I thought I should post this in a separate thread, since this is a new problem after installing a new voice pack on my Sabertrio. Well, now it seems I can only access one font, and I can’t get into the settings menu.
Help?
(Thanks in advance)
Help?
(Thanks in advance)
Make sure you have the proper amount of buttons defined and look at the controls for the prop you are using.
Yeah the button are defined correctly. I’m not sure what you mean by “the prop”.
The prop file that your saber uses is in charge of how the saber is controlled.
If you do not have a prop file defined then it will default to the saber.h prop.
I would look to see if you have a prop defined and if not either define one or look for the controls of the saber.h prop.
Oh right, I see what you mean. Currently I have the props set to “../props/saber_fett263_buttons.h”. But when I change it over to “../props/saber_sabertrio_buttons.h”, I get a long error message:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2360:12: error: 'MENU_SWINGON_SPEED' was not declared in this scope; did you mean 'FETT263_SWING_ON_SPEED'?
2360 | case MENU_SWINGON_SPEED:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2365:12: error: 'MENU_TWISTON' was not declared in this scope
2365 | case MENU_TWISTON:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2366:12: error: 'MENU_THRUSTON' was not declared in this scope
2366 | case MENU_THRUSTON:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2367:12: error: 'MENU_STABON' was not declared in this scope
2367 | case MENU_STABON:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2368:12: error: 'MENU_TWISTOFF' was not declared in this scope
2368 | case MENU_TWISTOFF:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2372:12: error: 'MENU_CLASH_THRESHOLD' was not declared in this scope; did you mean 'SAVE_CLASH_THRESHOLD'?
2372 | case MENU_CLASH_THRESHOLD:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2377:12: error: 'MENU_DIM_BLADE' was not declared in this scope
2377 | case MENU_DIM_BLADE:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2378:35: error: 'dim_revert_' was not declared in this scope
2378 | SaberBase::SetDimming(pow(dim_revert_, 2.5) * 16384);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2381:9: error: 'SaveGlobalState' was not declared in this scope; did you mean 'SaveGlobalStateFile'?
2381 | SaveGlobalState();
| SaveGlobalStateFile
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2387:12: error: 'MENU_VOLUME' was not declared in this scope
2387 | case MENU_VOLUME:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2389:34: error: 'revert_volume' was not declared in this scope
2389 | dynamic_mixer.set_volume(revert_volume);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2395:9: error: 'menu_sub_pos_' was not declared in this scope
2395 | menu_sub_pos_ = 0;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2402:12: error: 'MENU_STYLE_SETTING_SUB' was not declared in this scope
2402 | case MENU_STYLE_SETTING_SUB:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2407:20: error: 'DoPulsingCrystal' is not a member of 'SaberBase'
2407 | SaberBase::DoPulsingCrystal();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2410:12: error: 'MENU_OFF_OPTION' was not declared in this scope
2410 | case MENU_OFF_OPTION:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2412:9: error: 'RevertInOut' was not declared in this scope
2412 | RevertInOut();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2413:9: error: 'SetPresetFast' was not declared in this scope
2413 | SetPresetFast(current_preset_.preset_num);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2417:20: error: 'DoPulsingCrystal' is not a member of 'SaberBase'
2417 | SaberBase::DoPulsingCrystal();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void MenuExit()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2424:13: error: 'menu_type_' was not declared in this scope
2424 | switch (menu_type_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2425:12: error: 'MENU_PRESET' was not declared in this scope; did you mean 'ENETRESET'?
2425 | case MENU_PRESET:
| ENETRESET
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2426:9: error: 'first_preset' was not declared in this scope
2426 | first_preset();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2429:12: error: 'MENU_VOLUME' was not declared in this scope
2429 | case MENU_VOLUME:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2433:12: error: 'MENU_SETTING_SUB' was not declared in this scope
2433 | case MENU_SETTING_SUB:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2434:9: error: 'in_menu_' was not declared in this scope
2434 | in_menu_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2435:9: error: 'menu_time_' was not declared in this scope
2435 | menu_time_ = millis();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2442:5: error: 'menu_type_' was not declared in this scope
2442 | menu_type_ = MENU_TOP;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2442:18: error: 'MENU_TOP' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2443:5: error: 'menu_' was not declared in this scope
2443 | menu_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2444:5: error: 'in_menu_' was not declared in this scope
2444 | in_menu_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2445:5: error: 'twist_menu_' was not declared in this scope
2445 | twist_menu_ = M_PI / 2.5;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2446:5: error: 'wav_player' was not declared in this scope; did you mean 'wav_players'?
