Proffieboard v3.9 5v/Bat+ PIN problem
Ok, I not understand the correct use of the of status led. The instructions says how to drive the status led like a Blade, but I Need to move the status led tò.another Place visibile during charge.
Is possibile?
@profezzorn, if I read this correctly, I think I’ve wondered the same thing.
I know we can give the onboard status LED a custom blade style, but is it possible to do the inverse, where we could have the default behavior of the status LED show on another blade ( an accent LED )?
You would have to replicate what the status led does as a style.
Most of it is pretty simple, but maybe not all of it:
for the damaged board i requested a replacement from the seller aksaber on AliExpress. the refund was quick and the replacement is already on its way.
for the led status i decided to use the voice and the visual check on the blade rather than replicate the led status behavior in a style.
