Hello, looking for some advice or feedback regarding diagnosing an issue I’ve had with a second hand proffieboard I picked up some years ago.
the Saber was given to me with a known battery draining issue but otherwise worked fine, however soon refused to turn on with the STM32 chip growing warm rapidly with battery power or usb power.
I’m aware of a component potentially being shorted or damaged but I am unaware of what one to go after here.
So far I’ve looked at all fuses to check for shorts, none are present that I can find.
My thoughts are either the connected mosfets are bad, or the D61 diode is out, from the research I’ve managed to find anyway.
I have a spare board on hand in case this one is dead, but I’d prefer fixing the one I have, mainly for fun but also because this one has some font styles I really enjoy that have been lost to time. At least the config for them anyway.
If the chip is getting too warm to touch and is no longer functioning, it’s dead. There’s nothing you can practically do to fix it. Even if the original fault is still present (which you can’t really test for once you have damaged components in the mix), removing it won’t help once things have already been damaged.
As a theory, possibly something was shorted, wired incorrectly, etc. which damaged the chip. It may have only damaged some certain part of it, but over time these kinds of things tend to spread and get worse, more things get shorted from the heat of the short the original damage (presumably) caused, and so forth.
The only advice would to reinstall things with another board. And take care that you’re connecting wires to the right places, and that things which aren’t intended to be shorted are not.
Also, I’ll add to make sure that the “generic”/GPIO pads on the board (data pins, the “free” pads, buttons, tx/rx, etc. which you might connect accent LEDs or something to) aren’t sourcing or sinking too much current. That can damage the chip also, and is a common cause w/ mcus dying slowly over time.
Generally, when the main CPU gets warm or hot, chances are slim that the problem can be fixed. However, it is sometimes possible that there is a short on one of the CPU pins, and fixing/removing the short fixes the problem. It is unusual though, once the CPU gets hot enough it’s usually busted.
Thanks for the replies, I’ll still give it a chance and hopefully see it’s revival, if not I’ll just consider it done and swap the other board out with my spare.
My fault for not looking into the issue prior to getting to it but it is what it is. You live and learn.
