#define VOLUME 1000
#define CLASH_THRESHOLD_G 3.0
{ "apocaliypse", "tracks/venus.wav",
{ "Ascension", "tracks/mars.wav",
{ "BreathOfTheWild", "tracks/mercury.wav",
StyleFirePtr<RED, YELLOW>(), "fire"},
{ "CalJFO", "tracks/uranus.wav",
{ "Castle", "tracks/venus.wav",
StyleFirePtr<BLUE, CYAN>(), "blue fire"},
{ "Crimson_Menace", "tracks/Duel of the Fates.wav",
{ "CyberBlade", "tracks/mercury.wav",
{ "Dagan_Dark", "tracks/uranus.wav",
{ "Dagan_HighRepublic", "tracks/venus.wav",
{ "Default", "tracks/mars.wav",
{ "Dolby", "tracks/mercury.wav",
{ "Duke", "tracks/uranus.wav",
{ "Excalibur", "tracks/venus.wav",
&style_pov, "POV"},
{ "Guardian", "tracks/mars.wav",
{ "Halflex", "tracks/mars.wav",
{ "Huyang", "tracks/mars.wav",
{ "Krossguard_TROS", "tracks/mars.wav",
{ "Loth_Hero", "tracks/mars.wav",
{ "Mace", "tracks/mars.wav",
{ "Malak", "tracks/mars.wav",
{ "Nichirin", "tracks/mars.wav",
{ "Organ", "tracks/mars.wav",
{ "Proto", "tracks/mars.wav",
{ "PurgeTrooper", "tracks/mars.wav",
{ "Qui_Gone", "tracks/mars.wav",
{ "Rainbow", "tracks/mars.wav",
{ "seethe", "tracks/mars.wav",
{ "Shan", "tracks/mars.wav",
{ "Shock_Baton_Proffie", "tracks/mars.wav",
{ "Son_Of_Corellia", "tracks/mars.wav",
{ "SorcererV2", "tracks/mars.wav",
{ "Sun_Skoll", "tracks/mars.wav",
{ "TearsOfTheKingdom", "tracks/mars.wav",
{ "The_Lost_One", "tracks/mars.wav",
{ "The_ReturnV2", "tracks/mars.wav",
Thatâs a lot of charging presets, why?
Also, many of the presets donât have commas between them, like on line 43 you have a } at the end, but it should be },. (and on line 45, 47 ⌠83)
it still is saying font directory not found
#define VOLUME 1000
{ "Crimson_Menace", "D:\Crimson_Menace\tracks\Duel of the Fates.wav",
&style_pov, "POV"},
&style_charging, "Battery\nLevel"},
ProffieOS: Control software for lightsabers and other props.
http://fredrik.hubbe.net/lightsaber/teensy_saber.html
Copyright (c) 2016-2019 Fredrik Hubinette
Additional copyright holders listed inline below.
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
| You can have multiple configuration files, and specify which one |
| to use here by removing the two slashes at the beginning. |
| **NOTE** Only ONE line should be left uncommented at a time! |
| Add the slashes to any that you are not using. |
#define CONFIG_FILE "config/configmysaber_config.h"
// #define CONFIG_FILE "config/default_proffieboard_config.h"
// #define CONFIG_FILE "config/default_v3_config.h"
// #define CONFIG_FILE "config/crossguard_config.h"
// #define CONFIG_FILE "config/graflex_v1_config.h"
// #define CONFIG_FILE "config/prop_shield_fastled_v1_config.h"
// #define CONFIG_FILE "config/owk_v2_config.h"
// #define CONFIG_FILE "config/test_bench_config.h"
// #define CONFIG_FILE "config/toy_saber_config.h"
// #define CONFIG_FILE "config/proffieboard_v1_test_bench_config.h"
// #define CONFIG_FILE "config/proffieboard_v2_testing_config.h"
// #define CONFIG_FILE "config/td_proffieboard_config.h"
// #define CONFIG_FILE "config/proffieboard_v1_graflex.h"
// #define CONFIG_FILE "config/teensy_audio_shield_micom.h"
// #define CONFIG_FILE "config/proffieboard_v2_ob4.h"
// #define CONFIG_FILE "config/testconfig.h"
#ifdef CONFIG_FILE_TEST
#undef CONFIG_FILE
#define CONFIG_FILE CONFIG_FILE_TEST
#ifndef CONFIG_FILE
#error Please set CONFIG_FILE as shown above.
#define CONFIG_TOP
#include CONFIG_FILE
#undef CONFIG_TOP
#ifndef BOOT_VOLUME
#define BOOT_VOLUME VOLUME
#ifdef SAVE_STATE
#define SAVE_VOLUME
#define SAVE_PRESET
#define SAVE_COLOR_CHANGE
#define SAVE_BLADE_DIMMING
#ifdef ENABLE_ALL_EDIT_OPTIONS
#define DYNAMIC_BLADE_LENGTH
#define DYNAMIC_BLADE_DIMMING
#define DYNAMIC_CLASH_THRESHOLD
#define SAVE_VOLUME
#define SAVE_CLASH_THRESHOLD
// #define ENABLE_DEBUG
#ifdef KEEP_SAVEFILES_WHEN_PROGRAMMING
#warning Your config file has KEEP_SAVEFILES_WHEN_PROGRAMMING in it. If you experience problems, please remove it and try again before asking for help. For more information, see: https://pod.hubbe.net/config/keeping-edits-when-uploading.html
// OVERVIEW
// Here explain some general code concepts to make it easier
// to understand the code below.
// Most things start with the ProbBase class. Depending on the
// configuration, this class is extended by the Saber class,
// the Detonator class, or some other class. The extended class
// is instantiated as "prop", and is responsible for handling
// button clicks, clashes, swings and other events. These events
// are then send to all registered SaberBase classes.
// Generally speaking, there are usually two registered SaberBase
// classes listening for events. One for sound and one for
// the blade. Sound and blade effects are generally executed
// separately by separate clases.
// Blades are generally handled by one of the child-classes of
// BladeBase. These classes know how many LEDs the current
// blade has, and how to set those LEDs to a given color, but
// they don't actually decide what the blade should look like.
// Instead they just call the current BladeStyle class and
// asks it to set the colors. The BladeStyle classes don't
// need to know what kind of blade is attached, although
// some combinations of BladeBases and BladeStyles just don't
// make any sense.