2446 | wav_player.Free();
| wav_players
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2447:5: error: 'StopSystemMenuBGM' was not declared in this scope
2447 | StopSystemMenuBGM();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2448:9: error: 'OFF_FAST' was not declared in this scope
2448 | Off(OFF_FAST);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2448:5: error: 'Off' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void MenuSave()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2452:9: error: 'menu_type_' was not declared in this scope
2452 | if (menu_type_ == MENU_VOLUME) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2452:23: error: 'MENU_VOLUME' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2458:9: error: 'menu_type_' was not declared in this scope
2458 | if (menu_type_ == MENU_SETTING_SUB) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2458:23: error: 'MENU_SETTING_SUB' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2459:18: error: 'DoSettingsMenu' is not a member of 'SaberBase'
2459 | SaberBase::DoSettingsMenu();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2461:9: error: 'in_menu_' was not declared in this scope
2461 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2462:7: error: 'MenuPrompt' was not declared in this scope
2462 | MenuPrompt();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2463:7: error: 'MenuDial' was not declared in this scope
2463 | MenuDial(0);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void MenuSelect()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2469:9: error: 'menu_type_' was not declared in this scope
2469 | if (menu_type_ == MENU_SETTING_SUB) SaberBase::DoSettingsMenu();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2469:23: error: 'MENU_SETTING_SUB' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2469:52: error: 'DoSettingsMenu' is not a member of 'SaberBase'
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2470:5: error: 'MenuPrompt' was not declared in this scope
2470 | MenuPrompt();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2471:5: error: 'MenuDial' was not declared in this scope
2471 | MenuDial(0);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void MenuConfirm()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2476:9: error: 'menu_type_' was not declared in this scope
2476 | if (menu_type_ == MENU_SETTING_SUB) SaberBase::DoSettingsMenu();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2476:23: error: 'MENU_SETTING_SUB' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2476:52: error: 'DoSettingsMenu' is not a member of 'SaberBase'
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2477:5: error: 'MenuPrompt' was not declared in this scope
2477 | MenuPrompt();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2478:5: error: 'MenuDial' was not declared in this scope
2478 | MenuDial(0);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void MenuCancel()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2483:9: error: 'menu_type_' was not declared in this scope
2483 | if (menu_type_ == MENU_SETTING_SUB) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2483:23: error: 'MENU_SETTING_SUB' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2484:18: error: 'DoSettingsMenu' is not a member of 'SaberBase'
2484 | SaberBase::DoSettingsMenu();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2486:5: error: 'MenuPrompt' was not declared in this scope
2486 | MenuPrompt();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2487:5: error: 'MenuDial' was not declared in this scope
2487 | MenuDial(0);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void MenuReturn()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2491:20: error: 'class SoundLibrary' has no member named 'SayReturn'; did you mean 'SayRevert'?
2491 | sound_library_.SayReturn();
| SayRevert
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2492:9: error: 'menu_type_' was not declared in this scope
2492 | if (menu_type_ == MENU_SETTING_SUB) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2492:23: error: 'MENU_SETTING_SUB' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2493:18: error: 'DoSettingsMenu' is not a member of 'SaberBase'
2493 | SaberBase::DoSettingsMenu();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2495:5: error: 'MenuPrompt' was not declared in this scope
2495 | MenuPrompt();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2496:5: error: 'MenuDial' was not declared in this scope
2496 | MenuDial(0);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void MenuRevert()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2501:9: error: 'menu_type_' was not declared in this scope
2501 | if (menu_type_ == MENU_SETTING_SUB) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2501:23: error: 'MENU_SETTING_SUB' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2502:18: error: 'DoSettingsMenu' is not a member of 'SaberBase'
2502 | SaberBase::DoSettingsMenu();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2504:5: error: 'MenuPrompt' was not declared in this scope
2504 | MenuPrompt();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2505:5: error: 'MenuDial' was not declared in this scope
2505 | MenuDial(0);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void MenuPrompt()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2509:13: error: 'menu_type_' was not declared in this scope
2509 | switch (menu_type_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2510:12: error: 'MENU_TOP' was not declared in this scope
2510 | case MENU_TOP:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2515:12: error: 'MENU_BLADE_LENGTH' was not declared in this scope; did you mean 'DYNAMIC_BLADE_LENGTH'?
