Proffie V3 motion chip trying to reboot
Hi, Trying out the new Proffie V3 I’ve wired up everything and am trying to add a crystal chamber with the main blade. Ive tried different setups sometimes getting both sets of Led’s to light. The sound is pretty bad and barely audible ( I’ve tried 2 working speakers).
Serial Monitor just repeats:
Motion chip timeout, trying auto-reboot of motion chip! Motion chip … Battery voltage: 0.02
Hopefully I haven’t damaged the board :crossed_fingers:t2:
#define NUM_BLADES 2
#define VOLUME 2000
#define CLASH_THRESHOLD_G 3.0
#define ENABLE_SERIAL
#define MOTION_TIMEOUT 60 * 15 * 1000 // keeps motion chip active for 15 minutes while blade is Off
#define FETT263_THRUST_ON // enables Thrust On Ignition
#define FETT263_SWING_ON // enables Swing On Ignition
#define FETT263_TWIST_ON // enables Twist On Ignition
#define FETT263_TWIST_OFF // enables Twist Off Retraction
#define MOTION_TIMEOUT 60 * 10 * 1000 // keeps motion chip active for 15 minutes while blade is Off
#define FETT263_SAY_BATTERY_VOLTS
#define FETT263_COLORWHEEL_ZOOM
#include"../props/saber_fett263_buttons.h"
{ "Decay;common", "Decay/tracks/decay.wav",
StylePtr<Layers<
  StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
  //Bright purple absorb effect
  //StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,0,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,
  //Alternate darker purple absorb effect, color change friendly (for reds and such)
  AlphaL<BrownNoiseFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black,300>,SwingSpeed<400>>,
  //Unstable swing
  AlphaL<Stripes<1000,2000,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<95,0,210>>,Black>,Black,RotateColorsX<Variation,Rgb<95,0,210>>,Black>,SwingSpeed<500>>,
  //Ripple down swing
  AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,Scale<IsLessThan<SwingSpeed<600>,Int<13600>>,Scale<SwingSpeed<600>,Int<-19300>,Int<32768>>,Int<0>>>,
  //Bright hard swings
  LockupTrL<Layers<
	AlphaL<AudioFlickerL<Azure>,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>,
	AlphaL<White,Bump<Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>,Int<10000>>>>,TrConcat<TrInstant,White,TrFade<400>>,TrConcat<TrInstant,AlphaL<White,Int<0>>,TrWaveX<White,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>>>,StripesX<Int<3500>,Int<1200>,Mix<Sin<Int<20>>,RotateColorsX<Variation,Rgb<95,0,210>>,RotateColorsX<Variation,Rgb<75,0,165>>>,Mix<Sin<Int<23>>,RotateColorsX<Variation,Rgb<52,0,125>>,RotateColorsX<Variation,Rgb<84,0,210>>>,Mix<Sin<Int<16>>,RotateColorsX<Variation,Rgb<115,15,220>>,RotateColorsX<Variation,Rgb<95,0,210>>>,Mix<Sin<Int<18>>,RotateColorsX<Variation,Rgb<26,0,42>>,RotateColorsX<Variation,Rgb<60,0,132>>>>,TrFade<1225>,RotateColorsX<Variation,Rgb<160,60,255>>,TrFade<250>>,SaberBase::LOCKUP_NORMAL>,
  //Responsive lockup with reset
  //Responsive lightning block
  AlphaL<RotateColorsX<Variation,Rgb<160,60,255>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
  //Sparking emitter flare
  //AlphaL<RotateColorsX<Variation,Rgb16<45025,0,65535>>,SmoothStep<Scale<SlowNoise<Int<1750>>,Int<1500>,Int<4500>>,Int<-6000>>>,
  //Alternate darker sparking emitter flare, color change friendly (for reds and such)
  ResponsiveStabL<Red>,
  //Responsive stab
  ResponsiveClashL<TransitionEffect<Azure,White,TrInstant,TrFade<100>,EFFECT_CLASH>,TrInstant,TrFade<400>,Scale<BladeAngle<0,16000>,Int<4000>,Int<26000>>,Int<6000>,Int<20000>>,
  //Responsive clash
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<160,60,255>>,RandomPerLEDFlicker<Rgb<60,60,60>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<175,80,255>>,Rgb<30,30,30>,200>,RandomPerLEDFlicker<Rgb<80,80,80>,Rgb<30,30,30>>>,TrFade<1650>>,EFFECT_IGNITION>,
  //Bright unstable ignition
  TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<160,60,255>>,40>,TrFade<1200>>,EFFECT_RETRACTION>,
  //Bright HumpFlicker retraction
  //Drag
  //Responsive melt
  InOutTrL<TrWipeSparkTipX<RgbArg<IGNITION_COLOR_ARG,White>,BendTimePow<3000,10384>>,TrWipeInSparkTip<White,2125>>,
  //Spark tip in ignition and retraction