// Sounds are also abstracted. It starts with scanning a directory
// on the SD card for files that match known patterns of file names.
// The Effect class is responsible for keeping track of all numbered
// files that for a particular filename prefix.
// Once the directory has been scanned, we'll decide how to play
// sounds. In the past, there was one class for handling NEC style
// fonts and another for handling Plecter style fonts. However,
// both of those have now been merged into the HybridFont class
// which can do both. It is also capable of doing some mix and matching,
// so you can use a plecter style hum together with a NEC style
// swing if you so desire. The HybridFont class inherit from
// SaberBase and listen on on/off/clash/etc. events, just like
// BladeBase classes do.
// HybridFont tells the audio subsystem
// to trigger and mix sounds as aproperiate. The sound subsystem
// starts with an DMA channel which feeds data to a digital-to-analog
// converter. Once the data buffer is half-gone, and interrupt is
// triggered in the DAC class, which tries to fill it up by
// reading data from a int16_t AudioStream. Generally, that data
// stream is hooked up to the AudioDynamicMixer class. This
// class is responsible for taking multiple audio inputs,
// summing them up and then adjusting the volume to minimize
// clipping.
// TODO LIST:
// stab detect/effect
// Audio work items:
// select clash from force
// stab effect
// Blade stuff
// better clash
// Allow several blades to share power pins.
// If defined, DAC vref will be 3 volts, resulting in louder sound. (teensy only)
#define LOUD
// You can get better SD card performance by
// activating the USE_TEENSY3_OPTIMIZED_CODE define
// in SD.h in the teensy library, however, my sd card
// did not work with that define.
#include <Arduino.h>
#ifdef TEENSYDUINO
#include <DMAChannel.h>
#include <usb_dev.h>
#ifndef USE_TEENSY4
#include <kinetis.h>
#include <i2c_t3.h>
#else
// This is a hack to let me access the internal stuff..
#define private public
#include <Wire.h>
#undef private
#include <SD.h>
#include <SPI.h>
#ifdef abs
#undef abs
namespace {
template<typename T> constexpr auto abs(T x) -> decltype(-x) {
return x < 0 ? -x : x;
#else // TEENSYDUINO
#define digitalWriteFast digitalWrite
#endif // TEENSYDUINO
#ifdef ARDUINO_ARCH_STM32L4
#include <Wire.h>
#undef private
#include <FS.h>
#include <stm32l4_wiring_private.h>
#include <stm32l4xx.h>
#include <armv7m.h>
#include <stm32l4_gpio.h>
#include <stm32l4_sai.h>
#include <stm32l4_dma.h>
#include <stm32l4_system.h>
#include <arm_math.h>
#include <STM32.h>
#define DMAChannel stm32l4_dma_t
#define DMAMEM
#define NVIC_SET_PRIORITY(X, Y) NVIC_SetPriority((X), (IRQn_Type)(Y))
#else // ARDUINO_ARCH_STM32L4
#define INPUT_ANALOG INPUT
#endif // ARDUINO_ARCH_STM32L4
#include <math.h>
#include <malloc.h>
#ifdef ENABLE_SERIALFLASH
#define protected public
#include <SerialFlash.h>
#undef private
#undef protected
#ifdef ENABLE_SNOOZE
#define startup_early_hook DISABLE_startup_early_hook
#include <Snooze.h>
#undef startup_early_hook
SnoozeTimer snooze_timer;
SnoozeDigital snooze_digital;
SnoozeTouch snooze_touch;
SnoozeBlock snooze_config(snooze_touch, snooze_digital, snooze_timer);
const char version[] = "v7.15";
#include "common/common.h"
#include "common/state_machine.h"
#include "common/monitoring.h"
#include "common/stdout.h"
#include "common/errors.h"
Monitoring monitor;
DEFINE_COMMON_STDOUT_GLOBALS;
void PrintQuotedValue(const char* name, const char* str) {
STDOUT.print(name);
STDOUT.write('=');
if (str) {
while (*str) {
switch (*str) {
case '\n':
STDOUT.print("\\n");
break;
case '\t':
STDOUT.print("\\t");
break;
case '\\':
STDOUT.write('\\');
default:
STDOUT.write(*str);
++str;
STDOUT.write('\n');
#ifdef ENABLE_DEBUG
// This class is really useful for finding crashes
// basically, the pin you give it will be held high
// while this function is running. After that it will
// be set to low. If a crash occurs in this function
// it will stay high.
class ScopedPinTracer {
public:
explicit ScopedPinTracer(int pin)
: pin_(pin) {
pinMode(pin_, OUTPUT);
digitalWriteFast(pin, HIGH);
~ScopedPinTracer() {
digitalWriteFast(pin_, LOW);
private:
int pin_;
class ScopedTracer3 {
public:
explicit ScopedTracer3(int code) {
pinMode(bladePowerPin1, OUTPUT);
pinMode(bladePowerPin2, OUTPUT);
pinMode(bladePowerPin3, OUTPUT);
digitalWriteFast(bladePowerPin1, !!(code & 1));
digitalWriteFast(bladePowerPin2, !!(code & 2));
digitalWriteFast(bladePowerPin3, !!(code & 4));
~ScopedTracer3() {
digitalWriteFast(bladePowerPin1, LOW);
digitalWriteFast(bladePowerPin2, LOW);
digitalWriteFast(bladePowerPin3, LOW);
#include "common/scoped_cycle_counter.h"
#include "common/profiling.h"
uint64_t audio_dma_interrupt_cycles = 0;
uint64_t pixel_dma_interrupt_cycles = 0;
uint64_t motion_interrupt_cycles = 0;
uint64_t wav_interrupt_cycles = 0;
uint64_t loop_cycles = 0;
#include "common/loop_counter.h"
#if defined(ENABLE_SSD1306) || defined(INCLUDE_SSD1306)
#define ENABLE_DISPLAY_CODE
#ifdef DOSFS_CONFIG_STARTUP_DELAY
#define PROFFIEOS_SD_STARTUP_DELAY DOSFS_CONFIG_STARTUP_DELAY
#else
#define PROFFIEOS_SD_STARTUP_DELAY 1000
#ifndef CONFIG_STARTUP_DELAY
#define CONFIG_STARTUP_DELAY 0
#if PROFFIEOS_SD_STARTUP_DELAY > CONFIG_STARTUP_DELAY
#define PROFFIEOS_STARTUP_DELAY PROFFIEOS_SD_STARTUP_DELAY
#else
#define PROFFIEOS_STARTUP_DELAY CONFIG_STARTUP_DELAY
#include "common/linked_list.h"
#include "common/looper.h"
#include "common/command_parser.h"
#include "common/monitor_helper.h"
CommandParser* parsers = NULL;
MonitorHelper monitor_helper;
#include "common/vec3.h"
#include "common/quat.h"
#include "common/ref.h"
#include "common/events.h"
#include "common/saber_base.h"
#include "common/saber_base_passthrough.h"
SaberBase* saberbases = NULL;
SaberBase::LockupType SaberBase::lockup_ = SaberBase::LOCKUP_NONE;
SaberBase::ColorChangeMode SaberBase::color_change_mode_ =
SaberBase::COLOR_CHANGE_MODE_NONE;
bool SaberBase::on_ = false;
uint32_t SaberBase::last_motion_request_ = 0;
uint32_t SaberBase::current_variation_ = 0;
float SaberBase::sound_length = 0.0;
int SaberBase::sound_number = -1;
float SaberBase::clash_strength_ = 0.0;
#ifdef DYNAMIC_BLADE_DIMMING
int SaberBase::dimming_ = 16384;
#include "common/box_filter.h"
// Returns the decimals of a number, ie 12.2134 -> 0.2134
float fract(float x) {
return x - floorf(x);
// clamp(x, a, b) makes sure that x is between a and b.