2515 | case MENU_BLADE_LENGTH:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2519:12: error: 'MENU_GESTURE_SUB' was not declared in this scope
2519 | case MENU_GESTURE_SUB:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2522:12: error: 'MENU_SETTING_SUB' was not declared in this scope
2522 | case MENU_SETTING_SUB:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: At global scope:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2542:48: error: virt-specifiers in 'Parse' not allowed outside a class definition
2542 | bool Parse(const char *cmd, const char* arg) override {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'bool Parse(const char*, const char*)':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2543:24: error: cannot call member function 'virtual bool PropBase::Parse(const char*, const char*)' without object
2543 | if (PropBase::Parse(cmd, arg)) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2549:9: error: 'ListTracks' was not declared in this scope; did you mean 'SetTrack'?
2549 | ListTracks(path);
| SetTrack
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2555:7: error: 'saved_gesture_control' was not declared in this scope
2555 | saved_gesture_control.Print(arg);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2559:7: error: 'saved_gesture_control' was not declared in this scope
2559 | saved_gesture_control.Set(arg);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2560:7: error: 'SaveGestureState' was not declared in this scope
2560 | SaveGestureState();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void ToggleBattleMode()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2577:10: error: 'battle_mode_' was not declared in this scope
2577 | if (!battle_mode_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void ToggleMultiBlast()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2595:5: error: 'swing_blast_' was not declared in this scope
2595 | swing_blast_ = !swing_blast_;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void ToggleBattleModeMultiBlast()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2612:9: error: 'battle_mode_' was not declared in this scope
2612 | if (battle_mode_ && !swing_blast_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2612:26: error: 'swing_blast_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2613:7: error: 'check_blast_' was not declared in this scope
2613 | check_blast_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2614:7: error: 'last_blast_millis_' was not declared in this scope
2614 | last_blast_millis_ = millis();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2616:5: error: 'swing_blast_' was not declared in this scope
2616 | swing_blast_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void DoAutoMultiBlast()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2620:9: error: 'check_blast_' was not declared in this scope
2620 | if (check_blast_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2621:22: error: 'last_blast_millis_' was not declared in this scope
2621 | if (millis() - last_blast_millis_ < 2000) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2622:9: error: 'swing_blast_' was not declared in this scope
2622 | swing_blast_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void DoIgnition()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2632:9: error: 'On' was not declared in this scope; did you mean 'yn'?
2632 | On();
| yn
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2634:9: error: 'FastOn' was not declared in this scope
2634 | FastOn();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void CheckQuote()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2645:9: error: 'force_quote_' was not declared in this scope
2645 | force_quote_ = !force_quote_;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2647:7: error: 'ForceQuote' was not declared in this scope
2647 | ForceQuote();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void ForceQuote()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2654:9: error: 'force_quote_' was not declared in this scope; did you mean 'ForceQuote'?
2654 | if (force_quote_) {
| ForceQuote
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void PresetMenu(bool)':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2682:7: error: 'next_preset' was not declared in this scope; did you mean 'prop_next_preset'?
2682 | next_preset();
| prop_next_preset
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2684:7: error: 'previous_preset' was not declared in this scope; did you mean 'prop_previous_preset'?
2684 | previous_preset();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void ResetColors()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2690:5: error: 'ToggleColorChangeMode' was not declared in this scope
2690 | ToggleColorChangeMode();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2692:5: error: 'current_preset_' was not declared in this scope; did you mean 'CurrentPreset'?
