Correct. I didn’t remove anything. I only added the line breaks. I’ll have to try to catch when it starts on serial monitor. Of course, there’s always 6.4. I’ll update and see if it goes away as a weird quirk
6.4 has no changes for motion though…
I caught the beginning on Serial Monitor this time. Like before, the line breaks represent times that the saber was off and I was swinging it with no swing on. The last section shows where Motion turns off then the boot sound plays when I press pwr. I trimmed off everything before the last ignition that worked with swing on.
15:14:12.874 -> EVENT: Swing millis=710642
15:14:12.874 -> Ignition.
15:14:12.874 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:14:12.874 -> channels: 1 rate: 44100 bits: 16
15:14:12.874 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out05.wav
15:14:12.874 -> humstart: 100
15:14:12.874 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:14:12.874 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:14:14.187 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl03.wav
15:14:14.187 -> channels: 1 rate: 44100 bits: 16
15:14:14.187 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh03.wav
15:14:14.936 -> TWIST
15:14:14.936 -> EVENT: Twist ON millis=712714
15:14:14.936 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:14:14.936 -> channels: 1 rate: 44100 bits: 16
15:14:15.592 -> No sounds found: pstoff
15:14:15.639 -> Amplifier off.
15:14:16.623 -> Unmounting SD Card.
15:14:22.435 -> Battery voltage: 3.76
15:14:22.435 -> EVENT: Power-Pressed#1 millis=720245
15:14:22.435 -> EVENT: Power-Pressed millis=720245
15:14:22.528 -> EVENT: Power-Released#1 millis=720342
15:14:22.528 -> EVENT: Power-Released millis=720342
15:14:22.528 -> EVENT: Power-Shortclick#1 millis=720342
15:14:22.528 -> EVENT: Power-Shortclick millis=720342
15:14:22.763 -> EVENT: Power-SavedShortclick#1 millis=720546
15:14:22.763 -> Ignition.
15:14:22.763 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:14:22.763 -> channels: 1 rate: 44100 bits: 16
15:14:22.763 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out03.wav
15:14:22.763 -> humstart: 100
15:14:22.763 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl03.wav
15:14:22.763 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh03.wav
15:14:22.809 -> channels: 1 rate: 44100 bits: 16
15:14:34.245 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:14:34.245 -> channels: 1 rate: 44100 bits: 16
15:14:34.245 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:14:42.399 -> Battery voltage: 3.53
15:14:47.320 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:14:47.320 -> channels: 1 rate: 44100 bits: 16
15:14:47.320 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:14:57.802 -> Playing 02_TPM_Obi/hum.wav
15:14:57.802 -> channels: 1 rate: 44100 bits: 16
15:15:00.380 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:15:00.380 -> channels: 1 rate: 44100 bits: 16
15:15:00.380 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:15:02.395 -> Battery voltage: 3.51
15:15:13.455 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:15:13.455 -> channels: 1 rate: 44100 bits: 16
15:15:13.455 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:15:13.642 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl03.wav
15:15:13.642 -> channels: 1 rate: 44100 bits: 16
15:15:13.642 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh03.wav
15:15:22.404 -> Battery voltage: 3.51
15:15:26.481 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:15:26.481 -> channels: 1 rate: 44100 bits: 16
15:15:26.528 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:15:26.528 -> channels: 1 rate: 44100 bits: 16
15:15:32.808 -> Playing 02_TPM_Obi/hum.wav
15:15:32.808 -> channels: 1 rate: 44100 bits: 16
15:15:39.556 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:15:39.556 -> channels: 1 rate: 44100 bits: 16
15:15:39.603 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:15:39.603 -> channels: 1 rate: 44100 bits: 16
15:15:42.413 -> Battery voltage: 3.51
15:15:52.630 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:15:52.630 -> channels: 1 rate: 44100 bits: 16
15:15:52.630 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:16:02.414 -> Battery voltage: 3.50
15:16:05.695 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:16:05.695 -> channels: 1 rate: 44100 bits: 16
15:16:05.742 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:16:05.742 -> channels: 1 rate: 44100 bits: 16
15:16:07.851 -> Playing 02_TPM_Obi/hum.wav
15:16:07.851 -> channels: 1 rate: 44100 bits: 16
15:16:18.770 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:16:18.770 -> channels: 1 rate: 44100 bits: 16
15:16:18.770 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:16:22.425 -> Battery voltage: 3.50
15:16:31.845 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:16:31.845 -> channels: 1 rate: 44100 bits: 16
15:16:31.845 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:16:42.389 -> Battery voltage: 3.50
15:16:42.858 -> Playing 02_TPM_Obi/hum.wav
15:16:42.858 -> channels: 1 rate: 44100 bits: 16
15:16:44.920 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:16:44.920 -> channels: 1 rate: 44100 bits: 16
15:16:44.920 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:16:57.997 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:16:57.997 -> channels: 1 rate: 44100 bits: 16
15:16:57.997 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:17:02.403 -> Battery voltage: 3.50
15:17:11.072 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:17:11.072 -> channels: 1 rate: 44100 bits: 16
15:17:11.072 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:17:17.868 -> Playing 02_TPM_Obi/hum.wav
15:17:17.868 -> channels: 1 rate: 44100 bits: 16
15:17:22.414 -> Battery voltage: 3.49
15:17:24.147 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:17:24.147 -> channels: 1 rate: 44100 bits: 16
15:17:24.147 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:17:37.182 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:17:37.182 -> channels: 1 rate: 44100 bits: 16
15:17:37.229 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:17:37.229 -> channels: 1 rate: 44100 bits: 16
15:17:42.381 -> Battery voltage: 3.49
15:17:50.290 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:17:50.290 -> channels: 1 rate: 44100 bits: 16
15:17:50.290 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:17:52.902 -> Playing 02_TPM_Obi/hum.wav
15:17:52.902 -> channels: 1 rate: 44100 bits: 16
15:18:02.410 -> Battery voltage: 3.48
15:18:03.347 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:18:03.347 -> channels: 1 rate: 44100 bits: 16
15:18:03.347 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:18:16.422 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:18:16.422 -> channels: 1 rate: 44100 bits: 16
15:18:16.422 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:18:22.422 -> Battery voltage: 3.48
15:18:27.905 -> Playing 02_TPM_Obi/hum.wav
15:18:27.905 -> channels: 1 rate: 44100 bits: 16
15:18:29.498 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:18:29.498 -> channels: 1 rate: 44100 bits: 16
15:18:29.498 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:18:42.433 -> Battery voltage: 3.48
15:18:42.526 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:18:42.526 -> channels: 1 rate: 44100 bits: 16
15:18:42.573 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:18:42.573 -> channels: 1 rate: 44100 bits: 16