float clamp(float x, float a, float b) {
if (x < a) return a;
if (x > b) return b;
return x;
float Fmod(float a, float b) {
return a - floorf(a / b) * b;
int32_t clampi32(int32_t x, int32_t a, int32_t b) {
return x;
int16_t clamptoi16(int32_t x) {
return clampi32(x, -32768, 32767);
int32_t clamptoi24(int32_t x) {
return clampi32(x, -8388608, 8388607);
#include "common/sin_table.h"
void EnableBooster();
void EnableAmplifier();
bool AmplifierIsActive();
void MountSDCard();
const char* GetSaveDir();
#include "common/lsfs.h"
#include "common/strfun.h"
// Double-zero terminated array of search paths.
// No trailing slashes!
char current_directory[128];
const char* next_current_directory(const char* dir) {
dir += strlen(dir);
dir++;
if (!*dir) return NULL;
return dir;
const char* last_current_directory() {
const char* ret = current_directory;
while (true) {
const char* tmp = next_current_directory(ret);
if (!tmp) return ret;
ret = tmp;
const char* previous_current_directory(const char* dir) {
if (dir == current_directory) return nullptr;
dir -= 2;
while (true) {
if (dir == current_directory) return current_directory;
if (!*dir) return dir + 1;
dir--;
#include "sound/sound.h"
#include "common/battery_monitor.h"
#include "common/color.h"
#include "common/range.h"
#include "common/fuse.h"
#include "common/config_file.h"
#include "blades/blade_base.h"
#include "blades/blade_wrapper.h"
class MicroEventTime {
void SetToNow() {
micros_ = micros();
millis_ = millis();
uint32_t millis_since() {
return millis() - millis_;
uint32_t micros_since() {
if (millis_since() > (0xFFFF0000UL / 1000)) return 0xFFFFFFFFUL;
return micros() - micros_;
private:
uint32_t millis_;
uint32_t micros_;
template<class T, class U>
struct is_same_type { static const bool value = false; };
template<class T>
struct is_same_type<T, T> { static const bool value = true; };
// This really ought to be a typedef, but it causes problems I don't understand.
#define StyleAllocator class StyleFactory*
#include "styles/rgb.h"
#include "styles/rgb_arg.h"
#include "styles/charging.h"
#include "styles/fire.h"
#include "styles/sparkle.h"
#include "styles/gradient.h"
#include "styles/random_flicker.h"
#include "styles/random_per_led_flicker.h"
#include "styles/audio_flicker.h"
#include "styles/brown_noise_flicker.h"
#include "styles/hump_flicker.h"
#include "styles/rainbow.h"
#include "styles/color_cycle.h"
#include "styles/cylon.h"
#include "styles/ignition_delay.h"
#include "styles/retraction_delay.h"
#include "styles/pulsing.h"
#include "styles/blinking.h"
#include "styles/on_spark.h"
#include "styles/rgb_cycle.h"
#include "styles/clash.h"
#include "styles/lockup.h" // Also does "drag"
#include "styles/blast.h"
#include "styles/strobe.h"
#include "styles/inout_helper.h"
#include "styles/inout_sparktip.h"
#include "styles/colors.h"
#include "styles/mix.h"
#include "styles/style_ptr.h"
#include "styles/file.h"
#include "styles/stripes.h"
#include "styles/random_blink.h"
#include "styles/sequence.h"
#include "styles/byteorder.h"
#include "styles/rotate_color.h"
#include "styles/colorchange.h"
#include "styles/transition_pulse.h"
#include "styles/transition_effect.h"
#include "styles/transition_loop.h"
#include "styles/effect_sequence.h"
#include "styles/color_select.h"
#include "styles/remap.h"
#include "styles/edit_mode.h"
// functions
#include "functions/ifon.h"
#include "functions/change_slowly.h"
#include "functions/int.h"
#include "functions/int_arg.h"
#include "functions/int_select.h"
#include "functions/sin.h"
#include "functions/scale.h"
#include "functions/battery_level.h"
#include "functions/trigger.h"
#include "functions/bump.h"
#include "functions/smoothstep.h"
#include "functions/swing_speed.h"
#include "functions/sound_level.h"
#include "functions/blade_angle.h"
#include "functions/variation.h"
#include "functions/twist_angle.h"
#include "functions/layer_functions.h"
#include "functions/islessthan.h"
#include "functions/circular_section.h"
#include "functions/marble.h"
#include "functions/slice.h"
#include "functions/mult.h"
#include "functions/wavlen.h"
#include "functions/wavnum.h"
#include "functions/effect_position.h"
#include "functions/time_since_effect.h"
#include "functions/sum.h"
#include "functions/ramp.h"
#include "functions/center_dist.h"
#include "functions/linear_section.h"
#include "functions/hold_peak.h"
#include "functions/clash_impact.h"
#include "functions/effect_increment.h"
#include "functions/increment.h"
#include "functions/subtract.h"
#include "functions/divide.h"
#include "functions/isbetween.h"
#include "functions/clamp.h"
#include "functions/alt.h"
