Found the question:
Here’s the test config:
// DualProp saber and blaster based on blade detect
#define NUM_BLADES 5
#define NUM_BUTTONS 1
#define VOLUME 100
// #define EXTRA_COLOR_BUFFER_SPACE 30 // New define that can speed up processing a bit. Basically, it can calculate the colors for the next blade (or the next frame for the same blade) even though it's not done feeding out the data for the data in the color buffer yet.
#define CLASH_THRESHOLD_G 3.5
#define ENABLE_SERIAL // Bluetooth
// #define ENABLE_SSD1306 //OLED
// #define DISABLE_COLOR_CHANGE
#define SHARED_POWER_PINS
#define SAVE_STATE
// #define SAVE_VOLUME
// #define SAVE_PRESET
// #define SAVE_COLOR_CHANGE
// #define SAVE_DYNAMIC_DIMMING
// #define KEEP_SAVEFILES_WHEN_PROGRAMMING // upload overwrites presets.ini/tmp unless this is defined
#define BLADE_DETECT_PIN 10
#define ENABLE_POWER_FOR_ID PowerPINS<bladePowerPin2, bladePowerPin3>
// #define BLADE_ID_CLASS ExternalPullupBladeID<bladeIdentifyPin, 33000>
#define BLADE_ID_CLASS SnapshotBladeID<bladeIdentifyPin> // This will make it use the speed-of-charging-a-capacitor method of blade ID which sometimes works without resistors
// #define SPEAK_BLADE_ID
// #define ENABLE_I2S_OUT
// #define ENABLE_SPDIF_OUT
// #define LINE_OUT_VOLUME 2000 // SPDIF out
#define ENABLE_DEVELOPER_COMMANDS
//#define DISABLE_DIAGNOSTIC_COMMANDS
#define IDLE_OFF_TIME 5 * 1 * 1000
#define MOTION_TIMEOUT 60 * 5 * 1000
// #define ORIENTATION ORIENTATION_FETS_TOWARDS_BLADE
// #define ORIENTATION ORIENTATION_USB_TOWARDS_BLADE
// #define ORIENTATION ORIENTATION_TOP_TOWARDS_BLADE
// #define ORIENTATION ORIENTATION_BOTTOM_TOWARDS_BLADE
// #define ORIENTATION ORIENTATION_SDA_TOWARDS_BLADE
// #define ORIENTATION ORIENTATION_SERIAL_TOWARDS_BLADE
// #define ORIENTATION_ROTATION 0,-20,0
//changes the angle required to register twists on curved hilts
//example is for assaj ventress curved hit install
// #define CONFIG_STARTUP_DELAY 15000 // BC now canon
// #define OLED_FLIP_180 // BC now canon
// #define USE_AUREBESH_FONT
#define FEMALE_TALKIE_VOICE // BC now canon
#define VOLUME_MENU_CYCLE // BC now canon
#define NO_REPEAT_RANDOM // BC now canon
// ------- Gesture stuff -------
//#define BC_SWING_ON
#define BC_STAB_ON
#define BC_THRUST_ON
#define BC_TWIST_ON
#define BC_TWIST_OFF
#define BC_FORCE_PUSH
#define BC_FORCE_PUSH_LENGTH 5
#define ENABLE_AUTO_SWING_BLAST // BC Multiblast continues as long as swinging within 1 second.
#define ENABLE_SPINS
// #define GESTURE_AUTO_BATTLE_MODE
#define BC_LOCKUP_DELAY 200
// ------- Custom / Experimental stuff ---------
// #define NO_VOLUME_MENU // self evident
#define DISABLE_BASIC_PARSER_STYLES // Standard, Advanced, etc...
#define NO_BLADE_NO_GEST_ONOFF // If using blade detect, No Blade = No Gesture ignitions or retractions
#define FILTER_ORDER 8
//#define DYNAMIC_BLADE_LENGTH
//#define DYNAMIC_BLADE_DIMMING
//#define DYNAMIC_CLASH_THRESHOLD
//#define SAVE_VOLUME
//#define SAVE_BLADE_DIMMING
//#define SAVE_CLASH_THRESHOLD
//#define SAVE_COLOR_CHANGE
// --------- blaster --------------
#define ENABLE_BLASTER_AUTO
#define BLASTER_SHOTS_UNTIL_EMPTY 15 // (whatever number)
#define BLASTER_JAM_PERCENTAGE 10 // if not defined, random.
