ProffieOS 8.4 beta (call for testers!)
Well, I copy pasted a basic style and manually entered every color on the new colors list. Two blades/colors per preset. I misspelled Raspberry (the p is silent? or I have an accent? really even after all the Raspberry Pi stuff?) the error code made me laugh with the “did you mean…” statement but it very quickly allowed for the correction. Nice touch!
So yeah, every color is working and it was fun to see them all. Some beautiful variations.
I’ll do menus next (maybe last), but need to set up the config to test all of the functions.
It can be hard to settle on colors, so thanks for this it was worth it!
Excellent, thank you!
Trying out the menu system.
Using the base saber.h prop.
With
#define MENU_SPEC_TEMPLATE DefaultMenuSpec
The menu flow starts:
EDIT VOLUME /EDIT PRESETS
select EDIT PRESETS
and so on into many menus I don’t personally prefer, but there’s a lot you can do.
I use the Fett263 style settings only menu regularly, so I replaced the above define with:
#define MENU_SPEC_TEMPLATE SettingsOnlyMenuSpec
But i’m getting a full menu just as before with with original define. I was expecting to enter the setting menu with an AUX double tap and get things like brightness, volume, etc only without being able to move presets or copy paste etc.
What options should I have access to when using SettingsOnlyMenuSpec?
The Settings menu has 5 possible entries:
  • volume
  • sd access
  • blade length
  • clash threshold
  • blade dimming
Each of these settings require some define to enable though.
It would seem that you don’t have any of those defines, which is why the settings menu just gets reduced to “Edit volume”, and gets inlined into the top menu.
You don’t have to like it to test it. :slight_smile:
This is super weird to me, and doesn’t seem possible.
Can you post your config file?
Here’s my test config:
#define NUM_BLADES 2
#define VOLUME 1250
#define CLASH_THRESHOLD_G 1
//#define ENABLE_AUDIO
//#define ENABLE_MOTION
//#define ENABLE_WS2811
//#define ENABLE_SD
#define KILL_OLD_PLAYERS
#define FILTER_ORDER 8
#define DISABLE_TALKIE
#define SMOOTH_COLORCHANGE_TICKS_PER_REVOLUTION 60
#define BC_SWING_ON
//#define MENU_SPEC_TEMPLATE DefaultMenuSpec
#define CLASH_THRESHOLD_GAMMA 2.0
#define COLOR_MENU_GAMMA 2.2
#define ENABLE_SPINS
#include "../props/saber.h"
{"Ronin;common", "common/tracks/Ronin.wav",
https://fett263library.com/early-access/#Rotoscope
OS7.14 v3.01p
Style Option
Base Color: BaseColorArg (0)
Lockup Effect:
[Color: LockupColorArg]
Lightning Block Effect:
[Color: LBColorArg]
Drag Effect:
[Color: DragColorArg]
Melt Effect:
[Color: StabColorArg]
StylePtr<Layers<Mix<HoldPeakF<SwingSpeed<250>,Scale<SwingAcceleration<100>,Int<50>,Int<500>>,Scale<SwingAcceleration<>,Int<20000>,Int<10000>>>,RandomFlicker<StripesX<Int<15000>,Scale<HoldPeakF<SwingSpeed<200>,Scale<SwingAcceleration<100>,Int<50>,Int<300>>,Scale<SwingAcceleration<100>,Int<24000>,Int<16000>>>,Int<-3200>,Int<-200>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<7710>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>,Mix<Int<19276>,Black,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,RgbArg<BASE_COLOR_ARG,Rgb<0,0,255>>>,TransitionEffectL<TrWaveX<RgbArg<BLAST_COLOR_ARG,Rgb<255,255,255>>,Scale<EffectRandomF<EFFECT_BLAST>,Int<100>,Int<400>>,Int<100>,Scale<EffectPosition<EFFECT_BLAST>,Int<100>,Int<400>>,Scale<EffectPosition<EFFECT_BLAST>,Int<28000>,Int<8000>>>,EFFECT_BLAST>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,TransitionEffectL<TrConcat<TrInstant,AlphaL<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<12000>,Int<60000>>>>,TrFadeX<Scale<ClashImpactF<>,Int<200>,Int<400>>>>,EFFECT_CLASH>,TransitionEffectL<TrWaveX<RgbArg<CLASH_COLOR_ARG,