#include "functions/volume_level.h"
#include "functions/mod.h"
// transitions
#include "transitions/fade.h"
#include "transitions/join.h"
#include "transitions/concat.h"
#include "transitions/instant.h"
#include "transitions/delay.h"
#include "transitions/wipe.h"
#include "transitions/boing.h"
#include "transitions/random.h"
#include "transitions/colorcycle.h"
#include "transitions/wave.h"
#include "transitions/select.h"
#include "transitions/extend.h"
#include "transitions/center_wipe.h"
#include "transitions/sequence.h"
#include "transitions/blink.h"
#include "transitions/doeffect.h"
#include "transitions/loop.h"
#include "styles/legacy_styles.h"
//responsive styles
#include "styles/responsive_styles.h"
#include "styles/pov.h"
class NoLED;
#include "blades/power_pin.h"
#include "blades/drive_logic.h"
#include "blades/pwm_pin.h"
#include "blades/ws2811_blade.h"
#include "blades/fastled_blade.h"
#include "blades/simple_blade.h"
#include "blades/saviblade.h"
#include "blades/sub_blade.h"
#include "blades/dim_blade.h"
#include "blades/leds.h"
#include "blades/blade_id.h"
#include "common/preset.h"
#include "common/blade_config.h"
#include "common/current_preset.h"
#include "common/status_led.h"
#include "styles/style_parser.h"
#include "styles/length_finder.h"
#include "styles/show_color.h"
#include "styles/blade_shortener.h"
BladeConfig* current_config = nullptr;
class BladeBase* GetPrimaryBlade() {
#if NUM_BLADES == 0
return nullptr;
#else
return current_config->blade1;
const char* GetSaveDir() {
if (!current_config) return "";
if (!current_config->save_dir) return "";
return current_config->save_dir;
ArgParserInterface* CurrentArgParser;
#define CONFIG_STYLES
#undef CONFIG_STYLES
#define CONFIG_PRESETS
#undef CONFIG_PRESETS
#define CONFIG_PROP
#undef CONFIG_PROP
#ifndef PROP_TYPE
#include "props/saber.h"
PROP_TYPE prop;
#ifdef BLADE_ID_SCAN_MILLIS
bool ScanBladeIdNow() {
return prop.ScanBladeIdNow();
#if 0
#include "scripts/test_motion_timeout.h"
#warning MOTION TEST SCRIPT ACTIVE
MotionTimeoutScript script;
#if 0
#include "scripts/v3_test_script.h"
#warning !!! V3 TEST SCRIPT ACTIVE !!!
V3TestScript script;
#include "buttons/floating_button.h"
#include "buttons/latching_button.h"
#include "buttons/button.h"
#ifdef TEENSYDUINO
#include "buttons/touchbutton.h"
#include "buttons/stm32l4_touchbutton.h"
#include "buttons/rotary.h"
#include "buttons/pots.h"
#include "ir/ir.h"
#include "ir/receiver.h"
#include "ir/blaster.h"
#include "ir/print.h"
#include "ir/nec.h"
#include "ir/rc6.h"
#include "ir/stm32_ir.h"
#ifndef TEENSYDUINO
uint32_t startup_AHB1ENR;
uint32_t startup_AHB2ENR;
uint32_t startup_AHB3ENR;
uint32_t startup_APB1ENR1;
uint32_t startup_APB1ENR2;
uint32_t startup_APB2ENR;
uint32_t startup_MODER[4];
#define CONFIG_BUTTONS
#undef CONFIG_BUTTONS
#ifdef BLADE_DETECT_PIN
LatchingButtonTemplate<FloatingButtonBase<BLADE_DETECT_PIN>>
BladeDetect(BUTTON_BLADE_DETECT, BLADE_DETECT_PIN, "blade_detect");
#include "common/sd_test.h"
class I2CDevice;
class Commands : public CommandParser {
public:
enum PinType {
PinTypeFloating,
PinTypePulldown,
PinTypeCap,
PinTypeOther,
bool TestPin(int pin, PinType t) {
int ret = 0;
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW);
delayMicroseconds(20);
ret <<= 1;
ret |= digitalRead(pin);
digitalWrite(pin, HIGH);
ret <<= 1;
// Discharge time
pinMode(pin, INPUT_PULLDOWN);
uint32_t start = micros();
uint32_t end;
while (digitalRead(pin)) {
end = micros();
if (end - start > 32768) break; // 32 millis
ret <<= 16;
ret |= (end - start);
pinMode(pin, INPUT_PULLUP);
ret <<= 1;
pinMode(pin, INPUT);
return ret;
bool Parse(const char* cmd, const char* e) override {
if (!strcmp(cmd, "ls")) {
char tmp[128];
SerialFlashChip::opendir();
uint32_t size;
while (SerialFlashChip::readdir(tmp, sizeof(tmp), size)) {
STDOUT.print(tmp);
STDOUT.print(" ");
STDOUT.println(size);
STDOUT.println("Done listing files.");
return true;
if (!strcmp(cmd, "rm")) {
if (SerialFlashChip::remove(e)) {
STDOUT.println("Removed.\n");
} else {
STDOUT.println("No such file.\n");
return true;
if (!strcmp(cmd, "format")) {
STDOUT.print("Erasing ... ");
SerialFlashChip::eraseAll();
while (!SerialFlashChip::ready())
STDOUT.println("Done");
return true;
#ifdef ENABLE_SD
#ifndef DISABLE_DIAGNOSTIC_COMMANDS
if (!strcmp(cmd, "dir")) {
LOCK_SD(true);
if (!e || LSFS::Exists(e)) {
for (LSFS::Iterator dir(e ? e : ""); dir; ++dir) {
STDOUT.print(dir.name());
STDOUT.print(" ");
STDOUT.println(dir.size());
} else {
STDOUT.println("No such directory.");
LOCK_SD(false);
return true;
if (!strcmp(cmd, "cat") && e) {
LOCK_SD(true);
File f = LSFS::Open(e);
