The SW pad goes to the switch. Any switch will work, as long as it connects to ground when you want the saber to be on. (So if you connected to the middle pin of the switch, then one of the other pins should connect to GND or BATT-)
Hi Fredrik,
Any chance I could get a parts list for the helper pcb regarding the switches, slide switch and USB port?
All the links located on your proffie site just redirect me back to the same page for the control box helper pcb. Thank you in advance
This page worked for me…
https://fredrik.hubbe.net/lightsaber/v6/test_rig_breakout.html
It has the bom link.
Looks like this is for the test bench and not the control box helper pcb used in his 89sabers k4 install
Indeed, the links are broken.
The kicad files have the product info in them.
Pcb design software is a skill that I haven’t quite picked up yet but I was able to fumble my way through.
For anyone else needing these part numbers these should be the right ones. The mosfet/ diode is the same one used in the ever popular 7 chambers MoM Hero v4 helper boards and has increased Amp output of 5.9A as well as a smaller voltage threshold of 1V.
Switches for Button1 and Button2
EVQ-PUL02K
https://www.mouser.com/ProductDetail/Panasonic/EVQ-PUL02K?qs=m7HfDvvzlLb0VFxnw%2FUN1w%3D%3D
Micro USB port
10103594-0001LF
https://www.mouser.com/ProductDetail/Amphenol-FCI/10103594-0001LF?qs=EnLMdcWnKABYZwdMsmC%2Fag%3D%3D
Slide switch
PCM12SMTR
https://www.mouser.com/ProductDetail/CK/PCM12SMTR?qs=mfFuHy8STfL3qrPSfCHA7w%3D%3D
Mosfet/ schottky diode
SI2365EDS-T1-BE3
https://www.mouser.com/ProductDetail/Vishay-Siliconix/SI2365EDS-T1-BE3?qs=CiayqK2gdcIlOn6UKguzwg%3D%3D&countryCode=GB¤cyCode=GBP