15:18:55.627 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:18:55.627 -> channels: 1 rate: 44100 bits: 16
15:18:55.627 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:19:02.422 -> Battery voltage: 3.48
15:19:02.938 -> Playing 02_TPM_Obi/hum.wav
15:19:02.938 -> channels: 1 rate: 44100 bits: 16
15:19:08.702 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:19:08.702 -> channels: 1 rate: 44100 bits: 16
15:19:08.702 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:19:21.755 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:19:21.755 -> channels: 1 rate: 44100 bits: 16
15:19:21.755 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:19:22.411 -> Battery voltage: 3.47
15:19:34.828 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:19:34.828 -> channels: 1 rate: 44100 bits: 16
15:19:34.828 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:19:37.967 -> Playing 02_TPM_Obi/hum.wav
15:19:37.967 -> channels: 1 rate: 44100 bits: 16
15:19:42.420 -> Battery voltage: 3.47
15:19:47.917 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:19:47.917 -> channels: 1 rate: 44100 bits: 16
15:19:47.917 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:20:00.979 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:20:00.979 -> channels: 1 rate: 44100 bits: 16
15:20:00.979 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:20:02.431 -> Battery voltage: 3.47
15:20:12.976 -> Playing 02_TPM_Obi/hum.wav
15:20:12.976 -> channels: 1 rate: 44100 bits: 16
15:20:14.054 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:20:14.054 -> channels: 1 rate: 44100 bits: 16
15:20:14.054 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:20:22.395 -> Battery voltage: 3.46
15:20:27.113 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:20:27.113 -> channels: 1 rate: 44100 bits: 16
15:20:27.113 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:20:40.157 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:20:40.157 -> channels: 1 rate: 44100 bits: 16
15:20:40.204 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:20:40.204 -> channels: 1 rate: 44100 bits: 16
15:20:42.406 -> Battery voltage: 3.46
15:20:48.030 -> Playing 02_TPM_Obi/hum.wav
15:20:48.030 -> channels: 1 rate: 44100 bits: 16
15:20:53.263 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:20:53.263 -> channels: 1 rate: 44100 bits: 16
15:20:53.263 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:21:02.401 -> Battery voltage: 3.46
15:21:06.338 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:21:06.338 -> channels: 1 rate: 44100 bits: 16
15:21:06.338 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:21:19.373 -> Playing 02_TPM_Obi/swingl/swingl03.wav
15:21:19.373 -> channels: 1 rate: 44100 bits: 16
15:21:19.373 -> Playing 02_TPM_Obi/swingh/swingh03.wav
15:21:22.419 -> Battery voltage: 3.45
15:21:23.029 -> Playing 02_TPM_Obi/hum.wav
15:21:23.029 -> channels: 1 rate: 44100 bits: 16
15:21:25.700 -> TWIST
15:21:25.700 -> EVENT: Twist ON millis=1143672
15:21:25.700 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:21:25.747 -> channels: 1 rate: 44100 bits: 16
15:21:26.403 -> No sounds found: pstoff
15:21:26.450 -> Amplifier off.
15:21:27.434 -> Unmounting SD Card.
15:21:27.434 -> Booster off.
15:21:33.292 -> TWIST
15:21:33.292 -> EVENT: Twist millis=1151249
15:21:33.292 -> Ignition.
15:21:33.339 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:21:33.339 -> channels: 1 rate: 44100 bits: 16
15:21:33.339 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out03.wav
15:21:33.339 -> humstart: 100
15:21:33.339 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:21:33.339 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:21:34.839 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:21:34.839 -> channels: 1 rate: 44100 bits: 16
15:21:34.839 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:21:35.026 -> EVENT: Swing ON millis=1152969
15:21:35.401 -> EVENT: Swing ON millis=1153347
15:21:35.870 -> EVENT: Swing ON millis=1153807
15:21:36.432 -> EVENT: Swing ON millis=1154369
15:21:36.713 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:21:36.713 -> channels: 1 rate: 44100 bits: 16
15:21:36.713 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:21:36.854 -> EVENT: Swing ON millis=1154811
15:21:37.697 -> EVENT: Swing ON millis=1155623
15:21:38.728 -> TWIST
15:21:38.728 -> EVENT: Twist ON millis=1156667
15:21:38.728 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:21:38.728 -> channels: 1 rate: 44100 bits: 16
15:21:39.384 -> No sounds found: pstoff
15:21:39.431 -> Amplifier off.
15:21:40.426 -> Unmounting SD Card.
15:21:41.457 -> EVENT: Stab millis=1159417
15:21:41.457 -> Ignition.
15:21:41.457 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:21:41.457 -> channels: 1 rate: 44100 bits: 16
15:21:41.504 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out05.wav
15:21:41.504 -> channels: 1 rate: 44100 bits: 16
15:21:41.504 -> humstart: 100
15:21:41.504 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl03.wav
15:21:41.504 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh03.wav
15:21:42.394 -> Battery voltage: 3.48
15:21:43.563 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:21:43.563 -> channels: 1 rate: 44100 bits: 16
15:21:43.563 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:21:44.641 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl01.wav
15:21:44.641 -> channels: 1 rate: 44100 bits: 16
15:21:44.641 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh01.wav
15:21:44.734 -> TWIST
15:21:44.734 -> EVENT: Twist ON millis=1162713
15:21:44.734 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:21:44.781 -> channels: 1 rate: 44100 bits: 16
15:21:45.439 -> No sounds found: pstoff
15:21:45.486 -> Amplifier off.
15:21:46.283 -> EVENT: Power-Pressed#1 millis=1164233
15:21:46.283 -> EVENT: Power-Pressed millis=1164233
15:21:46.423 -> EVENT: Power-Released#1 millis=1164362
15:21:46.423 -> EVENT: Power-Released millis=1164362
15:21:46.423 -> EVENT: Power-Shortclick#1 millis=1164362
15:21:46.423 -> EVENT: Power-Shortclick millis=1164362
15:21:46.470 -> Unmounting SD Card.
15:21:46.564 -> EVENT: Power-SavedShortclick#1 millis=1164534
15:21:46.564 -> Ignition.
15:21:46.611 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:21:46.611 -> channels: 1 rate: 44100 bits: 16
15:21:46.611 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out03.wav
15:21:46.611 -> humstart: 100
15:21:46.611 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl03.wav
15:21:46.611 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh03.wav
15:21:47.735 -> EVENT: Swing ON millis=1165706
15:21:47.970 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl01.wav
15:21:47.970 -> channels: 1 rate: 44100 bits: 16
15:21:48.016 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh01.wav
15:21:48.016 -> channels: 1 rate: 44100 bits: 16
15:21:48.719 -> TWIST
15:21:48.719 -> EVENT: Twist ON millis=1166689
15:21:48.719 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:21:48.766 -> channels: 1 rate: 44100 bits: 16
15:21:49.422 -> No sounds found: pstoff
15:21:49.469 -> Amplifier off.
15:21:50.453 -> Unmounting SD Card.
15:21:54.604 -> EVENT: Power-Pressed#1 millis=1172559
15:21:54.604 -> EVENT: Power-Pressed millis=1172559
15:21:54.745 -> EVENT: Power-Released#1 millis=1172687
15:21:54.745 -> EVENT: Power-Released millis=1172687
15:21:54.745 -> EVENT: Power-Shortclick#1 millis=1172687
15:21:54.745 -> EVENT: Power-Shortclick millis=1172687
15:21:54.885 -> EVENT: Power-SavedShortclick#1 millis=1172860
15:21:54.885 -> Ignition.