while (f.available()) {
STDOUT.write(f.read());
f.close();
LOCK_SD(false);
return true;
if (!strcmp(cmd, "del") && e) {
LOCK_SD(true);
LSFS::Remove(e);
LOCK_SD(false);
return true;
#ifdef ENABLE_DEVELOPER_COMMANDS
if (!strcmp(cmd, "readalot")) {
uint8_t tmp[10];
LOCK_SD(true);
for (int i = 0; i < 10000; i++) {
f.seek(0);
f.read(tmp, 10);
f.seek(1000);
f.read(tmp, 10);
f.close();
LOCK_SD(false);
return true;
#endif // ENABLE_DEVELOPER_COMMANDS
if (!strcmp(cmd, "sdtest")) {
SDTestHelper sdtester;
if (e && !strcmp(e, "all")) {
sdtester.TestDir("");
} else {
sdtester.TestFont();
return true;
#endif // ENABLE_SD
#if defined(ENABLE_SD) && defined(ENABLE_SERIALFLASH)
if (!strcmp(cmd, "cache")) {
LOCK_SD(true);
if (!f) {
STDOUT.println("File not found.");
return true;
int bytes = f.size();
if (!SerialFlashChip::create(e, bytes)) {
STDOUT.println("Not enough space on serial flash chip.");
return true;
SerialFlashFile o = SerialFlashChip::open(e);
while (bytes) {
char tmp[256];
int b = f.read(tmp, min(bytes, (int)NELEM(tmp)));
o.write(tmp, b);
bytes -= b;
LOCK_SD(false);
STDOUT.println("Cached!");
return true;
if (!strcmp(cmd, "effects")) {
Effect::ShowAll();
return true;
#if 0
if (!strcmp(cmd, "df")) {
STDOUT.print(SerialFlashChip::capacity());
STDOUT.println(" bytes available.");
return true;
if (!strcmp(cmd, "high") && e) {
pinMode(atoi(e), OUTPUT);
digitalWrite(atoi(e), HIGH);
STDOUT.println("Ok.");
return true;
if (!strcmp(cmd, "low") && e) {
digitalWrite(atoi(e), LOW);
return true;
#if VERSION_MAJOR >= 4
if (!strcmp(cmd, "booster")) {
if (!strcmp(e, "on")) {
digitalWrite(boosterPin, HIGH);
STDOUT.println("Booster on.");
return true;
if (!strcmp(e, "off")) {
digitalWrite(boosterPin, LOW);
STDOUT.println("Booster off.");
return true;
#ifdef ENABLE_AUDIO
#if 0
if (!strcmp(cmd, "ton")) {
EnableAmplifier();
dac.SetStream(&saber_synth);
saber_synth.on_ = true;
return true;
if (!strcmp(cmd, "tof")) {
saber_synth.on_ = false;
return true;
if (!strcmp(cmd, "dumpwav")) {
int16_t tmp[32];
wav_players[0].Stop();
wav_players[0].read(tmp, NELEM(tmp));
wav_players[0].Play(e);
for (int j = 0; j < 64; j++) {
int k = wav_players[0].read(tmp, NELEM(tmp));
for (int i = 0; i < k; i++) {
STDOUT.print(tmp[i]);
STDOUT.print(" ");
STDOUT.println("");
return true;
if (!strcmp(cmd, "dumpwavplayer")) {
for (size_t i = 0; i < NELEM(wav_players); i++) {
if (e && atoi(e) != (int)i) continue;
wav_players[i].dump();
return true;
if (!strcmp(cmd, "sleep") && e) {
delay(atoi(e));
return true;
if (!strcmp(cmd, "twiddle")) {
int pin = strtol(e, NULL, 0);
STDOUT.print("twiddling ");
STDOUT.println(pin);
for (int i = 0; i < 1000; i++) {
delay(10);
delay(10);
STDOUT.println("done");
return true;
if (!strcmp(cmd, "twiddle2")) {
for (int i = 0; i < 500; i++) {
delayMicroseconds(1);
delay(10);
return true;
if (!strcmp(cmd, "malloc")) {
STDOUT.print("alloced: ");
STDOUT.println(mallinfo().uordblks);
STDOUT.print("Free: ");
STDOUT.println(mallinfo().fordblks);
return true;
if (!strcmp(cmd, "make_default_console")) {
default_output = stdout_output;
return true;
#if 0
// Not finished yet
if (!strcmp(cmd, "selftest")) {
struct PinDefs { int8_t pin; PinType type; };
static PinDefs pin_defs[] = {
{ bladePowerPin1, PinTypePulldown },
{ bladePowerPin2, PinTypePulldown },
{ bladePowerPin3, PinTypePulldown },
{ bladePowerPin4, PinTypePulldown },
{ bladePowerPin5, PinTypePulldown },
{ bladePowerPin6, PinTypePulldown },
{ bladePin, PinTypeOther },
{ blade2Pin, PinTypeFloating },
{ blade3Pin, PinTypeFloating },
{ blade4Pin, PinTypeFloating },
{ blade5Pin, PinTypeFloating },
{ amplifierPin, PinTypeFloating },
{ boosterPin, PinTypeFloating },
{ powerButtonPin, PinTypeFloating },
{ auxPin, PinTypeFloating },
{ aux2Pin, PinTypeFloating },
{ rxPin, PinTypeOther },
{ txPin, PinTypeFloating },
for (size_t test_index = 0; test_index < NELEM(pin_defs); test_index++) {
int pin = pin_defs[test_index].pin;
for (size_t i = 0; i < NELEM(pin_defs); i++)
pinMode(pin_defs[i].pin, INPUT);
// test
for (size_t i = 0; i < NELEM(pin_defs); i++) {
pinMode(pin_defs[i].pin, OUTPUT);
digitalWrite(pin_defs[i].pin, HIGH);
// test
digitalWrite(pin_defs[i].pin, LOW);
// test
if (!strcmp(cmd, "top")) {
#ifdef TEENSYDUINO
if (!(ARM_DWT_CTRL & ARM_DWT_CTRL_CYCCNTENA)) {
ARM_DEMCR |= ARM_DEMCR_TRCENA;
ARM_DWT_CTRL |= ARM_DWT_CTRL_CYCCNTENA;
STDOUT.println("Cycle counting enabled, top will work next time.");
return true;
if (!(DWT->CTRL & DWT_CTRL_CYCCNTENA_Msk)) {
CoreDebug->DEMCR |= 1 << 24; // DEMCR_TRCENA_Msk;
DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk;
return true;
// TODO: list cpu usage for various objects.
float total_cycles =
(float)(audio_dma_interrupt_cycles + pixel_dma_interrupt_cycles + motion_interrupt_cycles + wav_interrupt_cycles + Looper::CountCycles() + CountProfileCycles());
STDOUT.print("Audio DMA: ");
STDOUT.print(audio_dma_interrupt_cycles * 100.0f / total_cycles);
STDOUT.println("%");
STDOUT.print("Wav reading: ");
STDOUT.print(wav_interrupt_cycles * 100.0f / total_cycles);
STDOUT.print("Pixel DMA: ");
STDOUT.print(pixel_dma_interrupt_cycles * 100.0f / total_cycles);
STDOUT.print("LOOP: ");
STDOUT.print(loop_cycles * 100.0f / total_cycles);
STDOUT.print("Motion: ");
STDOUT.print(motion_interrupt_cycles * 100.0f / total_cycles);
STDOUT.print("Global loops / second: ");
global_loop_counter.Print();
STDOUT.println("");
STDOUT.print("High frequency loops / second: ");
hf_loop_counter.Print();
STDOUT.println("");
SaberBase::DoTop(total_cycles);
Looper::LoopTop(total_cycles);
DumpProfileLocations(total_cycles);
noInterrupts();
interrupts();
return true;
if (!strcmp(cmd, "version")) {
STDOUT << version
<< "\n" CONFIG_FILE "\nprop: " TOSTRING(PROP_TYPE) "\nbuttons: " TOSTRING(NUM_BUTTONS) "\ninstalled: "
<< install_time << "\n";
return true;
if (!strcmp(cmd, "reset")) {
#ifdef TEENSYDUINO
SCB_AIRCR = 0x05FA0004;
STM32.reset();
STDOUT.println("Reset failed.");
return true;
if (!strcmp(cmd, "shutdown")) {
STDOUT.println("Sleeping 10 seconds.\n");
STM32.stop(100000);
return true;
if (!strcmp(cmd, "RebootDFU")) {
stm32l4_system_dfu();
return true;
if (!strcmp(cmd, "dumpfusor")) {
fusor.dump();
return true;
if (!strcmp(cmd, "stm32info")) {
STDOUT.print("VBAT: ");
STDOUT.println(STM32.getVBAT());
STDOUT.print("VREF: ");
STDOUT.println(STM32.getVREF());
STDOUT.print("TEMP: ");
STDOUT.println(STM32.getTemperature());
return true;
if (!strcmp(cmd, "i2cstate")) {
extern void DumpI2CState();
DumpI2CState();
SaberBase::DumpMotionRequest();
return true;
if (!strcmp(cmd, "portstates")) {
GPIO_TypeDef* GPIO;
for (int i = 0; i < 4; i++) {
switch (i) {
case 0:
GPIO = (GPIO_TypeDef*)GPIOA_BASE;
STDOUT.print("PORTA: ");
break;
case 1:
GPIO = (GPIO_TypeDef*)GPIOB_BASE;
STDOUT.print("PORTB: ");
break;
case 2:
GPIO = (GPIO_TypeDef*)GPIOC_BASE;
STDOUT.print("PORTC: ");
break;
case 3:
GPIO = (GPIO_TypeDef*)GPIOH_BASE;
STDOUT.print("PORTH: ");
break;
for (int j = 15; j >= 0; j--) {
uint32_t now = (GPIO->MODER >> (j * 2)) & 3;
uint32_t saved = (startup_MODER[i] >> (j * 2)) & 3;
STDOUT.print((now == saved ? "ioga" : "IOGA")[now]);
if (!(j & 3)) STDOUT.print(" ");
STDOUT.print(" ");
uint32_t now = (GPIO->PUPDR >> (j * 2)) & 3;
STDOUT.print("-ud?"[now]);
STDOUT.print(" ");
uint32_t now = ((GPIO->IDR >> j) & 1) | (((GPIO->ODR >> j) & 1) << 1);
STDOUT.print("lhLH"[now]);
STDOUT.print(" ");
int afr = 0xf & (GPIO->AFR[j >> 3] >> ((j & 7) * 4));
STDOUT.print("0123456789ABCDEF"[afr]);
STDOUT.println("");
return true;
if (!strcmp(cmd, "CLK")) {
if (e) {
uint32_t c = atoi(e) * 1000000;
stm32l4_system_sysclk_configure(c, c / 2, c / 2);
STDOUT.print("Clocks: hse=");
STDOUT.print(stm32l4_system_hseclk());
STDOUT.print(" lse=");
STDOUT.print(stm32l4_system_lseclk());
STDOUT.print(" sys=");
STDOUT.print(stm32l4_system_sysclk());
STDOUT.print(" f=");
STDOUT.print(stm32l4_system_fclk());
STDOUT.print(" h=");
STDOUT.print(stm32l4_system_hclk());
STDOUT.print(" p1=");
STDOUT.print(stm32l4_system_pclk1());
STDOUT.print(" p2=");
STDOUT.print(stm32l4_system_pclk2());
STDOUT.print(" sai=");
STDOUT.println(stm32l4_system_saiclk());
return true;
if (!strcmp(cmd, "whatispowered")) {
STDOUT.print("ON: ");
#define PRINTIFON(REG, BIT) \
do { \
if (RCC->REG & RCC_##REG##_##BIT##EN) { \
STDOUT.print(" " #BIT); \
if (!(startup_##REG & RCC_##REG##_##BIT##EN)) STDOUT.print("+"); \
} while (0)
PRINTIFON(AHB1ENR, FLASH);
PRINTIFON(AHB1ENR, DMA1);
PRINTIFON(AHB1ENR, DMA2);
PRINTIFON(AHB2ENR, GPIOA);
PRINTIFON(AHB2ENR, GPIOB);
#ifdef GPIOC_BASE
PRINTIFON(AHB2ENR, GPIOC);
#ifdef GPIOD_BASE
PRINTIFON(AHB2ENR, GPIOD);
#ifdef GPIOE_BASE
PRINTIFON(AHB2ENR, GPIOE);
#if defined(STM32L476xx) || defined(STM32L496xx)
