I love those ideas!
Ok, I made a ProffieOS v7.7 zip.
It’s the same as 7.6, plus these bugfixes:
- Added a #warning when using KEEP_SAVEFILES_WHEN_PROGRAMMING
- Fett263 prop: Disable EVENT_PUSH when in menu
- Fett263 prop: Default edit color to red if not found
- Fett263 prop: Fix some clash/blast issues
- fix some spelling in comments
- Add description strings for new style arguments
As usual, the link can be found in the top post.
On a related note, testing is progressing 95 out of 181 things listed in the top post are now tested (or listed as not needed testing.)
The following were all tested by me when implemented and nothing’s changed to them since, so they are tested:
- Bendable time in most transitions
- Most OLED images can now use the length of the corresponding wav to decide how long to show the image or animation.
- All config.ini files in the font search path are now read.
(Tested by myself as well as @Sabersense ) - TrConcat can now be used without putting colors between transitions.
- POV_INCLUDE_FILE
- StylePOV
- ContinuousPOV
New pairable sound transitions
lock → endlock
armhum → endarm
auto → endauto
lb → endlb
melt → endmelt
drag → enddrag
EFFECT_BATTERY_LEVEL
EFFECT_VOLUME_LEVEL
EFFECT_POWERSAVE
EFFECT_QUOTE
EFFECT_ALT_SOUND
EFFECT_FAST_ON
BC prop (whole section)
Did you test these with the fett263 prop?
That’s a negative Ghost Rider.
This has been in my prop since OS5
Agreed, not sure why it’s in the to-be-tested list.
Is there a demo style or example code for the new Effects and/or special abilities? I’d test those, but I’m not sure how
I’m working on the UI for the OS7 library that will make these possible, until then not sure there’s much to test unless you build your own.
So, I think maybe ProffieOS 7 has been tested enough.
I’ve been going through the remaining items, and there really isn’t a lot left, and I assume that the items left really have been tested by somone.
I’m probably going to make ProffieOS 7.x the official ProffieOS tomorrow unless someone gives me a reason not to…
I’ve used and tested everything in my prop and nearly everything else with the exception of OLED stuff or other props. I think we’re pretty well tested by this point.
ive been running os7 for months, no issues.
Same. No issues.
I’ve been using OS7.x with Matthew’s SA22C prop without issues, and I think between Brian and me (more Brian), the OLED mods have also been pretty comprehensively tested.
I’ve installed it on five hilts and are all working nicely. OLED does works pretty well in them, too. So I don’t see a reason not to go with a release.
*Confirming zero issues w OS7.7 in BC and Fett props in all 7 hilts here.
@Fett263 OLED in your prop works fine as does the flip and Aurebesh functions. I probably shoulda/coulda chimed in on that a few weeks back but was busy w life.
Thanks, OLED isn’t tied to a specific prop, but appreciate it.
Ive been using OS7 for a month+