2692 | current_preset_.SetStyle(blade_num_, style_parser.CopyArguments("~", current_preset_.GetStyle(blade_num_), int_arg_menu_, NELEM(int_arg_menu_)));
| CurrentPreset
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2692:30: error: 'blade_num_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2694:5: error: 'UpdateStyle' was not declared in this scope
2694 | UpdateStyle();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void first_preset()':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2700:5: error: 'SaveState' was not declared in this scope
2700 | SaveState(0);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2702:5: error: 'SetPreset' was not declared in this scope; did you mean 'Preset'?
2702 | SetPreset(0, true);
| Preset
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void ChangeVolume(int)':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2713:22: error: 'class SoundLibrary' has no member named 'SayMininumVolume'; did you mean 'SayMinimumVolume'?
2713 | sound_library_.SayMininumVolume();
| SayMinimumVolume
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2742:68: error: virt-specifiers in 'Event2' not allowed outside a class definition
2742 | bool Event2(enum BUTTON button, EVENT event, uint32_t modifiers) override {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'bool Event2(BUTTON, EVENT, uint32_t)':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2751:9: error: 'blade_detected_' was not declared in this scope; did you mean 'BladeDetect'?
2751 | blade_detected_ = true;
| BladeDetect
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2755:9: error: 'saved_gesture_control' was not declared in this scope
2755 | saved_gesture_control.gestureon = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2757:9: error: 'FindBladeAgain' was not declared in this scope
2757 | FindBladeAgain();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2764:9: error: 'Off' was not declared in this scope
2764 | Off();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2766:20: error: 'DoNoBlade' is not a member of 'SaberBase'
2766 | SaberBase::DoNoBlade();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2777:13: error: 'menu_' was not declared in this scope
2777 | if (menu_ && menu_type_ == MENU_TRACK_PLAYER) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2777:22: error: 'menu_type_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2777:36: error: 'MENU_TRACK_PLAYER' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2779:24: error: 'MENU_TOP' was not declared in this scope
2779 | menu_type_ = MENU_TOP;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2787:13: error: 'menu_' was not declared in this scope
2787 | if (menu_) return false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2789:9: error: 'saber_off_time_millis_' was not declared in this scope
2789 | saber_off_time_millis_ = millis();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2797:14: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
2797 | if (!preset_menu_ && !in_menu_) {
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2797:31: error: 'in_menu_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2798:26: error: 'class SoundLibrary' has no member named 'SayResetBeep'
2798 | sound_library_.SayResetBeep(); // Beep to prompt user to release aux button for system reset
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2807:13: error: 'in_menu_' was not declared in this scope
2807 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2808:26: error: 'class SoundLibrary' has no member named 'ClearSoundQueue'
2808 | sound_library_.ClearSoundQueue();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2809:11: error: 'MenuDial' was not declared in this scope
2809 | MenuDial(-1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2812:20: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
2812 | } else if (preset_menu_) {
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2813:11: error: 'preset_forward_' was not declared in this scope
2813 | preset_forward_= false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2821:24: error: 'DoNoBlade' is not a member of 'SaberBase'
2821 | SaberBase::DoNoBlade();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2824:28: error: 'menu_time_' was not declared in this scope
2824 | if (millis() - menu_time_ > 1000) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2825:15: error: 'DoInteractivePreon' was not declared in this scope
2825 | DoInteractivePreon();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2833:14: error: 'in_menu_' was not declared in this scope
2833 | if (!in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2843:11: error: 'SaveGestureState' was not declared in this scope
2843 | SaveGestureState();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2857:9: error: 'StopWavPlayers' was not declared in this scope
2857 | StopWavPlayers(); // Stops reset beep
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2858:14: error: 'mode_volume_' was not declared in this scope; did you mean 'f_delvolume'?
2858 | if (!mode_volume_) {
| f_delvolume
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2859:11: error: 'StartOrStopTrack' was not declared in this scope
2859 | StartOrStopTrack();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2864:13: error: 'menu_' was not declared in this scope
2864 | if (menu_) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2865:13: error: 'in_menu_' was not declared in this scope
2865 | if (in_menu_) return false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2867:14: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
2867 | if (!preset_menu_ && blade_detected_) {
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2871:17: error: 'SetMute' was not declared in this scope
2871 | if (SetMute(true)) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2872:15: error: 'unmute_on_deactivation_' was not declared in this scope
2872 | unmute_on_deactivation_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2873:15: error: 'On' was not declared in this scope; did you mean 'yn'?