#include "../props/saber_BC_buttons.h"
#undef PROP_TYPE
#include "../props/blaster.h"
#include "../props/dual_prop.h"
#undef PROP_TYPE
#define PROP_TYPE SaberBlasterProp<SaberBCButtons, Blaster>
Preset saber [] = {
{ "testfont2a", "testfont2a/tracks/track2.wav",
// main blade
StylePtr<Layers<
AudioFlicker<RotateColorsX<Variation,DeepSkyBlue>,RotateColorsX<Variation,Rgb<0,0,128>>>,
// Dim Blade 50% "Power Save" button combo
EffectSequence<EFFECT_POWERSAVE,
AlphaL<Black,Int<16384>>,
AlphaL<Black,Int<0>>>,
// Clash
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<TransitionEffect<BrownNoiseFlicker<Rgb<255,150,0>,Black,50>,Moccasin,TrInstant,TrFade<300>,EFFECT_CLASH>,Bump<Scale<BladeAngle<>,Int<25000>,Int<8000>>,Int<18000>>>,TrFade<600>>,EFFECT_CLASH>,
// Stab
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<300>,AlphaL<Stripes<5000,1000,DarkOrange,Rgb<80,60,0>,Orange,Rgb<60,30,0>,Black,DarkOrange,Orange>,SmoothStep<Int<20000>,Int<2000>>>,TrJoin<TrSmoothFade<900>,TrWipe<700>>>,EFFECT_STAB>,
// Blast - white to red for blue and green blades
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>>,EFFECT_BLAST>,
BlastL<Red,850,250,351>,
AlphaL<TransitionEffectL<TrConcat<TrDelay<300>,Red,TrFade<500>>,EFFECT_BLAST>,BlastF<700,250,100000>>,
BlastL<White,500,300,100000>,
// Lockup
LockupTrL<Layers<
AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,
AlphaL<BrownNoiseFlicker<Yellow,Black,50>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<10000>>>>,
TrConcat<TrInstant,
AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<250>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,
// Non-Responsive Drag
LockupTrL<AlphaL<AudioFlicker<BrownNoiseFlicker<Strobe<Black,OrangeRed,20,25>,Yellow,200>,White>,SmoothStep<Int<30000>,Int<2000>>>,TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrFade<150>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_DRAG>,
// Lightning Block Non-Responsive
LockupTrL<AlphaL<RandomFlicker<Strobe<White,Rgb<60,0,255>,50,10>,BrownNoiseFlicker<Rgb<60,0,255>,Black,500>>,LayerFunctions<
Bump<Scale<SlowNoise<Int<2000>>,Int<3000>,Int<16000>>,Scale<BrownNoiseF<Int<10>>,Int<14000>,Int<8000>>>,
Bump<Scale<SlowNoise<Int<2300>>,Int<26000>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<10000>>>,
Bump<Scale<SlowNoise<Int<2300>>,Int<20000>,Int<30000>>,Scale<IsLessThan<SlowNoise<Int<1500>>,Int<8000>>,Scale<NoisySoundLevel,Int<5000>,Int<0>>,Int<0>>>>>,
//Begin Lightning Transition
TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<60,0,255>,Black,500>,TrFade<100>>,
//End Lightning Transition
TrConcat<TrInstant,GreenYellow,TrDelay<25>,BrownNoiseFlicker<Rgb<60,0,255>,Black,500>,TrFade<150>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<50>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<400>> >,SaberBase::LOCKUP_LIGHTNING_BLOCK>,
// Melt
LockupTrL<
AlphaL<Mix<TwistAngle<>,Yellow,RandomPerLEDFlicker<Orange,OrangeRed>,BrownNoiseFlicker<Rgb16<20095,128,128>,Rgb16<35103,8175,298>,150>,StyleFire<Rgb16<20393,93,93>,Red,0,4,FireConfig<0,2000,5>,FireConfig<3000,0,0>,FireConfig<0,4000,0>>>,
// Melt Shape
SmoothStep<Scale<TwistAngle<>,Int<24000>,Int<29000>>,Int<2000>>>,
//Melt Begin and End transitions
TrConcat<TrInstant,GreenYellow,TrDelay<25>,AlphaL<Black,Int<0>>,TrWipeIn<600>>,TrColorCycle<1500,-2000,100>,SaberBase::LOCKUP_MELT>, // Great melt colors as you twist, gets dripping red hot/fire and bright yellow.