15:21:54.932 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:21:54.932 -> channels: 1 rate: 44100 bits: 16
15:21:54.932 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out01.wav
15:21:54.932 -> humstart: 100
15:21:54.932 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl01.wav
15:21:54.932 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh01.wav
15:21:56.432 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:21:56.432 -> channels: 1 rate: 44100 bits: 16
15:21:56.432 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:21:56.526 -> TWIST
15:21:56.526 -> EVENT: Twist ON millis=1174508
15:21:56.526 -> unit = 4 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:21:56.572 -> channels: 1 rate: 44100 bits: 16
15:21:57.228 -> No sounds found: pstoff
15:21:57.275 -> Amplifier off.
15:21:58.259 -> Unmounting SD Card.
15:21:59.478 -> EVENT: Power-Pressed#1 millis=1177435
15:21:59.478 -> EVENT: Power-Pressed millis=1177435
15:21:59.619 -> EVENT: Power-Released#1 millis=1177599
15:21:59.619 -> EVENT: Power-Released millis=1177599
15:21:59.619 -> EVENT: Power-Shortclick#1 millis=1177599
15:21:59.619 -> EVENT: Power-Shortclick millis=1177599
15:21:59.759 -> EVENT: Power-SavedShortclick#1 millis=1177736
15:21:59.759 -> Ignition.
15:21:59.806 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:21:59.806 -> channels: 1 rate: 44100 bits: 16
15:21:59.806 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out05.wav
15:21:59.806 -> humstart: 100
15:21:59.806 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:21:59.806 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:22:01.493 -> EVENT: Swing ON millis=1179461
15:22:02.384 -> Battery voltage: 3.46
15:22:02.618 -> EVENT: Clash ON millis=1180579
15:22:02.618 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/clsh/clsh05.wav
15:22:02.618 -> channels: 1 rate: 44100 bits: 16
15:22:02.805 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl03.wav
15:22:02.805 -> channels: 1 rate: 44100 bits: 16
15:22:02.852 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh03.wav
15:22:02.852 -> channels: 1 rate: 44100 bits: 16
15:22:04.159 -> EVENT: Power-Pressed#1 ON millis=1182129
15:22:04.159 -> EVENT: Power-Pressed ON millis=1182129
15:22:04.486 -> EVENT: Power-Held#1 ON millis=1182432
15:22:04.486 -> EVENT: Power-Held ON millis=1182432
15:22:04.486 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:22:04.486 -> channels: 1 rate: 44100 bits: 16
15:22:04.486 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:22:04.580 -> EVENT: Clash mods Power ON millis=1182518
15:22:04.580 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/bgnlock/bgnlock4.wav
15:22:04.580 -> channels: 1 rate: 44100 bits: 16
15:22:05.564 -> EVENT: Power-Released#1 ON millis=1183537
15:22:05.564 -> EVENT: Power-Released ON millis=1183537
15:22:05.564 -> unit = 4 vol = 0.50, Playing 02_TPM_Obi/endlock/endlock1.wav
15:22:05.564 -> channels: 1 rate: 44100 bits: 16
15:22:06.127 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl03.wav
15:22:06.127 -> channels: 1 rate: 44100 bits: 16
15:22:06.127 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh03.wav
15:22:07.158 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:22:07.158 -> channels: 1 rate: 44100 bits: 16
15:22:07.158 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:22:08.423 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:22:08.423 -> channels: 1 rate: 44100 bits: 16
15:22:08.470 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:22:08.470 -> channels: 1 rate: 44100 bits: 16
15:22:09.032 -> EVENT: Clash ON millis=1186992
15:22:09.032 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/clsh/clsh01.wav
15:22:09.032 -> channels: 1 rate: 44100 bits: 16
15:22:09.688 -> EVENT: Clash ON millis=1187645
15:22:09.688 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/clsh/clsh02.wav
15:22:09.688 -> channels: 1 rate: 44100 bits: 16
15:22:10.626 -> EVENT: Clash ON millis=1188582
15:22:10.626 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/clsh/clsh01.wav
15:22:11.938 -> channels: 1 rate: 44100 bits: 16
15:22:11.938 -> EVENT: Clash ON millis=1189899
15:22:11.938 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/clsh/clsh02.wav
15:22:13.719 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:22:13.719 -> channels: 1 rate: 44100 bits: 16
15:22:13.719 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:22:14.094 -> TWIST
15:22:14.094 -> EVENT: Twist ON millis=1192075
15:22:14.094 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:22:14.140 -> channels: 1 rate: 44100 bits: 16
15:22:14.797 -> No sounds found: pstoff
15:22:14.843 -> Amplifier off.
15:22:15.827 -> Unmounting SD Card.
15:22:15.827 -> Booster off.
15:22:16.296 -> EVENT: Power-Pressed#1 millis=1194269
15:22:16.296 -> EVENT: Power-Pressed millis=1194269
15:22:16.343 -> EVENT: Power-Released#1 millis=1194295
15:22:16.343 -> EVENT: Power-Released millis=1194295
15:22:16.343 -> EVENT: Power-Shortclick#1 millis=1194295
15:22:16.343 -> EVENT: Power-Shortclick millis=1194295
15:22:16.624 -> EVENT: Power-SavedShortclick#1 millis=1194570
15:22:16.624 -> Ignition.
15:22:16.624 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:22:16.624 -> channels: 1 rate: 44100 bits: 16
15:22:16.624 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out05.wav
15:22:16.624 -> humstart: 100
15:22:16.624 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl01.wav
15:22:16.624 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh01.wav
15:22:16.671 -> channels: 1 rate: 44100 bits: 16
15:22:17.702 -> TWIST
15:22:17.702 -> EVENT: Twist ON millis=1195694
15:22:17.702 -> unit = 4 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:22:17.749 -> channels: 1 rate: 44100 bits: 16
15:22:18.405 -> No sounds found: pstoff
15:22:18.452 -> Amplifier off.
15:22:19.436 -> Unmounting SD Card.
15:22:21.732 -> EVENT: Power-Pressed#1 millis=1199712
15:22:21.732 -> EVENT: Power-Pressed millis=1199712
15:22:21.873 -> EVENT: Power-Released#1 millis=1199845
15:22:21.873 -> EVENT: Power-Released millis=1199845
15:22:21.873 -> EVENT: Power-Shortclick#1 millis=1199845
15:22:21.873 -> EVENT: Power-Shortclick millis=1199845
15:22:22.061 -> EVENT: Power-SavedShortclick#1 millis=1200013
15:22:22.061 -> Ignition.
15:22:22.061 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:22:22.061 -> channels: 1 rate: 44100 bits: 16
15:22:22.061 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out01.wav
15:22:22.061 -> humstart: 100
15:22:22.061 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:22:22.061 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:22:22.107 -> channels: 1 rate: 44100 bits: 16
15:22:22.389 -> Battery voltage: 3.58
15:22:23.982 -> TWIST
15:22:23.982 -> EVENT: Twist ON millis=1201943
15:22:23.982 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:22:23.982 -> channels: 1 rate: 44100 bits: 16
15:22:24.685 -> No sounds found: pstoff
15:22:24.685 -> Amplifier off.
15:22:25.669 -> Unmounting SD Card.