2873 | On();
| yn
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2882:22: error: 'DoNoBlade' is not a member of 'SaberBase'
2882 | SaberBase::DoNoBlade();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2894:14: error: 'menu_' was not declared in this scope
2894 | if (!menu_ && !in_menu_ && !preset_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2894:24: error: 'in_menu_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2894:37: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2895:11: error: 'StartEditMode' was not declared in this scope
2895 | StartEditMode();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2897:11: error: 'menu_time_' was not declared in this scope
2897 | menu_time_ = millis();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2898:11: error: 'system_menu_bgm_switch_' was not declared in this scope
2898 | system_menu_bgm_switch_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2899:11: error: 'MenuDial' was not declared in this scope
2899 | MenuDial(1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2910:13: error: 'menu_' was not declared in this scope
2910 | if (menu_) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2911:13: error: 'CheckShowColorCC' was not declared in this scope
2911 | if (CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2916:13: error: 'CheckShowColorCC' was not declared in this scope
2916 | if (CheckShowColorCC()) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2925:13: error: 'CancelShowColor' was not declared in this scope
2925 | if (CancelShowColor()) return false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2926:13: error: 'menu_' was not declared in this scope
2926 | if (menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2928:13: error: 'menu_type_' was not declared in this scope
2928 | if (menu_type_ == MENU_SETTING_SUB) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2928:27: error: 'MENU_SETTING_SUB' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2929:11: error: 'MenuChoice' was not declared in this scope
2929 | MenuChoice();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2955:13: error: 'menu_' was not declared in this scope
2955 | if (menu_ || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2955:22: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2958:11: error: 'battle_mode_' was not declared in this scope
2958 | battle_mode_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2965:13: error: 'CheckShowColorCC' was not declared in this scope
2965 | if (CheckShowColorCC()) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2971:13: error: 'in_menu_' was not declared in this scope
2971 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2976:14: error: 'swinging_' was not declared in this scope
2976 | if (!swinging_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2977:11: error: 'check_blast_' was not declared in this scope
2977 | check_blast_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2978:11: error: 'swing_blast_' was not declared in this scope
2978 | swing_blast_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2981:11: error: 'battle_mode_' was not declared in this scope
2981 | battle_mode_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2988:13: error: 'CheckShowColorCC' was not declared in this scope
2988 | if (CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2989:13: error: 'in_menu_' was not declared in this scope
2989 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:2999:13: error: 'CheckShowColorCC' was not declared in this scope
2999 | if (CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3000:12: error: 'in_menu_' was not declared in this scope
3000 | if(in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3001:26: error: 'class SoundLibrary' has no member named 'ClearSoundQueue'
3001 | sound_library_.ClearSoundQueue();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3002:11: error: 'MenuDial' was not declared in this scope
3002 | MenuDial(-1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3020:13: error: 'in_menu_' was not declared in this scope
3020 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3021:26: error: 'class SoundLibrary' has no member named 'ClearSoundQueue'
3021 | sound_library_.ClearSoundQueue();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3022:11: error: 'MenuDial' was not declared in this scope
3022 | MenuDial(1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3027:26: error: 'kyber_time_' was not declared in this scope
3027 | if (millis() - kyber_time_ >1000) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3028:13: error: 'DoInteractiveBlast' was not declared in this scope
3028 | DoInteractiveBlast();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3035:13: error: 'in_menu_' was not declared in this scope
3035 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3036:11: error: 'MenuChoice' was not declared in this scope
3036 | MenuChoice();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3042:11: error: 'ToggleColorChangeMode' was not declared in this scope
3042 | ToggleColorChangeMode();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3054:13: error: 'CancelShowColor' was not declared in this scope
3054 | if (CancelShowColor()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3055:13: error: 'in_menu_' was not declared in this scope
3055 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3056:11: error: 'MenuDial' was not declared in this scope
3056 | MenuDial(-1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3069:13: error: 'menu_' was not declared in this scope
3069 | if (menu_ || CancelShowColor()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3069:22: error: 'CancelShowColor' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3077:13: error: 'ToggleColorChangeMode' was not declared in this scope
3077 | ToggleColorChangeMode();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3081:24: error: 'DoKyber' is not a member of 'SaberBase'
3081 | SaberBase::DoKyber();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3082:13: error: 'ToggleColorChangeMode' was not declared in this scope
3082 | ToggleColorChangeMode();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3083:13: error: 'kyber_time_' was not declared in this scope
3083 | kyber_time_ = millis();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3091:13: error: 'menu_' was not declared in this scope
3091 | if (menu_ || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3091:22: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3100:11: error: 'check_blast_' was not declared in this scope
3100 | check_blast_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3101:11: error: 'swing_blast_' was not declared in this scope
3101 | swing_blast_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3108:13: error: 'menu_' was not declared in this scope
