>,
TransitionEffectL<TrSelect<IntArg<PREON_OPTION_ARG,0>,TrInstant,TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Mult<Int<16384>,WavLen<EFFECT_PREON>>,Mult<Int<10922>,WavLen<EFFECT_PREON>>,Mult<Int<5462>,WavLen<EFFECT_PREON>>>,BrownNoiseFlicker<Black,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,100>,RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Rgb<50,50,50>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,RotateColorsX<Int<4000>,RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>>>,White,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrInstant,AlphaL<RandomPerLEDFlicker<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Black>,SmoothStep<Scale<NoisySoundLevel,Int<-10000>,Int<36000>>,Int<-4000>>>,TrDelayX<WavLen<EFFECT_PREON>>>,TrConcat<TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,10>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,15>,SmoothStep<Sum<Int<2000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrFadeX<Mult<Int<8192>,WavLen<EFFECT_PREON>>>,AlphaL<HumpFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,20>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<8192>,WavLen<EFFECT_PREON>>,3>>,TrConcat<TrBoingX<Mult<Int<10922>,WavLen<EFFECT_PREON>>,5>,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<100>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrBoingX<Mult<Int<10922>,WavLen<EFFECT_PREON>>,3>,Black,TrBoingX<Mult<Int<7260>,WavLen<EFFECT_PREON>>,3>,AlphaL<BrownNoiseFlickerL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<200>>,SmoothStep<Sum<Int<4000>,IntArg<PREON_SIZE_ARG,2000>>,Int<-4000>>>,TrBoingX<Mult<Int<3664>,WavLen<EFFECT_PREON>>,3>>,TrConcat<TrFadeX<Mult<Int<4096>,WavLen<EFFECT_PREON>>>,AlphaL<PulsingL<RgbArg<PREON_COLOR_ARG,Rgb<255,0,0>>,Int<800>>,SmoothStep<IntArg<PREON_SIZE_ARG,2000>,Int<-4000>>>,TrDelayX<Mult<Int<28672>,WavLen<EFFECT_PREON>>>>>,EFFECT_PREON>,
TransitionEffectL<TrConcat<TrExtend<3000,TrInstant>,AlphaL<Mix<BatteryLevel,Red,Green>,Bump<BatteryLevel,Int<10000>>>,TrFade<1000>>,EFFECT_BATTERY_LEVEL>
StylePtr<IgnitionDelayX<IntArg<IGNITION_DELAY_ARG,550>,Layers<
StylePtr<Layers<
InOutTrL<TrFadeX<IgnitionTime<100>>,TrFadeX<RetractionTime<600>>,ColorSelect<IntArg<OFF_OPTION_ARG,0>,TrInstant,TransitionLoop<RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,TrConcat<TrBoing<1200,2>,Mix<Int<1285>,Black,RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>>,TrFade<1200>>>,Pulsing<RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,Mix<Int<7710>,Black,RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>>,800>,ColorCycle<RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,25,100,RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,25,300,4000>,ColorCycle<RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,25,300,RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,25,100,4000>,TransitionLoop<Black,TrConcat<TrWipe<1000>,RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,TrWipe<1000>>>,TransitionLoop<Black,TrConcat<TrWipeIn<200>,RgbArg<OFF_COLOR_ARG,Rgb<255,0,0>>,TrWipeIn<200>>>>>
>>(), "Rotoscope"},
You need to make sure you have the copyright section with each style or you’ll be totally lost. Go back to the Test Styles and include the copyright and option info in your config.
So, can someone tell me the details around dynamic blade length?
It just let’s you edit the length of your blade(s) IF combined with Edit Mode or ProffieOS Workbench and the save version. It’s automatically enabled with the ENABLE_ALL_EDIT_OPTIONS define.
Yeah this is a big deal for me since the bladeID resistor is out in my setup. Do we have a wiki page yet on how to actually do it?
It’s handled in Edit Mode under the Settings Menu, too complicated to make a Wiki this is the page for Edit Mode.
i apologize but do all the blade styles have to start with StylePtr< if so, how come ones i have made using Blade library work on the style editor after editing them to my liking then start with only Layers< but wont convert to “style Factory”.
There is no OS6 library styles or editor yet.
Yes, you need StylePtr <…>()
Styles copied correctly. I’m kinda amazed here. Thanks!
When I am editing in the saber for ignition options, I get 0-5 that match perfectly with the copyright section. A counter clockwise turn past 0 gets a minimum value message, a clockwise turn past 5 went 9, 8, 7 and I stopped there. Is anyone else getting maximum value message after the last option?
that’s unfortunate ,i am aware thanks though, and to think I worked so hard on them ok- back to square one then.
Maximum for “options” is 32768, if there are only 5 then #6 is equal to #0 and so on. The menu cannot determine the number of options.