15:22:33.120 -> Booster off.
15:22:42.212 -> EVENT: Power-Pressed#1 millis=1220171
15:22:42.212 -> EVENT: Power-Pressed millis=1220171
15:22:42.306 -> EVENT: Power-Released#1 millis=1220272
15:22:42.306 -> EVENT: Power-Released millis=1220272
15:22:42.306 -> EVENT: Power-Shortclick#1 millis=1220272
15:22:42.306 -> EVENT: Power-Shortclick millis=1220272
15:22:42.399 -> Battery voltage: 3.70
15:22:42.493 -> EVENT: Power-SavedShortclick#1 millis=1220472
15:22:42.493 -> Ignition.
15:22:42.540 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:22:42.540 -> channels: 1 rate: 44100 bits: 16
15:22:42.540 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out04.wav
15:22:42.540 -> humstart: 100
15:22:42.540 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:22:42.540 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:22:43.056 -> Playing 02_TPM_Obi/swingl/swingl04.wav
15:22:43.056 -> channels: 1 rate: 44100 bits: 16
15:22:43.056 -> Playing 02_TPM_Obi/swingh/swingh04.wav
15:22:43.852 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl03.wav
15:22:43.852 -> channels: 1 rate: 44100 bits: 16
15:22:43.852 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh03.wav
15:22:43.946 -> TWIST
15:22:43.946 -> EVENT: Twist ON millis=1221902
15:22:43.946 -> unit = 4 vol = 0.50, Playing 02_TPM_Obi/in/in02.wav
15:22:43.946 -> channels: 1 rate: 44100 bits: 16
15:22:44.602 -> No sounds found: pstoff
15:22:44.649 -> Amplifier off.
15:22:45.633 -> Unmounting SD Card.
15:22:53.556 -> Booster off.
15:23:02.405 -> Battery voltage: 3.70
15:23:03.576 -> EVENT: Clash millis=1241548
15:23:03.951 -> Motion disable.
15:23:05.966 -> I2C sleeping..
15:23:09.153 -> EVENT: Power-Pressed#1 millis=1247160
15:23:09.153 -> EVENT: Power-Pressed millis=1247160
15:23:09.294 -> EVENT: Power-Released#1 millis=1247277
15:23:09.294 -> EVENT: Power-Released millis=1247277
15:23:09.294 -> EVENT: Power-Shortclick#1 millis=1247277
15:23:09.294 -> EVENT: Power-Shortclick millis=1247277
15:23:09.481 -> EVENT: Power-SavedShortclick#1 millis=1247464
15:23:09.481 -> unit = 0 vol = 0.50, Playing 02_TPM_Obi/boot/boot03.wav
15:23:09.481 -> channels: 1 rate: 44100 bits: 16
15:23:09.528 -> Motion setup ... I2C init..
15:23:09.622 -> done.
15:23:13.324 -> Amplifier off.
15:23:13.886 -> EVENT: Power-Pressed#1 millis=1251863
15:23:13.886 -> EVENT: Power-Pressed millis=1251863
15:23:13.980 -> EVENT: Power-Released#1 millis=1251981
15:23:13.980 -> EVENT: Power-Released millis=1251981
15:23:13.980 -> EVENT: Power-Shortclick#1 millis=1251982
15:23:13.980 -> EVENT: Power-Shortclick millis=1251982
15:23:14.167 -> EVENT: Power-SavedShortclick#1 millis=1252165
15:23:14.167 -> Ignition.
15:23:14.167 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:23:14.167 -> channels: 1 rate: 44100 bits: 16
15:23:14.214 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out02.wav
15:23:14.214 -> channels: 1 rate: 44100 bits: 16
15:23:14.214 -> humstart: 100
15:23:14.214 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:23:14.214 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:23:16.230 -> TWIST
15:23:16.230 -> EVENT: Twist ON millis=1254234
15:23:16.230 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in02.wav
15:23:16.276 -> channels: 1 rate: 44100 bits: 16
15:23:16.933 -> No sounds found: pstoff
15:23:16.979 -> Amplifier off.
15:23:17.917 -> Unmounting SD Card.
15:23:22.387 -> Battery voltage: 3.70
15:23:25.231 -> Booster off.
15:23:42.383 -> Battery voltage: 3.71
This is everything that came before in case there’s something useful here. I switched straight to the Serial Monitor after uploading 6.4
Activating polyphonic font.
Activating SmoothSwing V2
Accent Swings Enabled.
Polyphonic swings: 16
Monophonic swings: 0
Accent Slashes NOT Detected:
unit = 0 vol = 0.50, Playing 02_TPM_Obi/boot/boot02.wav
I2C init.Welcome to ProffieOS v6.4. Type 'help' for more info.
Battery voltage: 3.92
15:03:26.520 -> EVENT: Power-Pressed#1 millis=64097
15:03:26.520 -> EVENT: Power-Pressed millis=64097
15:03:26.661 -> EVENT: Power-Released#1 millis=64201
15:03:26.661 -> EVENT: Power-Released millis=64201
15:03:26.661 -> EVENT: Power-Shortclick#1 millis=64201
15:03:26.661 -> EVENT: Power-Shortclick millis=64201
15:03:26.848 -> EVENT: Power-SavedShortclick#1 millis=64402
15:03:26.848 -> Ignition.