3108 | if (menu_ || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3108:22: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3110:9: error: 'check_blast_' was not declared in this scope
3110 | check_blast_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3111:9: error: 'swing_blast_' was not declared in this scope
3111 | swing_blast_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3116:13: error: 'menu_' was not declared in this scope
3116 | if (menu_ || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3116:22: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3134:13: error: 'in_menu_' was not declared in this scope
3134 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3139:13: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
3139 | if (preset_menu_) {
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3142:11: error: 'StopMenuBGM' was not declared in this scope
3142 | StopMenuBGM();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3146:15: error: 'menu_' was not declared in this scope
3146 | if (menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3152:24: error: 'DoNoBlade' is not a member of 'SaberBase'
3152 | SaberBase::DoNoBlade();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3155:28: error: 'menu_time_' was not declared in this scope
3155 | if (millis() - menu_time_ > 1000) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3163:13: error: 'in_menu_' was not declared in this scope
3163 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3164:26: error: 'class SoundLibrary' has no member named 'ClearSoundQueue'
3164 | sound_library_.ClearSoundQueue();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3165:11: error: 'MenuDial' was not declared in this scope
3165 | MenuDial(1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3168:13: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
3168 | if (preset_menu_) {
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3169:11: error: 'preset_forward_' was not declared in this scope
3169 | preset_forward_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3178:14: error: 'in_menu_' was not declared in this scope
3178 | if (!in_menu_ && !preset_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3178:27: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3184:13: error: 'in_menu_' was not declared in this scope
3184 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3185:11: error: 'MenuChoice' was not declared in this scope
3185 | MenuChoice();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3188:14: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
3188 | if (!preset_menu_) {
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3191:11: error: 'preset_forward_' was not declared in this scope
3191 | preset_forward_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3194:11: error: 'StartMenuBGM' was not declared in this scope
3194 | StartMenuBGM();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3197:11: error: 'StopMenuBGM' was not declared in this scope
3197 | StopMenuBGM();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3209:13: error: 'color_mode_' was not declared in this scope
3209 | if (color_mode_ == CC_COLOR_LIST) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3210:11: error: 'dial_' was not declared in this scope
3210 | dial_ = (dial_ + 1) % NELEM(color_list_);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3215:13: error: 'in_menu_' was not declared in this scope
3215 | if (in_menu_ && enable_twist_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3215:25: error: 'enable_twist_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3216:11: error: 'MenuDial' was not declared in this scope
3216 | MenuDial(1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3226:13: error: 'color_mode_' was not declared in this scope
3226 | if (color_mode_ == CC_COLOR_LIST) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3227:15: error: 'dial_' was not declared in this scope
3227 | if (dial_ <= 0) dial_ = NELEM(color_list_);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3228:11: error: 'dial_' was not declared in this scope
3228 | dial_ = dial_ - 1;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3233:13: error: 'in_menu_' was not declared in this scope
3233 | if (in_menu_ && enable_twist_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3233:25: error: 'enable_twist_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3234:11: error: 'MenuDial' was not declared in this scope
3234 | MenuDial(-1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3244:13: error: 'in_menu_' was not declared in this scope
3244 | if (in_menu_ && enable_twist_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3244:25: error: 'enable_twist_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3245:11: error: 'MenuDial' was not declared in this scope
3245 | MenuDial(1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3255:13: error: 'in_menu_' was not declared in this scope
3255 | if (in_menu_ && enable_twist_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3255:25: error: 'enable_twist_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3256:11: error: 'MenuDial' was not declared in this scope
3256 | MenuDial(-1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3262:13: error: 'menu_' was not declared in this scope
3262 | if (menu_ || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3262:22: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3276:13: error: 'in_menu_' was not declared in this scope
3276 | if (in_menu_ && enable_twist_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3276:25: error: 'enable_twist_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3277:11: error: 'MenuDialIncrement' was not declared in this scope
3277 | MenuDialIncrement(1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3280:13: error: 'swinging_' was not declared in this scope
3280 | if (swinging_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3290:13: error: 'in_menu_' was not declared in this scope
3290 | if (in_menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3291:11: error: 'MenuDialIncrement' was not declared in this scope
3291 | MenuDialIncrement(-1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3294:13: error: 'swinging_' was not declared in this scope
3294 | if (swinging_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3304:13: error: 'menu_' was not declared in this scope
3304 | if (menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3305:15: error: 'menu_type_' was not declared in this scope
3305 | if (menu_type_ == MENU_TRACK_PLAYER) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3305:29: error: 'MENU_TRACK_PLAYER' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3306:13: error: 'track_mode_' was not declared in this scope; did you mean 'track_player_'?
