My custom built proffieboard v2.2 saber will only do a boot sound and the voice sounds. No light will show and I cant do any other sounds. I’m new to this so this might be an easy fix but if anyone could help that would be great. Everything is wired correctly and my voltage is 4.1
There are thousand ways to wire a proffieboard, all of them correct.
Show us your config file and tell us how your saber is actually wired and then maybe we can tell you what is wrong, or what to check next.
I fixed the lighting and everything is working fine including the AUX button but the power button does nothing but turn the blade off. Here is my config.
#define NUM_BLADES 2
#define VOLUME 2500
#define CLASH_THRESHOLD_G 3.0
#define SHARED_STATE
#define SHARED_POWER_PINS
{ 0,
WS281XBladePtr<26, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin4> >(),
CONFIGARRAY(presets) },
- Have you read the top of
so you know how to use it? - What does it say in the serial monitor when you push the power button?
A few comments on your config file:
- You have no presets, that won’t work properly.
SHARED_STATE
is not a ProffieOS define, it won’t do anything so you can remove it. -
SHARED_POWER_PINS
is only needed if multiple blades use the same power pins, which yours don’t, so you can remove it.
PS: I edited your post and put three backticks before and after the config file to make it show up better.
Thank you and yes I have read all of the sa22c file and it does the boot sound when I press the power button and turns the blade off.
The serial monitor is a good place to get a clue as to what it’s doing/trying to do.
Silly question though: Is the battery charged?
