One button setup
I recently got a new saber from CC sabers. i uploaded my own config from fett263 for a 1 button setup. i know im doing something wrong. when i select only one button for the config the saber wont turn on when pressing the only button it has, but i can twist on and off. when selecting a two button setup with 1 button power and 2 button aux the power button just cycles through sound fonts. pressing and holding power enters edit mode. ill link my config. again im not a pro…still very much a noob so any help would be greatsingle button config
Sounds like your power button is wired to the button2/aux pad.
Just change the powerButtonPin to auxPin at the very button in the button config section and see if that does it.
ok ill try that thanks!
that worked thank you very much!
Glad to hear, you’re welcome :slight_smile:
