Neopixel Blade Doesn't Light Up
A bit of an overdue update here, now that I’ve finally gotten around to finishing this project. I replaced the Proffie board with one from 123electronics. Once I did that, the saber worked as expected (minus the crystal chamber lighting up, but I think that’s a solder connection issue). It seems it was an issue with the board. Hope this helps someone else.
