I will have to check I’ll let you know tomorrow. Meanwhile, could you clarify what the values 300, 294, 892 are here?
DefaultPinClass, 800000, 300, 294, 892, 5 * 60 * 1000>()
300 = reset pulse length (microseconds)
294 = length of high signal to send a zero (microseconds)
892 = length of high signal to send a one (microseconds)
Not all of the possible WS281X drivers respect these values though.
More reports of green flashes as of OS6. Not just on main blade but emitter PCB as well (ruling out faulty strips).
I’ll try to have people posts here I guess under “OS 6.7 is live” thread.
It’s almost always better to just start a new thread.
If someone is willing to try stuff, I can try a few things and see if we can stop it from happening.
Apologies for reviving an old thread. But is there a current dedicated thread for this green flash issue?
I don’t think so.
Since its often difficult to know if you are having a the same problem as someone else, it’s often best to start a new thread anyways. (After trying a couple of searches to see if a solution can be found easily of course.)