15:03:26.848 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:03:26.848 -> channels: 1 rate: 44100 bits: 16
15:03:26.895 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out01.wav
15:03:26.895 -> channels: 1 rate: 44100 bits: 16
15:03:26.895 -> humstart: 100
15:03:26.895 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl01.wav
15:03:26.895 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh01.wav
15:03:27.785 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:03:27.785 -> channels: 1 rate: 44100 bits: 16
15:03:27.832 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:03:27.832 -> channels: 1 rate: 44100 bits: 16
15:03:40.860 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:03:40.860 -> channels: 1 rate: 44100 bits: 16
15:03:40.860 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:03:42.454 -> Battery voltage: 3.62
15:03:53.954 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:03:53.954 -> channels: 1 rate: 44100 bits: 16
15:03:53.954 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:04:01.874 -> Playing 02_TPM_Obi/hum.wav
15:04:01.874 -> channels: 1 rate: 44100 bits: 16
15:04:02.437 -> Battery voltage: 3.61
15:04:07.029 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:04:07.029 -> channels: 1 rate: 44100 bits: 16
15:04:07.029 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:04:20.057 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:04:20.057 -> channels: 1 rate: 44100 bits: 16
15:04:20.104 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:04:20.104 -> channels: 1 rate: 44100 bits: 16
15:04:22.448 -> Battery voltage: 3.60
15:04:33.133 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:04:33.133 -> channels: 1 rate: 44100 bits: 16
15:04:33.179 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:04:33.179 -> channels: 1 rate: 44100 bits: 16
15:04:36.928 -> Playing 02_TPM_Obi/hum.wav
15:04:36.928 -> channels: 1 rate: 44100 bits: 16
15:04:42.458 -> Battery voltage: 3.59
15:04:46.208 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:04:46.208 -> channels: 1 rate: 44100 bits: 16
15:04:46.208 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:04:59.287 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:04:59.287 -> channels: 1 rate: 44100 bits: 16
15:04:59.287 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:05:02.474 -> Battery voltage: 3.59
15:05:11.913 -> Playing 02_TPM_Obi/hum.wav
15:05:11.913 -> channels: 1 rate: 44100 bits: 16
15:05:12.334 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:05:12.334 -> channels: 1 rate: 44100 bits: 16
15:05:12.381 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:05:12.381 -> channels: 1 rate: 44100 bits: 16
15:05:22.450 -> Battery voltage: 3.58
15:05:25.416 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:05:25.416 -> channels: 1 rate: 44100 bits: 16
15:05:25.416 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:05:38.475 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:05:38.475 -> channels: 1 rate: 44100 bits: 16
15:05:38.522 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:05:38.522 -> channels: 1 rate: 44100 bits: 16
15:05:42.459 -> Battery voltage: 3.58
15:05:46.958 -> Playing 02_TPM_Obi/hum.wav
15:05:46.958 -> channels: 1 rate: 44100 bits: 16
15:05:51.582 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:05:51.582 -> channels: 1 rate: 44100 bits: 16
15:05:51.582 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:06:02.437 -> Battery voltage: 3.57
15:06:04.639 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:06:04.639 -> channels: 1 rate: 44100 bits: 16
15:06:04.639 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:06:17.714 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:06:17.714 -> channels: 1 rate: 44100 bits: 16
15:06:17.714 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:06:21.979 -> Playing 02_TPM_Obi/hum.wav
15:06:21.979 -> channels: 1 rate: 44100 bits: 16
15:06:22.448 -> Battery voltage: 3.56
15:06:30.768 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:06:30.768 -> channels: 1 rate: 44100 bits: 16
15:06:30.768 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:06:42.484 -> Battery voltage: 3.57
15:06:43.843 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:06:43.843 -> channels: 1 rate: 44100 bits: 16
15:06:43.843 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:06:56.903 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:06:56.903 -> channels: 1 rate: 44100 bits: 16
15:06:56.903 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:06:56.997 -> Playing 02_TPM_Obi/hum.wav
15:06:56.997 -> channels: 1 rate: 44100 bits: 16
15:07:02.433 -> Battery voltage: 3.56
15:07:09.978 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:07:09.978 -> channels: 1 rate: 44100 bits: 16
15:07:09.978 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:07:22.452 -> Battery voltage: 3.56
15:07:23.062 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:07:23.062 -> channels: 1 rate: 44100 bits: 16
15:07:23.062 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:07:32.013 -> Playing 02_TPM_Obi/hum.wav
15:07:32.013 -> channels: 1 rate: 44100 bits: 16
15:07:36.137 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:07:36.137 -> channels: 1 rate: 44100 bits: 16
15:07:36.137 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:07:42.463 -> Battery voltage: 3.56
15:07:49.203 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:07:49.203 -> channels: 1 rate: 44100 bits: 16
15:07:49.203 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:08:02.247 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:08:02.247 -> channels: 1 rate: 44100 bits: 16
15:08:02.294 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:08:02.294 -> channels: 1 rate: 44100 bits: 16
15:08:02.434 -> Battery voltage: 3.56
15:08:07.057 -> Playing 02_TPM_Obi/hum.wav
15:08:07.057 -> channels: 1 rate: 44100 bits: 16
15:08:15.349 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:08:15.349 -> channels: 1 rate: 44100 bits: 16
15:08:15.349 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:08:22.446 -> Battery voltage: 3.56
15:08:28.398 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:08:28.398 -> channels: 1 rate: 44100 bits: 16
15:08:28.398 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:08:41.479 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:08:41.479 -> channels: 1 rate: 44100 bits: 16
15:08:41.479 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:08:42.088 -> Playing 02_TPM_Obi/hum.wav
15:08:42.088 -> channels: 1 rate: 44100 bits: 16
15:08:42.463 -> Battery voltage: 3.55
15:08:54.554 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:08:54.554 -> channels: 1 rate: 44100 bits: 16
15:08:54.554 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:09:02.427 -> Battery voltage: 3.56
15:09:07.660 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:09:07.660 -> channels: 1 rate: 44100 bits: 16
15:09:07.660 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:09:17.068 -> Playing 02_TPM_Obi/hum.wav
15:09:17.068 -> channels: 1 rate: 44100 bits: 16
15:09:20.677 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:09:20.677 -> channels: 1 rate: 44100 bits: 16
15:09:20.677 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:09:22.458 -> Battery voltage: 3.54
15:09:33.752 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:09:33.752 -> channels: 1 rate: 44100 bits: 16
15:09:33.752 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:09:42.469 -> Battery voltage: 3.55
15:09:46.827 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:09:46.827 -> channels: 1 rate: 44100 bits: 16
15:09:46.827 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:09:52.107 -> Playing 02_TPM_Obi/hum.wav
15:09:52.107 -> channels: 1 rate: 44100 bits: 16
15:09:59.911 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:09:59.911 -> channels: 1 rate: 44100 bits: 16
15:09:59.911 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:10:02.442 -> Battery voltage: 3.55
15:10:12.975 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:10:12.975 -> channels: 1 rate: 44100 bits: 16
15:10:12.975 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:10:22.441 -> Battery voltage: 3.54
15:10:26.050 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:10:26.050 -> channels: 1 rate: 44100 bits: 16
15:10:26.050 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:10:27.128 -> Playing 02_TPM_Obi/hum.wav
15:10:27.128 -> channels: 1 rate: 44100 bits: 16
15:10:39.078 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:10:39.078 -> channels: 1 rate: 44100 bits: 16
15:10:39.125 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:10:39.125 -> channels: 1 rate: 44100 bits: 16
15:10:42.450 -> Battery voltage: 3.54
15:10:52.151 -> Playing 02_TPM_Obi/swingl/swingl01.wav
15:10:52.151 -> channels: 1 rate: 44100 bits: 16
15:10:52.198 -> Playing 02_TPM_Obi/swingh/swingh01.wav
15:10:52.198 -> channels: 1 rate: 44100 bits: 16
15:10:57.096 -> TWIST
15:10:57.096 -> EVENT: Twist ON millis=514831
15:10:57.096 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:10:57.096 -> channels: 1 rate: 44100 bits: 16
15:10:57.799 -> No sounds found: pstoff
15:10:57.846 -> Amplifier off.
15:10:58.784 -> Unmounting SD Card.
15:10:59.620 -> EVENT: Swing millis=517360
15:10:59.620 -> Ignition.
15:10:59.667 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:10:59.667 -> channels: 1 rate: 44100 bits: 16
15:10:59.667 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out01.wav
15:10:59.667 -> humstart: 100
15:10:59.667 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:10:59.667 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:11:02.104 -> TWIST
15:11:02.104 -> EVENT: Twist ON millis=519849
15:11:02.104 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:11:02.151 -> channels: 1 rate: 44100 bits: 16
15:11:02.432 -> Battery voltage: 3.50
15:11:02.807 -> No sounds found: pstoff
15:11:02.854 -> Amplifier off.
15:11:03.838 -> Unmounting SD Card.
