I’m separating this problem from my other active thread, for an easier handling.
With the FETT263_MOTION_WAKE_POWER_BUTTON enabled, when the motion detection is offline and you press the power button, the saber plays the boot.wav file as expected and resume motion detection.
However, immediately after the boot it starts playing hum.wav, without lighting up the blade.
20:49:11.164 -> Welcome to ProffieOS v6.5. Type 'help' for more info.
20:49:12.308 -> Battery voltage: 3.74
20:49:14.046 -> EVENT: Power-Pressed#1 millis=561780
20:49:14.046 -> EVENT: Power-Pressed millis=561780
20:49:14.215 -> EVENT: Power-Released#1 millis=561945
20:49:14.215 -> EVENT: Power-Released millis=561946
20:49:14.215 -> EVENT: Power-Shortclick#1 millis=561946
20:49:14.215 -> EVENT: Power-Shortclick millis=561946
20:49:14.352 -> EVENT: Power-SavedShortclick#1 millis=562081
20:49:14.386 -> unit = 0 vol = 0.50, Playing Fates/boot.wav
20:49:14.386 -> channels: 1 rate: 22050 bits: 16
20:49:15.962 -> Playing Fates/hum.wav
20:49:15.962 -> channels: 1 rate: 22050 bits: 16
The hum can be stopped by igniting the blade and turning it off.
For reference, this is my current config.
// Fencer
#define NUM_BLADES 2
#define NUM_BUTTONS 1
#define VOLUME 1000
#define CLASH_THRESHOLD_G 2.7
#define SAVE_PRESET
#define DISABLE_BASIC_PARSER_STYLES // required for memory saving and using built-in styles for ProffieOS Workbench
#define FETT263_TWIST_ON
#define ENABLE_DEVELOPER_COMMANDS
#define MOTION_TIMEOUT 1 * 5 * 60 * 1000 // hours * min * 60 sec * millis
{ "Fates;common", "tracks/mars.wav", //DeepSkyBlue
StylePtr<InOutHelper<EasyBlade<AudioFlicker<RandomFlicker<DeepSkyBlue,Rgb16<0,10724,42307>>,Rgb16<635,20393,65535>>,Rgb16<35025,49761,65535>,Rgb16<35025,49761,65535>>,300,800>>(),
StylePtr<InOutHelper<AudioFlicker<Red,Black>,400,800,Pulsing<Red,Black,5000>>>(), "Fates"},
{ "Shatter;common", "tracks/mars.wav", //DeepPurple
StylePtr<InOutHelper<EasyBlade<AudioFlicker<RandomFlicker<Rgb16<30324,0,49768>,Rgb16<7994,78,13896>>,Rgb16<12482,128,21919>>,Rgb16<45487,14885,59477>,Rgb16<45487,14885,59477>>,300,800>>(),
StylePtr<InOutHelper<AudioFlicker<Red,Black>,400,800,Pulsing<Red,Black,5000>>>(), "Shatter"},
{ "Revenge;common", "tracks/mars.wav", //Red
StylePtr<InOutHelper<EasyBlade<AudioFlicker<RandomFlicker<Red,Rgb16<37981,0,0>>,Rgb16<65535,431,431>>,Rgb16<65535,33124,33124>,Rgb16<65535,33124,33124>>,300,800>>(),
StylePtr<InOutHelper<AudioFlicker<Red,Black>,400,800,Pulsing<Red,Black,5000>>>(), "Revenge"},
{ "Bespin;common", "tracks/mars.wav", //Cyan Rgb<0,255,80>
StylePtr<InOutHelper<EasyBlade<AudioFlicker<RandomFlicker<Rgb<0,255,80>,Rgb16<0,45025,3813>>,Rgb16<269,65535,7994>>,Rgb16<45951,65535,65535>,Rgb16<45951,65535,65535>>,300,800>>(),
StylePtr<InOutHelper<AudioFlicker<Red,Black>,400,800,Pulsing<Red,Black,5000>>>(), "Bespin"},
{ "Corell;common", "tracks/mars.wav", //DarkOrange
StylePtr<InOutHelper<EasyBlade<AudioFlicker<RandomFlicker<DarkOrange,Rgb16<22863,1113,0>>,Orange>,NavajoWhite,NavajoWhite>,300,800>>(),
StylePtr<InOutHelper<AudioFlicker<Red,Black>,400,800,Pulsing<Red,Black,5000>>>(), "Corellia"},
{ "SmthJedi;common", "tracks/mars.wav", //Green
StylePtr<InOutHelper<EasyBlade<AudioFlicker<RandomFlicker<Green,Rgb16<0,30086,0>>,Rgb16<169,65535,169>>,Rgb16<28108,65535,28108>,Rgb16<28108,65535,28108>>,300,800>>(),
StylePtr<InOutHelper<AudioFlicker<Red,Black>,400,800,Pulsing<Red,Black,5000>>>(), "Smooth Jedi"},
{ "RgueCmdr;common", "tracks/mars.wav", //Gold
StylePtr<InOutHelper<EasyBlade<AudioFlicker<RandomFlicker<Rgb16<46260,33410,0>,Rgb16<36260,23410,0>>,Rgb16<46260,33410,0>>,Rgb16<65535,48313,28252>,Rgb16<65535,48313,28252>>,300,800>>(),
StylePtr<InOutHelper<AudioFlicker<Red,Black>,400,800,Pulsing<Red,Black,5000>>>(), "Rougue Comm"},
{ "Spitfire;common", "tracks/mars.wav", //Chartreuse
StylePtr<InOutHelper<EasyBlade<AudioFlicker<RandomFlicker<Chartreuse,Rgb16<1373,36732,0>>,Rgb16<4838,65535,431>>,Rgb16<35307,65535,20732>,Rgb16<35307,65535,20732>>,300,800>>(),
StylePtr<InOutHelper<AudioFlicker<Red,Black>,400,800,Pulsing<Red,Black,5000>>>(), "Spitfire"}
struct AVRedLED {
static constexpr float MaxAmps = 0.02;
static constexpr float MaxVolts = 2.0;
static constexpr float P2Amps = 0.01;
static constexpr float P2Volts = 1.8;
static constexpr float R = 150.0; // Resistor value
static const int Red = 255;
static const int Green = 0;
static const int Blue = 0;
{ 0,
SimpleBladePtr<CreeXPE2RedTemplate<1200>, CreeXPE2GreenTemplate<510>, CreeXPE2BlueTemplate<510>, CreeXPE2WhiteTemplate<510>, bladePowerPin1, bladePowerPin2, bladePowerPin3, bladePowerPin4>(),
SimpleBladePtr<AVRedLED, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(),
CONFIGARRAY(presets) },
