Ok, but that doesn’t answer the question, which is: Should we make it pretty?
Or should we focus on utility?
My point is that displays are basically eye candy, so having a menu system that looks bad would be self-defeating.
I there an in-between?
Until such time I have some experience with cool color display and layers stuff, I can only speak to128x32 monochrome OLEDs. For those, following suit of the existing operation of bmp use would make sense to me.
I just think if you enter a settings menu, and go forward to blade length edit, seeing those “title screens” would seem like a natural extension of what it already does with boot, font, idle etc…
i don’t hear that well, and process audible information poorly. I process written language much better than spoken. i would very much like to be able to write messages to the OLED display.
I agree, BUT for users that did spring for the “eye candy” if we’re able to support (if they want) then I don’t see harm. For my prop I’d make it an optional define as I assume you’d be sacrificing memory for said “eye candy”, so the user has to make that choice.
My thought is to pair it with the Say functions in Sound Library when we announce menus, as this would just provide a visual prompt. Ideally, if we could append the Say functions in Sound Library with an image to display that might be the way to go, as then we wouldn’t need to go into the various individual menus and add new functions, and since most of the Say functions are “announcing” the active menu, they line up with each “step” already. It would also allow new menus to take advantage if they wanted as the sound library already acts as a “prompt” roadmap.
As to the level of detail and/or utility, I’m of the mind that we take a phased approach. If we can get the menu names/modes added simply enough, then that’s the first step. If displaying things like blade length, volume, etc. is more challenging or requires more thought and time, we do that as a future update/phase after initial feedback from the first phase.
Pardon my ignorance, but I was wondering—what if I wanted to make a saber without sounds? For example, by setting all the configuration options to make the sounds silent. However, instead of sounds, I would love to see the commands displayed on the OLED. Would that be possible, or is it something that can already be done?
You mean, Ignite Muted? There’s already a control, that’s been available since the original OS.
Or you can set BOOT_VOLUME to 0 and use Volume Menu to increase when you want to use sounds.
or unsolder your speaker ![]()
"No, I mean the voice feedback when navigating the settings menu, like when it says 'Blade length, Clash threshold, Exit, Save.
pardon my English
You “could” replace all of sounds in /common with silence, but good luck navigating or using the menus.
Even if we add OLED support, all of the menus use hilt rotation, so you would need to turn yourself with the hilt to be able read the screen at all times, which seems highly impractical. The screen would be an “eye candy” feature, not a viable replacement for the audio IMHO.
This is a bit beyond the scope of this thread, I’d start a separate thread for this or submit a PR.
Fair enough. Hoping it makes it to a future version so I don’t have to patch it later… based on my research there are others who are looking for a solution and lots that has been tried. My method is a super clean way to do it.
Updated first post with OS8 features (missed new circular defines).
This might be an OS9 type request but have ya given any thought to adding the new color ways into the prop? Asking because I know some users who are loving MintyParadise, SchoolBus, and another one. Something beyond the base 27 since the main OS is expanding.
The Color List is just a “starting point” for the main colors, from there the Color Zoom feature allows a user to easily dial to any specific shade they want. I feel like we already have the primary spectrum covered well enough, trying to cater to every users specific color needs is probably better done by said user modifying the Color List itself to their liking.
True and yeah, actually thought of that mod to add in more colors but wanted to touch-base w you first.
*Can you throw a link to where ColorZoom is accessed within the EDIT_SETTINGS_MENU or if it’s while in active mode in case we missed something so I can pass it along to the STEM kids? this way they can bookmark it all as a resource. TIA!
Edit Settings menu doesn’t touch presets, so you can’t edit colors. If you’re using ARG styles you’d access Color List and Color Zoom through Color Change controls.
All controls in my prop for OS7 are listed here:
Much appreciated. So reading thru that and your reply just so I’m clear in my answer on this:
*OS7.15 (stable version) being what I reference here since it’s what they’re using…
…If you want to change in between the standard offered 27 colors where you can go in under an active blade where using Aux-Pow goes into the standard 27 color selections, for ColorZoom you do need to run #define FETT263_EDIT_MODE_MENU.
EDIT_SETTINGS does not provide that so simply comment out (disable) or remove #define FETT263_EDIT_SETTINGS_MENU and run #define FETT263_EDIT_MODE_MENU instead.
ColorZoom is listed under the ColorChange controls or as part of Edit Colors in Edit Mode.
Sorry a qustions: now the fet263 online configurator Is compatibile with 8.15 proffieos?
I can’t select proffieboard 8.x from drop down menù.
I have to update the config helper still. It’s on my list, but finding time has been challenging lately.