15:11:03.885 -> EVENT: Swing millis=521613
15:11:03.885 -> Ignition.
15:11:03.885 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:11:03.885 -> channels: 1 rate: 44100 bits: 16
15:11:03.932 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out05.wav
15:11:03.932 -> channels: 1 rate: 44100 bits: 16
15:11:03.932 -> humstart: 100
15:11:03.932 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:11:03.932 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:11:05.244 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:11:05.244 -> channels: 1 rate: 44100 bits: 16
15:11:05.244 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:11:08.712 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:11:08.712 -> channels: 1 rate: 44100 bits: 16
15:11:08.712 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:11:21.512 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:11:21.512 -> channels: 1 rate: 44100 bits: 16
15:11:21.559 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:11:21.559 -> channels: 1 rate: 44100 bits: 16
15:11:22.450 -> Battery voltage: 3.54
15:11:34.353 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:11:34.353 -> channels: 1 rate: 44100 bits: 16
15:11:34.400 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:11:34.400 -> channels: 1 rate: 44100 bits: 16
15:11:38.946 -> Playing 02_TPM_Obi/hum.wav
15:11:38.946 -> channels: 1 rate: 44100 bits: 16
15:11:42.461 -> Battery voltage: 3.53
15:11:47.194 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:11:47.194 -> channels: 1 rate: 44100 bits: 16
15:11:47.241 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:12:00.054 -> channels: 1 rate: 44100 bits: 16
15:12:00.054 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:12:00.054 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:12:02.444 -> Battery voltage: 3.53
15:12:12.894 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:12:12.894 -> channels: 1 rate: 44100 bits: 16
15:12:12.894 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:12:13.925 -> Playing 02_TPM_Obi/hum.wav
15:12:13.925 -> channels: 1 rate: 44100 bits: 16
15:12:22.408 -> Battery voltage: 3.53
15:12:25.735 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:12:25.735 -> channels: 1 rate: 44100 bits: 16
15:12:25.735 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:12:38.576 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:12:38.576 -> channels: 1 rate: 44100 bits: 16
15:12:38.576 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:12:42.419 -> Battery voltage: 3.52
15:12:48.970 -> Playing 02_TPM_Obi/hum.wav
15:12:48.970 -> channels: 1 rate: 44100 bits: 16
15:12:51.401 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:12:51.401 -> channels: 1 rate: 44100 bits: 16
15:12:51.401 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:13:02.441 -> Battery voltage: 3.53
15:13:04.222 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:13:04.222 -> channels: 1 rate: 44100 bits: 16
15:13:04.222 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:13:17.086 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:13:17.086 -> channels: 1 rate: 44100 bits: 16
15:13:17.086 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:13:22.433 -> Battery voltage: 3.52
15:13:23.979 -> Playing 02_TPM_Obi/hum.wav
15:13:23.979 -> channels: 1 rate: 44100 bits: 16
15:13:29.925 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:13:29.925 -> channels: 1 rate: 44100 bits: 16
15:13:29.925 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:13:42.437 -> Battery voltage: 3.52
15:13:42.765 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:13:42.765 -> channels: 1 rate: 44100 bits: 16
15:13:42.765 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:13:46.842 -> EVENT: Swing ON millis=684627
15:13:47.545 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:13:47.545 -> channels: 1 rate: 44100 bits: 16
15:13:47.545 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:13:47.780 -> EVENT: Swing ON millis=685561
15:13:48.670 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:13:48.670 -> channels: 1 rate: 44100 bits: 16
15:13:48.670 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:13:49.748 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:13:49.748 -> channels: 1 rate: 44100 bits: 16
15:13:49.748 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:13:51.056 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:13:51.056 -> channels: 1 rate: 44100 bits: 16
15:13:51.056 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:13:52.087 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl01.wav
15:13:52.087 -> channels: 1 rate: 44100 bits: 16
15:13:52.134 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh01.wav
15:13:52.134 -> channels: 1 rate: 44100 bits: 16
15:13:52.181 -> TWIST
15:13:52.181 -> EVENT: Twist ON millis=689971
15:13:52.181 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:13:52.181 -> channels: 1 rate: 44100 bits: 16
15:13:52.877 -> No sounds found: pstoff
15:13:52.926 -> Amplifier off.
15:13:53.426 -> EVENT: Swing millis=691199
15:13:53.426 -> Ignition.
15:13:53.426 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:13:53.426 -> channels: 1 rate: 44100 bits: 16
15:13:53.426 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out01.wav
15:13:53.426 -> humstart: 100
15:13:53.426 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl01.wav
15:13:53.426 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh01.wav
15:13:53.473 -> channels: 1 rate: 44100 bits: 16
15:13:54.410 -> TWIST
15:13:54.410 -> EVENT: Twist ON millis=692207
15:13:54.410 -> unit = 4 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:13:54.410 -> channels: 1 rate: 44100 bits: 16
15:13:55.113 -> No sounds found: pstoff
15:13:55.160 -> Amplifier off.
15:13:56.144 -> Unmounting SD Card.
15:13:56.472 -> EVENT: Swing millis=694265
15:13:56.472 -> Ignition.
15:13:56.519 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:13:56.519 -> channels: 1 rate: 44100 bits: 16
15:13:56.519 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out03.wav
15:13:56.519 -> humstart: 100
15:13:56.519 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:13:56.519 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:13:57.831 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:13:57.831 -> channels: 1 rate: 44100 bits: 16
15:13:57.831 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:13:57.925 -> Playing 02_TPM_Obi/swingl/swingl04.wav
15:13:57.925 -> channels: 1 rate: 44100 bits: 16
15:13:57.925 -> Playing 02_TPM_Obi/swingh/swingh04.wav
15:13:58.393 -> TWIST
15:13:58.393 -> EVENT: Twist ON millis=696177
15:13:58.393 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:13:58.393 -> channels: 1 rate: 44100 bits: 16
15:13:59.096 -> No sounds found: pstoff
15:13:59.096 -> Amplifier off.
15:13:59.987 -> EVENT: Swing millis=697781
15:13:59.987 -> Ignition.
