When I connect my board to my PC in ProffieOS, it shows as only a USB Composite Device, no serial device. The composite device is unable to start with error code 10.
BOOT+RESET into bootloader, STM32 Bootloader is recognized, no errors.
Running the Arduino config with the correct parameters results in a port busy error.
But the port that is busy is COM1 which is the only com port available, and definitely isn’t the proffie board.
This is either in bootloader or ProffieOS mode.
processing.app.debug.RunnerException
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:152)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2071)
at java.lang.Thread.run(Thread.java:748)
Caused by: processing.app.SerialException: Error touching serial port 'COM1'.
at processing.app.Serial.touchForCDCReset(Serial.java:107)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:136)
... 5 more
Caused by: jssc.SerialPortException: Port name - COM1; Method name - openPort(); Exception type - Port busy.
at jssc.SerialPort.openPort(SerialPort.java:164)
at processing.app.Serial.touchForCDCReset(Serial.java:101)
... 6 more
