Proffie version is 5.9
Wiriing:
3.7v 18650 battery, kill switch, 1 main momentary and 1 aux switch, TRI CREE LED RGB (3 channel led). Resistors for the red and blue dies. In addition, one crystal LED but this seems fine.
Issue: On ignition all 3 LED channels are lit rather than following the presets in the config file. I was expecting one LED lit at a time and to be able to change color channel with button.
Config file:
#define NUM_BLADES 2
#define VOLUME 1000
#define CLASH_THRESHOLD_G 1.0
StyleNormalPtr<WHITE, WHITE, 300, 800>(), "cyan"},
StyleNormalPtr<WHITE, WHITE, 300, 800>(), "blue"},
StyleNormalPtr<RED, WHITE, 300, 800>(),
StyleNormalPtr<WHITE, WHITE, 300, 800>(), "red"},
StylePtr<InOutHelper<EASYBLADE(OnSpark<GREEN>, WHITE), 300, 800> >(),
StyleNormalPtr<WHITE, WHITE, 300, 800>(), "green"},
StyleNormalPtr<WHITE, RED, 300, 800, RED>(),
StyleNormalPtr<WHITE, WHITE, 300, 800>(), "white"},
StyleNormalPtr<AudioFlicker<YELLOW, WHITE>, BLUE, 300, 800>(),
StyleNormalPtr<WHITE, WHITE, 300, 800>(), "yellow"},
StylePtr<InOutSparkTip<EASYBLADE(MAGENTA, WHITE), 300, 800> >(),
StyleNormalPtr<WHITE, WHITE, 300, 800>(), "magenta"},
{ 0, SimpleBladePtr<CreeXPE2RedTemplate<1500>, CreeXPE2GreenTemplate<0>, CreeXPE2BlueTemplate<450>, NoLED, bladePowerPin1, bladePowerPin2, bladePowerPin3, -1>(),
SimpleBladePtr<CreeXPE2WhiteTemplate<550>, NoLED, NoLED, NoLED, bladePowerPin6, -1, -1, -1>()
, CONFIGARRAY(presets) },