  //InOutTrL<TrWipeSparkTip<White,200>,TrWipeInSparkTip<White,1125>>,
  //Alternate spark tip ignition and retraction
  TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrWipe<150>,HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,TrBoing<350,2>>,EFFECT_PREON>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<5000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<9000>>>,TrFade<625>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,40>,Bump<Int<0>,Int<13000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<18000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,69>,Bump<Int<0>,Int<23000>>>,TrFade<750>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,30>,Bump<Int<0>,Int<7000>>>,TrFade<500>,AlphaL<HumpFlickerL<RotateColorsX<Variation,Rgb<95,0,210>>,50>,Bump<Int<0>,Int<19000>>>,TrBoing<1950,9>>,EFFECT_PREON>,
  TransitionEffectL<TrConcat<TrInstant,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<500>,Int<200>,Int<400>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<1000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<115>,Int<375>,Int<115>,Int<32768>>>,TrDelay<1250>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<1500>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1750>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<300>,Int<300>,Int<32768>>>,TrDelay<2000>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<300>,Int<315>,Int<215>,Int<32768>>>,TrDelay<450>,TransitionLoopL<TrWaveX<RotateColorsX<Variation,Rgb<95,0,210>>,Int<100>,Int<400>,Int<100>,Int<32768>>>,TrDelay<1450>,AlphaL<RotateColorsX<Variation,Rgb<95,0,210>>,Bump<Int<0>,Int<6000>>>,TrBoing<1450,5>>,EFFECT_PREON>,
  TransitionEffectL<TrConcat<TrDelay<4350>,AlphaL<Mix<Trigger<EFFECT_PREON,Int<3000>,Int<5000>,Int<3000>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,Rgb16<33124,0,65535>>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb16<56306,0,65535>>,RotateColorsX<Variation,Rgb16<21919,0,22863>>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,Rgb16<33124,0,65535>>,RotateColorsX<Int<2750>,RotateColorsX<Variation,Rgb16<33124,0,65535>>>>,RotateColorsX<Variation,Rgb16<42753,14386,65535>>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-5000>,Int<42500>>,Int<-4000>>>,TrDelay<7750>>,EFFECT_PREON>
  //Life force drain preon
 { 0, WS281XBladePtr<124, bladePin, Color8::GRB, PowerPINS<bladePowerPin2,bladePowerPin3> >(),
    WS281XBladePtr<7, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >()
  , CONFIGARRAY(presets) },
//Motion chip timeout, trying auto-reboot of motion chip! Motion chip ... Battery voltage: 0.02
First thing I would do is to check for a shorts between the speaker wires and SDA.
Also, you should remove ENABLE_SERIAL from your config file, unless you need it for some reason.
What version do you have of the arduino-proffieboard plugin?
Can you post some pictures of your wiring?
Oh, and what version of ProffieOS?
HI Profezzorn, ok deleted ENABLE_SERIAL, Arduino is 1.8.3.
Sorry but the wiring is everywhere and inside a chassis, I’ve followed the wiring diagrams.
I’m using OS7.12
SDA pad looks untouched from what I can see
Well, the config looks reasonable, which makes me think that this is a wiring problem. (Hopefully a fixable one, and not a “something is fried” one.)
Time to bring out the multimeter and check voltages and shorts.
Arduino 1.8.3 is ancient, I would recommend upgrading that, although I don’t think it will make a difference. However, you didn’t tell me what version you have of the arduino-proffieboard plugin. If that is also ancient, that could be the issue.
How do i find out what arduino-proffieboard plugin i’ve got please?
Thanks for the advice, ill get to it in the morning
Arduino → Tools → Board → Board Manager
(search for proffieboard)
Version 3.6.0 installed
I think i accidentally short circuited the board, leaving the battery in while resoldering some connections, now everything is dead🫣
My condolences.
Haha very good
Had another go at this, it was bad positive and negative power to the board solder connections, all is working now
