New here and looking for Config error help!
What is the 3 step method? Not familiar with that.
It seems to not have posted them all.
I am going to redo the presets and lower the amount of fonts. Then I will get back to you guys.
Three backtick method: Recommended way to post a config file
So redid the config so it was not too big. That uploaded fine.
Downloaded the Madame Leota Voice Pack from NoSloppy (Thank you and coffee sent).
Renamed everything accordingly (At least I thought I did) Got font directory not found.
Config Link
I ran effects on the Serial Monitor and got:
Found clrlst files: 1-27 using 2 digits in subdirs in common
Found mnum files: 1-20 in subdirs in common
Found medit files: one unnumbered file in common
Found vmend files: one unnumbered file in common
Found vmbegin files: one unnumbered file in common
Found ccchange files: one unnumbered file in common
Found ccend files: one unnumbered file in common
Found ccbegin files: one unnumbered file in common
Found bladeout files: one unnumbered file in common
Found bladein files: one unnumbered file in commonD
one listing effects.
SD Card screen shot
Tracks folder screen shot.
Sorry I been having so many questions y’all but I truly appreciate it being new.
“Font directory not found” means literally that.
One (or more) of the directories specified in the config file cannot be found on the SD card.
The “effects” command doesn’t help with this, because it only lists what files were found.
Since all the files were found in “common”, I assume that the font directory (Duel_Bandit_Proffie ?) is the one that was not found on the SD card.
I can’t access the “SD card screen shot”, so I don’t know what it is in there.
(Btw, if you know how to use cmd or powershell, you can just copy-paste directory listings from there rather than using screenshots.)
I had restricted access to the screen shot, it has been removed so you should see it now.
Apologies I am unfamiliar with using cmd or powershell. If you have any references on how I can try to use them.
Duel_Bandit_Proffie is on the SD card. That is the font that usually makes a boot .wav when powered up.
So when do you get “font directory not found” ?
When you boot up?
When you go to the next / previous font?
When you go to a specific font?
When it happens, what does the serial monitor say?
When it boots.
Do I need to run a command on Serial Monitor?
No, you don’t need to run a command, it should tell you what the directory is that it cannot find.
However, sometimes text gets dropped at boot time in the serial monitor. So you may need to use the n (for next preset) and then p (for previous preset) commands to make sure you get all the output. Also make sure to resize the window so you don’t just see the last couple of lines.
So I plugged it in and typed p and n to go thru 2 of them and got this:
SD card is busy, flags= medium
Style RAM = 1412
Scanning sound font: FinalSteps_Proffie NOT FOUND!
Scanning sound font: common NOT FOUND!
Activating polyphonic font.
DISPLAY: Preset: 4
No sounds found: font
Amplifier off.
Battery voltage: 0.14
EVENT: ?47 millis=65796
EVENT MENU TURN RIGHT
Booster off.
Saving Current Preset
Style RAM = 1404
Style RAM = 1404
Scanning sound font: Rescue_Proffie NOT FOUND!
I renamed 2 of the presets and folder on the sd card to see if that made a difference, it did not after uploading the updated config.
UPDATE:
Erased and reformatted the SD card to add the fonts and common all over again. Made sure everything is renamed. Font Directory Not Found error has gone away.
New error is Error in Font Directory. I have gone through all the folders in the SD card and everything seems okay and numbered properly. Where else can I check or might be missing. Also the delay has come back to the SD card but that may just be the SD card now after reformatting.
Serial Monitor remains your friend. The effects command along with just watching the serial monitor in general when switching to the preset.
I got this and not familiar with what I am looking for. The things it says are MISSING, are actually there on the SD. Also, when I scroll thru using “n” or “p” its says Font Directory not found but that error does not happen when booting. Fun stuff!
Found vmend files: one unnumbered file SOME FILES ARE MISSING! 1 != 256 in common
Found vmbegin files: one unnumbered file SOME FILES ARE MISSING! 1 != 256 in common
Found ccchange files: one unnumbered file SOME FILES ARE MISSING! 1 != 256 in common
Found ccend files: one unnumbered file SOME FILES ARE MISSING! 1 != 256 in common
Found endlb files: 1-3 in subdirs in FinalSteps_Proffie
Found lb files: one unnumbered file in subdirs in FinalSteps_Proffie
Found bgnlb files: 1-3 in subdirs in FinalSteps_Proffie
Found endmelt files: one unnumbered file in subdirs in FinalSteps_Proffie
Found melt files: one unnumbered file in subdirs in FinalSteps_Proffie
Found bgnmelt files: one unnumbered file in subdirs in FinalSteps_Proffie
Found enddrag files: 1-4 in subdirs in FinalSteps_Proffie
Found drag files: one unnumbered file in subdirs in FinalSteps_Proffie
Found swingh files: 1-4 using 2 digits in subdirs in FinalSteps_Proffie
Found swingl files: 1-4 using 2 digits in subdirs in FinalSteps_Proffie
Found swng files: 1-16 using 2 digits in subdirs in FinalSteps_Proffie
Found lock files: 1-1 using 2 digits in subdirs in FinalSteps_Proffie
Found out files: 1-4 using 2 digits in subdirs in FinalSteps_Proffie
Found in files: 1-2 using 2 digits in subdirs in FinalSteps_Proffie
Found clsh files: 1-16 using 2 digits in subdirs in FinalSteps_Proffie
Found blst files: 1-6 using 2 digits in subdirs in FinalSteps_Proffie
Found endlock files: 1-4 in subdirs in FinalSteps_Proffie
Found bgnlock files: 1-4 in subdirs in FinalSteps_Proffie
Found font files: one unnumbered file in subdirs in FinalSteps_Proffie
Found stab files: 1-4 in subdirs in FinalSteps_Proffie
Found force files: 1-4 in subdirs in FinalSteps_Proffie
Found hum files: 1-1 using 2 digits in subdirs in FinalSteps_Proffie
Found bladeout files: one unnumbered file SOME FILES ARE MISSING! 1 != 256 in common
Found boot files: 1-5 in subdirs in FinalSteps_Proffie
Found preon files: 1-4 in subdirs in FinalSteps_Proffie
Done listing effects.
IT WORKS!!! Reformatted the SD card with the SD Card Formatter recommended. Earlier I did not use that. Reloaded the same Folders and now there is no lag or error message!!
Thank you to everyone who took time to educate and try to help. This has truly been an eye opening experience. Major props to all of you who do this as a living or professionally.
MTFBWY!! But remember, Peace is a Lie.