15:13:59.987 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:13:59.987 -> channels: 1 rate: 44100 bits: 16
15:13:59.987 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out03.wav
15:13:59.987 -> humstart: 100
15:13:59.987 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:14:00.034 -> channels: 1 rate: 44100 bits: 16
15:14:00.034 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:14:01.299 -> EVENT: Power-Pressed#1 ON millis=699098
15:14:01.299 -> EVENT: Power-Pressed ON millis=699099
15:14:01.393 -> EVENT: Power-Released#1 ON millis=699203
15:14:01.393 -> EVENT: Power-Released ON millis=699203
15:14:01.393 -> EVENT: Power-Shortclick#1 ON millis=699203
15:14:01.393 -> EVENT: Power-Shortclick ON millis=699204
15:14:01.627 -> EVENT: Power-SavedShortclick#1 ON millis=699401
15:14:01.627 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/blst/blst04.wav
15:14:01.627 -> channels: 1 rate: 44100 bits: 16
15:14:01.814 -> EVENT: Power-Pressed#1 ON millis=699585
15:14:01.814 -> EVENT: Power-Pressed ON millis=699585
15:14:01.908 -> EVENT: Power-Released#1 ON millis=699721
15:14:01.908 -> EVENT: Power-Released ON millis=699722
15:14:01.908 -> EVENT: Power-Shortclick#1 ON millis=699722
15:14:01.955 -> EVENT: Power-Shortclick ON millis=699722
15:14:02.096 -> EVENT: Power-SavedShortclick#1 ON millis=699894
15:14:02.096 -> unit = 4 vol = 0.50, Playing 02_TPM_Obi/blst/blst02.wav
15:14:02.142 -> channels: 1 rate: 44100 bits: 16
15:14:02.377 -> EVENT: Power-Pressed#1 ON millis=700152
15:14:02.377 -> EVENT: Power-Pressed ON millis=700153
15:14:02.424 -> Battery voltage: 3.51
15:14:02.517 -> EVENT: Power-Released#1 ON millis=700287
15:14:02.517 -> EVENT: Power-Released ON millis=700287
15:14:02.517 -> EVENT: Power-Shortclick#1 ON millis=700287
15:14:02.517 -> EVENT: Power-Shortclick ON millis=700287
15:14:02.658 -> EVENT: Power-SavedShortclick#1 ON millis=700472
15:14:02.658 -> unit = 5 vol = 0.50, Playing 02_TPM_Obi/blst/blst01.wav
15:14:02.705 -> channels: 1 rate: 44100 bits: 16
15:14:02.892 -> EVENT: Power-Pressed#1 ON millis=700700
15:14:02.892 -> EVENT: Power-Pressed ON millis=700701
15:14:03.033 -> EVENT: Power-Released#1 ON millis=700834
15:14:03.033 -> EVENT: Power-Released ON millis=700834
15:14:03.033 -> EVENT: Power-Shortclick#1 ON millis=700834
15:14:03.033 -> EVENT: Power-Shortclick ON millis=700834
15:14:03.220 -> EVENT: Power-SavedShortclick#1 ON millis=701007
15:14:03.220 -> unit = 6 vol = 0.50, Playing 02_TPM_Obi/blst/blst05.wav
15:14:03.220 -> channels: 1 rate: 44100 bits: 16
15:14:03.689 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl04.wav
15:14:03.689 -> channels: 1 rate: 44100 bits: 16
15:14:03.689 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh04.wav
15:14:04.345 -> TWIST
15:14:04.345 -> EVENT: Twist ON millis=702157
15:14:04.345 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:14:04.392 -> channels: 1 rate: 44100 bits: 16
15:14:05.048 -> No sounds found: pstoff
15:14:05.095 -> Amplifier off.
15:14:05.470 -> EVENT: Swing millis=703235
15:14:05.470 -> Ignition.
15:14:05.470 -> unit = 0 vol = 0.00, Playing 02_TPM_Obi/hum.wav
15:14:05.470 -> channels: 1 rate: 44100 bits: 16
15:14:05.470 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/out/out03.wav
15:14:05.470 -> humstart: 100
15:14:05.470 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl01.wav
15:14:05.470 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh01.wav
15:14:07.438 -> unit = 2 vol = 0.00, Playing 02_TPM_Obi/swingl/swingl02.wav
15:14:07.438 -> channels: 1 rate: 44100 bits: 16
15:14:07.438 -> unit = 3 vol = 0.00, Playing 02_TPM_Obi/swingh/swingh02.wav
15:14:07.625 -> EVENT: Swing ON millis=705433
15:14:08.141 -> EVENT: Swing ON millis=705928
15:14:08.375 -> Playing 02_TPM_Obi/swingl/swingl02.wav
15:14:08.375 -> channels: 1 rate: 44100 bits: 16
15:14:08.375 -> Playing 02_TPM_Obi/swingh/swingh02.wav
15:14:08.750 -> EVENT: Swing ON millis=706513
15:14:09.641 -> TWIST
15:14:09.641 -> EVENT: Twist ON millis=707425
15:14:09.641 -> unit = 1 vol = 0.50, Playing 02_TPM_Obi/in/in01.wav
15:14:09.641 -> channels: 1 rate: 44100 bits: 16
15:14:10.344 -> No sounds found: pstoff
15:14:10.344 -> Amplifier off.
15:14:11.328 -> Unmounting SD Card.
@profezzorn any ideas? I can’t see any reason Swing would just stop being detected before the motion times out and can’t replicate.
And also the fact that my motion timeout is 5 mins, not 1 second
The config you posted earlier has a 15 minute MOTION_TIMEOUT unless you changed.
But that’s not showing up, when the motion times out you’ll see this in the Serial Monitor
And when it wakes back up you’ll see this:
That’s not showing in those “gaps” so your motion is not actually timed out and if there’s no readout for any motion or anything else for that matter something else is going or (or not working).
Sorry, yes, 15. I just meant it had been less than 1 second since my last motion event till the time of the Motion disable
Maybe just double check you’re actually uploading the config you noted and double check the MOTION_TIMEOUT define. I usually just add a small typo to a style so you get an error, then fix and upload. Otherwise I’m not sure.