3306 | track_mode_ = PLAYBACK_ROTATE;
| track_player_
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3306:27: error: 'PLAYBACK_ROTATE' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3310:13: error: 'MenuDialIncrement' was not declared in this scope
3310 | MenuDialIncrement(1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3321:13: error: 'menu_' was not declared in this scope
3321 | if (menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3322:15: error: 'menu_type_' was not declared in this scope
3322 | if (menu_type_ == MENU_TRACK_PLAYER) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3322:29: error: 'MENU_TRACK_PLAYER' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3323:13: error: 'track_mode_' was not declared in this scope; did you mean 'track_player_'?
3323 | track_mode_ = PLAYBACK_LOOP;
| track_player_
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3323:27: error: 'PLAYBACK_LOOP' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3327:13: error: 'MenuDialIncrement' was not declared in this scope
3327 | MenuDialIncrement(-1);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3334:13: error: 'menu_' was not declared in this scope
3334 | if (menu_) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3340:13: error: 'menu_' was not declared in this scope
3340 | if (menu_ || SaberBase::Lockup() || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3340:45: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3342:14: error: 'battle_mode_' was not declared in this scope
3342 | if (!battle_mode_ || swinging_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3342:30: error: 'swinging_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3343:11: error: 'clash_impact_millis_' was not declared in this scope
3343 | clash_impact_millis_ = millis();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3347:9: error: 'clash_impact_millis_' was not declared in this scope
3347 | clash_impact_millis_ = millis();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3353:11: error: 'auto_melt_on_' was not declared in this scope
3353 | auto_melt_on_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3356:9: error: 'clash_type_' was not declared in this scope; did you mean 'clash_t_'?
3356 | clash_type_ = CLASH_BATTLE_MODE;
| clash_t_
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3356:23: error: 'CLASH_BATTLE_MODE' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3360:13: error: 'menu_' was not declared in this scope
3360 | if (menu_ || SaberBase::Lockup() || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3360:45: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3364:14: error: 'swinging_' was not declared in this scope
3364 | if (!swinging_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3365:16: error: 'battle_mode_' was not declared in this scope
3365 | if (!battle_mode_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3374:11: error: 'auto_melt_on_' was not declared in this scope
3374 | auto_melt_on_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3382:13: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
3382 | if (preset_menu_) return false;
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3383:14: error: 'menu_' was not declared in this scope
3383 | if (!menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3387:15: error: 'FastOn' was not declared in this scope
3387 | FastOn();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3395:24: error: 'DoNoBlade' is not a member of 'SaberBase'
3395 | SaberBase::DoNoBlade();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3403:13: error: 'menu_' was not declared in this scope
3403 | if (menu_ || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3403:22: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3404:24: error: 'last_twist_' was not declared in this scope
3404 | if (millis() - last_twist_ > 1000) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3407:11: error: 'battle_mode_' was not declared in this scope
3407 | battle_mode_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3412:9: error: 'battle_mode_' was not declared in this scope
3412 | battle_mode_ = false;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3418:13: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
3418 | if (preset_menu_) return false;
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3420:14: error: 'menu_' was not declared in this scope
3420 | if (!menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3422:26: error: 'last_twist_' was not declared in this scope
3422 | if (millis() - last_twist_ > 1000 && millis() - saber_off_time_ > 1000) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3422:59: error: 'saber_off_time_' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3425:17: error: 'On' was not declared in this scope; did you mean 'yn'?
