MY blade and illuminated pcb are not lighting up
battery is fully charged and the illuminated switch is still lighting but the pcb and the blade doesn’t light up, I haved tested the 2 blades I have and neither are lighting. I even reverted back to the original config and still nothing. the data line and the negatives have continuity but I can’t get to the positive line.
is there anything on the serial monitor I can check to see why this is not lighting up?
How do you have it wired up?
Is your positive line wired directly to the battery or somewhere else?
Not sure i bought this so I’m have to ask them.