// Ignition / Retraction
InOutTrL<TrWipeSparkTip<White,250>,TrWipeInX<WavLen<EFFECT_RETRACTION>>>,
// On-Demand Battery Level
AlphaL<TransitionEffectL<TrConcat<TrSmoothFade<500>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Scale<BatteryLevel,Int<0>,Int<35000>>,Int<-1>>>,TrDelay<1000>,AlphaL<Mix<BatteryLevel,Red,Green>,SmoothStep<Scale<BatteryLevel,Int<0>,Int<35000>>,Int<-1>>>,TrSmoothFade<1000>>,EFFECT_FORCE>,Ifon<Int<0>,Int<32768>>>
// muzzle
StylePtr<Black>(),
// barrel
StylePtr<Black>(),
"testdualprop\nblade in"},
{ "TeensySF;common", "",
// main blade
StylePtr<Red>(),
// barrel
StylePtr<Green>(),
// muzzle
StylePtr<Yellow>(),
"TeensySF\nbladein"},
Preset blaster[] = {
{ "testfont2a", "testfont2a/tracks/track1.wav",
// Main BLade
// StylePtr<Black>(),
// barrel
StylePtr<Layers<
Black,
TransitionEffectL<TrConcat<TrWipe<100>,White,TrWipe<100>,Red,TrWipe<200>>,EFFECT_FIRE>,
TransitionEffectL<TrConcat<TrWipe<100>,DeepSkyBlue,TrWipe<100>,Blinking<Black,Blue,100,500>,TrWipe<200>>,EFFECT_STUN>,
LockupTrL<Layers<
TransitionLoopL<TrConcat<TrWipe<50>,Red,TrWipe<150>>>,
TransitionLoopL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<25000>>>,TrFade<200>>>,
TransitionLoopL<TrConcat<TrInstant,AlphaL<White,Bump<Int<0>,Int<25000>>>,TrFade<200>>>>,TrConcat<TrInstant,Rgb<255,100,100>,TrFade<200>>,TrJoin<TrConcat<TrInstant,AlphaL<Rgb<50,0,0>,Bump<Int<32768>,Int<60000>>>,TrFade<400>>,TrWipeX<Int<400>>,TrWaveX<Rgb<50,0,0>,Int<1800>,Int<40>,Int<400>,Int<5000>>>,SaberBase::LOCKUP_AUTOFIRE>
// muzzle
StylePtr<Layers<
Black,
TransitionEffectL<TrConcat<TrDelay<100>,White,TrFade<200>,Red,TrFade<300>>,EFFECT_FIRE>,
TransitionEffectL<TrConcat<TrDelay<100>,DeepSkyBlue,TrFade<200>,Blinking<Black,Blue,100,500>,TrFade<300>>,EFFECT_STUN>,
LockupTrL<Layers<
TransitionLoopL<TrConcat<TrInstant,White,TrFade<50>,Red,TrFade<150>>>>,TrInstant,TrConcat<TrInstant,Rgb<50,0,0>,TrFade<400>>,SaberBase::LOCKUP_AUTOFIRE>
"testfont2a\nbladeout"},
{ 123, // BCA 123, 1" Ciel_Tan_A 132 D1_data_line = proffie_D1---> NPXL ctrpin---> bladePCB 330ohm--->Main blade strips
WS281XBladePtr<132, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), // Main Blade
WS281XBladePtr<5, blade2Pin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), // HiltPCB
WS281XBladePtr<10, blade3Pin, Color8::GRB, PowerPINS<bladePowerPin5> >(), // Switches
SimpleBladePtr<AccentsLED, NoLED, NoLED, NoLED, bladePowerPin1, -1, -1, -1>(), // Pommel
SimpleBladePtr<CH3LED, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>(), // Bluetooth // barrel
CONFIGARRAY(saber),
"SaberSave"},
{ NO_BLADE, // D1_data_line = proffie_D1---> NPXL ctrpin---> bladePCB 330ohm--->Main blade strips
// WS281XBladePtr<132, bladePin, Color8::GRB, PowerPINS<bladePowerPin2, bladePowerPin3> >(), // Main Blade
CONFIGARRAY(blaster),
"BlasterSave"}
// Button FireButton(BUTTON_FIRE, powerButtonPin, "fire");
// Button ModeButton(BUTTON_MODE_SELECT, auxPin, "modeselect");
