Neopixel blade on LED1?
Is this bad? I am done the whole install and setup and a little afraid to fire it up when I noticed that my other saber is wired up what I remember is the traditional LED2/3. Everything is nice, trim and packed away. Wondering if I need to hack up this beautiful install to move the LED to 2/3 or if I can leave it on just 1. about 135LEDs(x2). Thanks!
So, it depends.
Some users have run full-length blades off of a single FET with no problems.
Some users have had problems with running the main blade from a single FET.
It should work, and it should be safe, so try it, and if it doesn’t work well, try moving it.
ok thanks. It is working great.