Rgb<255,255,255>>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Int<100>,Scale<ClashImpactF<>,Int<100>,Int<400>>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>>,EFFECT_CLASH>>,LockupTrL<TransitionEffect<AlphaL<AlphaMixL<Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>,AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,BrownNoiseFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<12000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>,300>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<22000>>>>,AlphaL<AudioFlicker<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Mix<Int<20000>,Black,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,TrExtend<5000,TrInstant>,TrFade<5000>,EFFECT_LOCKUP_BEGIN>,TrConcat<TrJoin<TrDelay<50>,TrInstant>,Mix<IsLessThan<ClashImpactF<>,Int<26000>>,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,AlphaL<RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-10000>>>,Scale<ClashImpactF<>,Int<20000>,Int<60000>>>>>,TrFade<300>>,TrConcat<TrInstant,RgbArg<LOCKUP_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,SaberBase::LOCKUP_NORMAL,Int<1>>,ResponsiveLightningBlockL<Strobe<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,AudioFlicker<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Blue>,50,1>,TrConcat<TrExtend<200,TrInstant>,AlphaL<RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,Bump<Scale<BladeAngle<>,Int<10000>,Int<21000>>,Int<10000>>>,TrFade<200>>,TrConcat<TrInstant,RgbArg<LB_COLOR_ARG,Rgb<255,255,255>>,TrFade<400>>,Int<1>>,LockupTrL<AlphaL<TransitionEffect<RandomPerLEDFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>>,BrownNoiseFlickerL<RgbArg<DRAG_COLOR_ARG,Rgb<255,255,255>>,Int<300>>,TrExtend<4000,TrInstant>,TrFade<4000>,EFFECT_DRAG_BEGIN>,SmoothStep<Scale<TwistAngle<>,IntArg<DRAG_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrWipeIn<200>,TrWipe<200>,SaberBase::LOCKUP_DRAG,Int<1>>,LockupTrL<AlphaL<Stripes<2000,4000,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,Mix<Sin<Int<50>>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,Mix<Int<4096>,Black,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrConcat<TrExtend<4000,TrWipeIn<200>>,AlphaL<HumpFlicker<Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>,RotateColorsX<Int<3000>,Mix<TwistAngle<>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>,RotateColorsX<Int<3000>,RgbArg<STAB_COLOR_ARG,Rgb<255,68,0>>>>>,100>,SmoothStep<Scale<TwistAngle<>,IntArg<MELT_SIZE_ARG,28000>,Int<30000>>,Int<3000>>>,TrFade<4000>>,TrWipe<200>,SaberBase::LOCKUP_MELT,Int<1>>,InOutTrL<TrWipeX<BendTimePowInvX<IgnitionTime<300>,Mult<IntArg<IGNITION_OPTION2_ARG,10992>,Int<98304>>>>,TrWipeInX<BendTimePowX<RetractionTime<0>,Mult<IntArg<RETRACTION_OPTION2_ARG,10992>,Int<98304>>>>,Black>>>(),
OS7.14 v3.01p
Style Option
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
"Ronin"},
{"AstralP;common", "common/tracks/x.wav",
StylePtr<Layers<
  BrainFreeze,
  ResponsiveLockupL<Ivory,TrInstant,TrFade<100>,Int<26000>>,
  ResponsiveLightningBlockL<Ivory>,
  ResponsiveMeltL<Mix<TwistAngle<>,Red,Yellow>>,
  ResponsiveDragL<Ivory>,
  ResponsiveClashL<Ivory,TrInstant,TrFade<200>,Int<26000>>,
  ResponsiveBlastL<Ivory>,
  ResponsiveBlastWaveL<Ivory>,
  ResponsiveBlastFadeL<Ivory>,
  ResponsiveStabL<Ivory>,
  InOutTrL<TrWipe<300>,TrWipeIn<500>>>>(),
  StylePtr<Layers<
  BrutalPink,
"AstralP"},
{"Celsius;common", "common/tracks/SailorMoon.wav",
StylePtr<Layers<
  BusyBee,
  StylePtr<Layers<
  VibrantMint,
"Celsius"},
 { 0, WS281XBladePtr<125, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(),
    WS281XBladePtr<14, blade4Pin, Color8::GRB, PowerPINS<bladePowerPin6> >()
  , CONFIGARRAY(presets) },
Currently testing the new serial commands.