PRINTIFON(AHB2ENR, GPIOF);
PRINTIFON(AHB2ENR, GPIOG);
PRINTIFON(AHB2ENR, GPIOH);
#if defined(STM32L496xx)
PRINTIFON(AHB2ENR, GPIOI);
PRINTIFON(AHB2ENR, ADC);
PRINTIFON(APB1ENR1, DAC1);
PRINTIFON(AHB2ENR, OTGFS);
#else
PRINTIFON(APB1ENR1, USBFS);
PRINTIFON(APB2ENR, USART1);
PRINTIFON(APB1ENR1, USART2);
#if defined(STM32L433xx) || defined(STM32L476xx) || defined(STM32L496xx)
PRINTIFON(APB1ENR1, USART3);
PRINTIFON(APB1ENR1, UART4);
PRINTIFON(APB1ENR1, UART5);
PRINTIFON(APB1ENR2, LPUART1);
PRINTIFON(APB1ENR1, I2C1);
PRINTIFON(APB1ENR1, I2C2);
PRINTIFON(APB1ENR1, I2C3);
PRINTIFON(APB1ENR2, I2C4);
PRINTIFON(APB2ENR, SPI1);
PRINTIFON(APB1ENR1, SPI2);
PRINTIFON(APB1ENR1, SPI3);
PRINTIFON(APB1ENR1, CAN1);
PRINTIFON(APB1ENR1, CAN2);
PRINTIFON(AHB3ENR, QSPI);
PRINTIFON(APB2ENR, SDMMC1);
PRINTIFON(APB2ENR, SAI1);
PRINTIFON(APB2ENR, SAI2);
PRINTIFON(APB2ENR, DFSDM1);
PRINTIFON(APB2ENR, TIM1);
PRINTIFON(APB1ENR1, TIM2);
#ifdef TIM3_BASE
PRINTIFON(APB1ENR1, TIM3);
#ifdef TIM4_BASE
PRINTIFON(APB1ENR1, TIM4);
#ifdef TIM5_BASE
PRINTIFON(APB1ENR1, TIM5);
PRINTIFON(APB1ENR1, TIM6);
#ifdef TIM7_BASE
PRINTIFON(APB1ENR1, TIM7);
#ifdef TIM8_BASE
PRINTIFON(APB2ENR, TIM8);
PRINTIFON(APB2ENR, TIM15);
PRINTIFON(APB2ENR, TIM16);
PRINTIFON(APB2ENR, TIM17);
PRINTIFON(APB1ENR1, LPTIM1);
PRINTIFON(APB1ENR2, LPTIM2);
// Not sure what CPUs implement these
PRINTIFON(AHB1ENR, CRC);
PRINTIFON(AHB1ENR, TSC);
PRINTIFON(AHB2ENR, RNG);
#ifdef LCD_BASE
PRINTIFON(APB1ENR1, LCD);
PRINTIFON(APB1ENR1, RTCAPB);
PRINTIFON(APB1ENR1, WWDG);
PRINTIFON(APB1ENR1, CRS);
PRINTIFON(APB1ENR1, PWR);
PRINTIFON(APB1ENR1, OPAMP);
#ifdef SWPMI1_BASE
PRINTIFON(APB1ENR2, SWPMI1);
PRINTIFON(APB2ENR, SYSCFG);
PRINTIFON(APB2ENR, FW);
STDOUT.println("");
STDOUT.print("VBUS: ");
STDOUT.println(stm32l4_gpio_pin_read(GPIO_PIN_PB2));
STDOUT.print("USBD connected: ");
STDOUT.println(USBD_Connected());
return true;
#ifdef HAVE_STM32L4_DMA_GET
if (!strcmp(cmd, "dmamap")) {
for (int channel = 0; channel < 16; channel++) {
stm32l4_dma_t* dma = stm32l4_dma_get(channel);
if (dma) {
STDOUT.print(" DMA");
STDOUT.print(1 + (channel / 8));
STDOUT.print("_CH");
STDOUT.print(channel % 8);
STDOUT.print(" = ");
STDOUT.println(dma->channel >> 4, HEX);
return true;
#endif // HAVE_STM32L4_DMA_GET
return false;
StaticWrapper<Commands> commands;
#include "common/serial.h"
#if defined(ENABLE_MOTION) || defined(ENABLE_DISPLAY_CODE)
#include "common/i2cdevice.h"
I2CBus i2cbus;
#ifdef ENABLE_SSD1306
#include "display/ssd1306.h"
#ifndef DISPLAY_POWER_PINS
#define DISPLAY_POWER_PINS PowerPINS<>
StandardDisplayController<128, uint32_t> display_controller;
SSD1306Template<128, uint32_t, DISPLAY_POWER_PINS> display(&display_controller);
#ifdef INCLUDE_SSD1306
#ifdef ENABLE_MOTION
#include "motion/motion_util.h"
#include "motion/mpu6050.h"
#include "motion/lsm6ds3h.h"
#include "motion/fxos8700.h"
#include "motion/fxas21002.h"
// Define this to record clashes to sd card as CSV files
// #define CLASH_RECORDER
#ifdef GYRO_CLASS
// Can also be gyro+accel.
StaticWrapper<GYRO_CLASS> gyroscope;
#ifdef ACCEL_CLASS
StaticWrapper<ACCEL_CLASS> accelerometer;
#endif // ENABLE_MOTION
#include "sound/amplifier.h"
#include "common/sd_card.h"
#include "common/booster.h"
void setup() {
#define SAVE_RCC(X) startup_##X = RCC->X
SAVE_RCC(AHB1ENR);
SAVE_RCC(AHB2ENR);
SAVE_RCC(AHB3ENR);
SAVE_RCC(APB1ENR1);
SAVE_RCC(APB1ENR2);
SAVE_RCC(APB2ENR);
#define SAVE_MODER(PORT, X) startup_MODER[X] = ((GPIO_TypeDef*)GPIO##PORT##_BASE)->MODER
SAVE_MODER(A, 0);
SAVE_MODER(B, 1);
SAVE_MODER(C, 2);
SAVE_MODER(H, 3);
// TODO enable/disable as needed
pinMode(boosterPin, OUTPUT);
Serial.begin(115200);
// TODO: Figure out if we need this.
// Serial.blockOnOverrun(false);
// Wait for all voltages to settle.
// Accumulate some entrypy while we wait.
uint32_t now = millis();
while (millis() - now < PROFFIEOS_STARTUP_DELAY) {
#ifndef NO_BATTERY_MONITOR
srand((rand() * 917823) ^ LSAnalogRead(batteryLevelPin));
// Figure out if blade is connected or not.