Double checked. Looks like I did send you the one I had for 6.3. But I didn’t change anything for 6.4
#define NUM_BUTTONS 1
#define VOLUME 1000
//Maximum Volume Level
//Maximum Number of Pixels in a Strip
#define CLASH_THRESHOLD_G 2.0
//Minimum amount of force required to trigger a clash (Default: 2.0)
#define ENABLE_SERIAL
//Enables necessary board functions
//Saves board memory. Comment out this line to troubleshoot with Serial Monitor
#define SAVE_STATE
//Ensures that sounds do not play back-to-back
#define EXTRA_COLOR_BUFFER_SPACE 64
//Boosts processing time
#define FILTER_CUTOFF_FREQUENCY 150
//Enables High Pass Filter to cut off frequencies below set number (Number represents frequency in Hz)
#define FILTER_ORDER 8
//Determines how sharp the cutoff is between filtered frequences and unfiltered frequencies (Must be an even number between 2 and 16. Default: 8)
//Adjustable Defines
//After motion timeout, short click PWR will wake motion controls and boot.wav will play
#define FETT263_SAVE_CHOREOGRAPHY
//Enables Enhanced Battle Mode with Saved Choreography
//Enables odd/even out.wav ignition sound selection based on blade angle
//Up = odd number sounds, Down = even numbered sounds
//Enables selection of clash, stab and lockup sounds based on clash strength
//Light clash = 01.wav, Hard clash = highest number.wav
#define FETT263_MAX_CLASH 16
//The value for hardest clash level to select clash sound
//Range 8 ~ 16
//Spoken Color Names replace default sounds during Color List Mode (requires .wav files)
//Spoken Color Names replace default sounds during Color Change "CC" Color List Mode (requires .wav files)
//#define FETT263_SAY_BATTERY_VOLTS
//Spoken Battery Level as volts during On Demand Battery Level effect (requires .wav files)
//Spoken Battery Level as percent during On Demand Battery Level effect (requires .wav files)
//== BATTLE MODE OPTIONS ==
//Battle Mode is enabled via controls by default in this prop, you can customize further with these defines
//#define FETT263_BATTLE_MODE_ALWAYS_ON
//Battle Mode is always on, toggle controls deactivated
//This will disable traditional Clash and Stab effects (cannot be used with FETT263_BATTLE_MODE_START_ON)
//#define FETT263_BATTLE_MODE_START_ON
//Battle Mode is active with each ignition by default but can be toggled using Aux + Swing control
//(cannot be used with FETT263_BATTLE_MODE_ALWAYS_ON)
//This is the "delay" in millis to determine Clash vs Lockup
//The max value to use clashes in Battle Mode 2.0, clashes used on clash strength below this value
//This allows light clashes to produce clash effects instead of using Begin/End Lockup
//(above this value Clash is performed by quick pull away using Begin/End Lockup sounds and effect)
//Range 0 ~ 8 (note 0 will use Battle Mode 1.0 with all clashes being Begin/End Lockup)
//#define FETT263_BM_DISABLE_OFF_BUTTON
//During Battle Mode Power Button Retraction is disabled
//== Swing On ==
//Gesture Ignition via Swing
//You can use one of the following defines to enable swing on:
#define FETT263_SWING_ON
//To enable Swing On Ignition control (automatically enters Battle Mode, uses Fast On)
//#define FETT263_SWING_ON_PREON
//Disables Fast On ignition for Swing On so Preon is used (cannot be used with FETT263_SWING_ON)
//#define FETT263_SWING_ON_NO_BM
//To enable Swing On Ignition control but not activate Battle Mode
//(Combine with FETT263_SWING_ON or FETT263_SWING_ON_PREON,
//cannot be used with FETT263_BATTLE_MODE_ALWAYS_ON or FETT263_BATTLE_MODE_START_ON)
//Adjust Swing Speed required for Ignition 250 ~ 500 recommended
//== Twist Off ==
//Gesture Retraction via Twist (back and forth)
//To enable Twist Off Retraction control
//== Twist On ==
//Gesture Ignition via Twist (back and forth)
//You can use one of the following defines to enable twist on:
#define FETT263_TWIST_ON
//To enable Twist On Ignition control (automatically enters Battle Mode, uses Fast On)
//#define FETT263_TWIST_ON_PREON
//Disables Fast On ignition for Twist On so Preon is used (cannot be used with FETT263_TWIST_ON)
//#FETT263_TWIST_ON_NO_BM - To enable Twist On Ignition control but not activate Battle Mode
//(Combine with FETT263_TWIST_ON or FETT263_TWIST_ON_PREON,
//== Stab On ==
//Gesture Ignition via Stab (linear movement + clash at tip of blade)
//You can use one of the following defines to enable stab on:
#define FETT263_STAB_ON
//To enable Stab On Ignition control (automatically enters Battle Mode, uses Fast On)
//#define FETT263_STAB_ON_PREON
//Disables Fast On ignition for Stab On so Preon is used (cannot be used with FETT263_STAB_ON)
//#define FETT263_STAB_ON_NO_BM
//To enable Stab On Ignition control but not activate Battle Mode
//(Combine with FETT263_STAB_ON or FETT263_STAB_ON_PREON,
//== Thrust On ==
//Gesture Ignition via Thrust (linear movement)
//You can use one of the following defines to enable thrust on:
#define FETT263_THRUST_ON
//To enable Thrust On Ignition control (automatically enters Battle Mode, uses Fast On)
//#define FETT263_THRUST_ON_PREON
//Disables Fast On ignition for Thrust On so Preon is used (cannot be used with FETT263_THRUST_ON)
//#define FETT263_THRUST_ON_NO_BM
//To enable Thrust On Ignition control but not activate Battle Mode
//(Combine with FETT263_THRUST_ON or FETT263_THRUST_ON_PREON,
//== Gesture Sleep ==
//Toggle Gesture Ignition and Retraction detection to disable or enable gesture options
//#define FETT263_SAVE_GESTURE_OFF
//Save "Gesture Sleep" setting to turn gesture ignitions and retractions off on boot
//== Force Push ==
//Push movement triggers push.wav (or force.wav if push.wav is not present)
//You can use one of the following defines to enable force push:
#define FETT263_FORCE_PUSH
//To enable gesture controlled Force Push during Battle Mode
//(will use push.wav or force.wav if not present)
//#define FETT263_FORCE_PUSH_ALWAYS_ON
//To enable gesture controlled Force Push full time
//Allows for adjustment to Push gesture length in millis needed to trigger Force Push
//Recommended range 1 ~ 10, 1 = shortest, easiest to trigger, 10 = longest
#define FETT263_MULTI_PHASE
//This will enable a preset change while ON to create a "Multi-Phase" saber effect
//This extends the motion timeout to 15 minutes to allow gesture ignition to remain active
//Increase/decrease the "15" value as needed
#define COLORWHEEL_ZOOM
//This will enable "Zoom" mode in ColorWheel (does not apply to Color Change using Color List for Edit Mode styles)
//#define FETT263_QUOTE_PLAYER_START_ON
//This will set Force / Quote Player to play Quote by default (if in font)
You might be able to replicate if you change your motion timeout to 1 minute. I just did. (With MOTION_WAKE_POWER_BUTTON of course)
Ignite saber and leave idle for more than one minute.
Retract saber.
Swing on will not work.
Leave idle for a few moments.
Motion will disable.
Press PWR and motion will boot up and boot.wav will play.
Swing on will work again
That’s odd, it’s something with MotionRequested() isn’t working right.
TBH I stuck the FETT263_WAKE_POWER_BUTTON define in per a request but it’s not something I use and I simply don’t have time to mess with it so for the time being just don’t use it. If you need your motion to last longer just increase the MOTION_TIMEOUT. This define is proving to be too much of a PITA in my opinion, I’ll probably just revert it for the next update.
The current fix for it is not to use it IMO.
I agree, and I kinda expected that would be the answer. I don’t really need it either. I just had noticed odd behavior since enabling. Thanks for bearing with me on it!
Yeah, I think it’s causing more problems then it solved. They can’t all be winners.
My guess is that you missed setting saber_off_time_millis_ somewhere.
That would make it stop detecting swings.
That might be it, looks like Twist Off was missing the reset which might explain. When MOTION_TIMEOUT was set to a really low number it became prevalent so I’m also defaulting saber_off_time_millis_ to 2100 so we get passed the motion initialization and swing on delay. Thanks for the added set of eyes. If it proves out I’ll submit.
@Jakmar can you test this branch out to see if it fixes for you both at low MOTION_TIMEOUT value and normal use, I won’t have time tonight.
That seems to be working! I tried out both short and normal timeout lengths. I’ll continue using the normal length to see if anything pops up. It has the 2 second delay now which it didn’t before.
Do you mean on boot? There’s always been a 2 second delay for swing detection.
No, I mean after retraction. Until you made the change that you made, there wasn’t a 2 second delay for swing on after retraction. (At least after twist off in 6.3 and 6.4. I never really thought about it before that)
Ok, yes twist off was missing the reset on timer. There is a 2 second delay for swing ignition on boot, retraction or motion restart. This is needed to prevent false ignitions when the motion chip is initializing. If you need to ignite less than 2 seconds after retraction use button press.