Trying out the new serial monitor commands related to sound playback:
quote - plays quote.wav
swing - plays swng.wav
slash - plays slsh.wav
spin - I have #define ENABLE_SPINS but get
Whut? :spin
When entering spin in the command line.
Also, the exact naming convention is missing from the POD list of Names and Effects, so I guessed spin.wav (or I missed it?).
Before shutting down the lab for the day I did another upload of the same config. I had double checked before reporting what I thought was odd menu behavior with at least 2 upload/testing cycles, and was getting the full menu selection as I described with SettingsOnlyMenuSpec.
On this final try, when entering the menu system in the saber I only get EDIT VOLUME and no longer hear EDIT PRESETS (which I expected considering your last reply).
What defines (is there a list in the POD?) are needed to get the Settings menu running? More later in the week unless there’s something you’d like me to try now.
Are you sure you’re uploading the right config file?
I tried your config file, and “spin” works for me.
(Well, I didn’t have any spin sounds, so it says:
No sounds found: spin
But it definitely tried.
The defines are listed on the pod, but I should probably make it more explicit.
The defines you want are these:
#define MOUNT_SD_SETTING
I should probably update ENABLE_ALL_EDIT_OPTIONS to include MOUNT_SD_SETTING…
OK, with this config, for sure:
#define VOLUME 1250
//#define ENABLE_SD
#define BC_SWING_ON
OS7.14 v3.01p
Style Option
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
OS7.14 v3.01p
Style Option
Lockup Effect:
[Color: LBColorArg]
Drag Effect:
Melt Effect:
"Ronin"},
StylePtr<Layers<
  BrainFreeze,
  StylePtr<Layers<
  BrutalPink,
"AstralP"},
StylePtr<Layers<
  BusyBee,
  StylePtr<Layers<
  VibrantMint,
"Celsius"},
Entering the settings menu I get:
Edit Volume - normal function
Edit Brightness - normal function
Edit Clash Threshhold - normal function
Edit Blade Length - normal function
but no sd access that I can detect. Maybe I am looking for the wrong thing, or the voicepack (Vader V2) doesn’t include sd access?
I am never sure at this point :stuck_out_tongue_winking_eye: . So I closed everything out and opened ProffieOS from a clean desktop prior to this upload.
In the serial monitor:
spin - plays spin.wav (verified, sorry about that)
sd, sd1,sd2 - getting “whut” feed back, even with #define MOUNT_SD_SETTING
added as suggested in the last post (as seen in the config above)
I forgot to mention that the sd access menu also requires that you program with mass storage enabled. No mass storage - no sd access - no sd access menu. This also affects the “sd” command.
Ah, I see that info in NoSloppy’s post about it. Ok, I fix that and check it tomorrow. Thanks for the hand holding!
Finding these things is really what testing is all about.
That way I can document things better, and maybe the next person will have an easier time. :slight_smile:
ProffieOS 8.x is now in beta, and ProffieOS 8.0 zip file is available in the top post.
Is the 4.6 plugin required for 8.x?
No, but it is highly recommended, because some code (in particular, the color display code) has triggered compiler bugs which makes the compiler generate broken code, so far I have not seen that with 4.6.
OK. Not likely to need colour display stuff any time soon, and 4.6 is unusable due to the extra file size on compile.
This might be the point at which v2 is obsolete for some people…
The V2 was getting pretty “cozy” for a lot of people even before this.
Just beware that if someone comes to me and complains about something not working, I will almost certainly require them to try 4.6 before I take it seriously.
Fair dos. I tried trimming the config but it stripped out nearly half of what I had.
One question:
Is BlackPower now part of the OS (for blade plug charging)?
Previously I’ve had to add the code below to the config. Just wondering if that’s still necessary with OS-8?
#ifdef CONFIG_STYLES
class BlackPower {
  public:
    LayerRunResult run(BladeBase* base) {
      return LayerRunResult::UNKNOWN;
    SimpleColor getColor(int led) {
      return SimpleColor(Color16(0,0,0));
