New Seismic Charge Animation and the Remap Function
Yeah, why do you have the same bump 3 times?
Just FYI, this is the same as just “Black”, any AlphaL with a fixed “Int<32768>” is the same as the solid color.
Still not 100% sure what you’re after, guessing you’re sticking above inside something else?
You shouldn’t need to repeat the same bump multiple times, there’s most likely a more efficient method but if you’re happy with the result and not worried about the size of the code then go with it.
Finally was able to record a video of this effect and post it! You can watch it here:
NoSloppy, I am getting a “drop box” error. Is this still active?
Thanks
What’s the error specifically?
When I hit your link to “drop box” it says “ oops something went wrong, try refreshing page”. This is the first time I have come across this. I have tried two different browsers to no avail.
I really hope it isn’t because I shared proffie-dfu-setup.exe with someone and now they’re shutting down my sharing. grrr.
How bout this?
It certainly might be.
Google should know that this binary is harmless by now, but I don’t know how long it will take for this information to trickle down to all their tools.
Thanks NoSloppy, that worked fine!