3425 | On();
| yn
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3433:26: error: 'DoNoBlade' is not a member of 'SaberBase'
3433 | SaberBase::DoNoBlade();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3446:13: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
3446 | if (preset_menu_) return false;
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3447:14: error: 'menu_' was not declared in this scope
3447 | if (!menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3451:15: error: 'FastOn' was not declared in this scope
3451 | FastOn();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3459:24: error: 'DoNoBlade' is not a member of 'SaberBase'
3459 | SaberBase::DoNoBlade();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3467:13: error: 'preset_menu_' was not declared in this scope; did you mean 'PresetMenu'?
3467 | if (preset_menu_) return false;
| PresetMenu
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3468:14: error: 'menu_' was not declared in this scope
3468 | if (!menu_) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3472:15: error: 'FastOn' was not declared in this scope
3472 | FastOn();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3480:24: error: 'DoNoBlade' is not a member of 'SaberBase'
3480 | SaberBase::DoNoBlade();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3486:13: error: 'menu_' was not declared in this scope
3486 | if (menu_ || CheckShowColorCC()) return true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3486:22: error: 'CheckShowColorCC' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3489:23: error: 'last_push_millis_' was not declared in this scope
3489 | millis() - last_push_millis_ > 1000) {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3513:53: error: virt-specifiers in 'SB_Effect' not allowed outside a class definition
3513 | void SB_Effect(EffectType effect, float location) override {
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h: In function 'void SB_Effect(EffectType, float)':
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3516:26: error: 'PlayEffectTrack' was not declared in this scope
3516 | case EFFECT_TRACK: PlayEffectTrack(); return;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3526:17: error: 'OFF_FAST' was not declared in this scope
3526 | Off(OFF_FAST);
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3526:13: error: 'Off' was not declared in this scope
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3528:13: error: 'Off' was not declared in this scope
3528 | Off();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3530:11: error: 'saber_off_time_millis_' was not declared in this scope
3530 | saber_off_time_millis_ = millis();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3549:9: error: 'preon_effect_' was not declared in this scope
3549 | preon_effect_ = true;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3558:13: error: 'FastOn' was not declared in this scope
3558 | FastOn();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3569:13: error: 'On' was not declared in this scope; did you mean 'yn'?
3569 | On();
| yn
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3582:31: error: 'SoundLoop' was not declared in this scope
3582 | case EFFECT_SOUND_LOOP: SoundLoop(); return;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3584:14: error: 'battle_mode_' was not declared in this scope
3584 | if (!battle_mode_) ToggleBattleMode();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3587:13: error: 'battle_mode_' was not declared in this scope
3587 | if (battle_mode_) ToggleBattleMode();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3590:14: error: 'swing_blast_' was not declared in this scope
3590 | if (!swing_blast_) ToggleMultiBlast();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3593:13: error: 'swing_blast_' was not declared in this scope
3593 | if (swing_blast_) ToggleMultiBlast();
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3600:1: error: expected unqualified-id before 'private'
3600 | private:
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3633:3: error: 'ClashType' does not name a type
3633 | ClashType clash_type_ = CLASH_NONE;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3634:3: error: 'MenuType' does not name a type
3634 | MenuType menu_type_ = MENU_TOP;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3637:3: error: 'TrackMode' does not name a type
3637 | TrackMode track_mode_ = PLAYBACK_OFF;
C:\Users\ajbur\Desktop\LIGHTSABER FILES\My Aeryn\extra\ProffieOS\props\saber_sabertrio_buttons.h:3675:1: error: expected declaration before '}' token
3675 | };
Compilation error: redefinition of 'Effect SFX_quote'
Sabertrio uses a heavily modified ProffieOS that I don’t think is up to date and I believe that their prop relies on that OS.
I could be wrong, other people know better than I.