// Note that if PROFFIEOS_STARTUP_DELAY is smaller than
// the settle time for BladeDetect, this won't work properly.
BladeDetect.Warmup();
SerialFlashChip::begin(serialFlashSelectPin);
#ifdef ENABLE_SD
bool sd_card_found = LSFS::Begin();
if (!sd_card_found) {
if (sdCardSelectPin >= 0 && sdCardSelectPin < 255) {
STDOUT.println("No sdcard found.");
pinMode(sdCardSelectPin, OUTPUT);
digitalWrite(sdCardSelectPin, 0);
delayMicroseconds(2);
pinMode(sdCardSelectPin, INPUT);
if (digitalRead(sdCardSelectPin) != HIGH) {
STDOUT.println("SD select not pulled high!");
stm32l4_gpio_pin_configure(GPIO_PIN_PA5, (GPIO_PUPD_PULLUP | GPIO_OSPEED_HIGH | GPIO_MODE_INPUT));
delayMicroseconds(10);
if (!stm32l4_gpio_pin_read(GPIO_PIN_PA5)) {
STDOUT.println("SCK won't go high!");
stm32l4_gpio_pin_configure(GPIO_PIN_PA5, (GPIO_PUPD_PULLDOWN | GPIO_OSPEED_HIGH | GPIO_MODE_INPUT));
if (stm32l4_gpio_pin_read(GPIO_PIN_PA5)) {
STDOUT.println("SCK won't go low!");
} else {
STDOUT.println("Sdcard found..");
Looper::DoSetup();
// Time to identify the blade.
prop.FindBlade();
SaberBase::DoBoot();
if (!sd_card_found) ProffieOSErrors::sd_card_not_found();
#endif // ENABLE_SD
#ifdef MTP_RX_ENDPOINT
void mtp_yield() {
Looper::DoLoop();
void mtp_lock_storage(bool lock) {
AudioStreamWork::LockSD(lock);
#include "mtp/mtpd.h"
MTPD mtpd;
#ifdef ENABLE_SD
#include "mtp/mtp_storage_sd.h"
MTPStorage_SD sd_storage(&mtpd);
#include "mtp/mtp_storage_serialflash.h"
MTPStorage_SerialFlash serialflash_storage(&mtpd);
#endif // MTP_RX_ENDPOINT
#include "common/clock_control.h"
void loop() {
mtpd.loop();
Looper::DoLoop();
#define CONFIG_BOTTOM
#undef CONFIG_BOTTOM
#define PROFFIEOS_DEFINE_FUNCTION_STAGE
Do you actually have all these fonts on your SD card?
This seems to be the font you have, but the config file says:
Might work better without the extra i.
this is my sd card
Folders:
- apocaliypse
- Ascension
- BreathOfTheWild
- CalJFO
- Castle
- common
- Crimson_Menace
- CyberBlade
- Dagan_Dark
- Dagan_HighRepublic
- Default
- Dolby
- Duke
- Excalibur
- Final_Steps
- Guardian
- Halflex
- Huyang
- Krossguard_TROS
- Loth_Hero
- Mace
- Malak
- Nichirin
- Organ
- Proto
- PurgeTrooper
- Qui_Gone
- Rainbow
- seethe
- Shan
- Shock_Baton_Profile
- Son_Of_Corellia
- SorcererV2
- Sun_Skoll
- TearsOfTheKingdom
- The_Lost_One
- The_ReturnV2
- tracks
- VTS
Files:
- curstate.ini
- curstate.tmp
- gesture.ini
- gesture.tmp
- presets.ini
- presets.tmp
still is saying font directory not found and now im just lost
Which preset is it saying this for?
All of them?
The first one?
If you type pwd in the serial monitor, what does it say?
ill be honest i have no clue and i dont know what a serial monitor is
In proffieOS:
Serial Monitor is a choice in the dropdown menu Tools (at the top). It letâs you type in commands that will either tell your saber what to do, or read what itâs doing.
Do you have a voicepack in your common folder ? Or what do you have in your common folder ?
default voicepacks can be found here:
https://fredrik.hubbe.net/lightsaber/sound/
Maybe post your latest config or is it the same as above ?
If the voice pack was missing, it would say âerror in font directoryâ rather than âfont directory not foundâ.
Sorry about that, I know both messages but Iâm still getting those two error messages confused. They look a bit too similar to one another, IMHO.
all it said was teensySF, and when i used list_presets it showed wrong preesets
It must be reading it from presets.ini/tmp then.
Try removing those two files from the SD card and try again.
its saying In file included from C:\Users\Quentin\Downloads\ProffieOS-v7.15\ProffieOS\ProffieOS.ino:57:
C:\Users\user\Downloads\ProffieOS-v7.15\ProffieOS\config\configmysaber_config.h:2:10: fatal error: proffieboard_v2_config.h: No such file or directory
2 | #include âproffieboard_v2_config.hâ
compilation terminated.
Compilation error: proffieboard_v2_config.h: No such file or directory
It canât find âproffieboard_v2_config.hâ, itâs supposed to be in your config directory.
If you donât know what happened to it, I suggest re-downloading/extracting ProffieOS again.
good news it works bad news there are no motion controles like to ignight the saber, i cant change the sabers volume, i cant change blade colors, some of the presets lack color, other presets blades dont ignite and have a weird blue light that just is there on the blade while a voiceline is active
That would because you are missing defines and/or using the default saber prop that doesnât have motion control, if you look in your prop folder, you have many props to choose from and to set it up, read this:
I would suggest saber_sabersense_buttons.h as it is really easy for beginners to understand. And to know what defines you need for that prop and how to control it, open saber_sabersense_buttons.h in your text editor and read the top section.
thatâs weird, did you read the top section of saber.h (from your prop folder) ?
That is because you are using old blade styles that canât change colors.
that is probably the POV, it will be black but it will show
this
https://crucible.hubbe.net/uploads/default/original/2X/f/f028e0b025a3684a018b560bd6c79af67a0c15fe.jpeg
when you swing it (I think) using retina âpersistence of visionâ or POV
that is from all your &style_charging the blue led is an indication of how charged your battery is (only one &style_charging, preferably on your last preset, so it is easy to find) , not exactly a âblade styleâ but more for information
