Multiple trloop.wav issiue
give me a few hours and ill run both tests
version
Unmounting SD Card.
Amplifier off.
I2C init..
Motion chip ... 106 found.
EVENT: Clash millis=1355
Welcome to ProffieOS v7.15
Booster off.
v7.15
config/Crossguard.h
prop: SaberFett263Buttons
buttons: 2
installed: Dec 17 2025 13:01:47
Battery voltage: 0.16
attempting user 5 with visual, nothing happens
Battery voltage: 0.21
EVENT: Aux-Pressed#1 millis=224046
EVENT: Aux-Pressed millis=224046
EVENT: Aux-Released#1 millis=224182
EVENT: Aux-Released millis=224182
EVENT: Aux-Shortclick#1 millis=224182
EVENT: Aux-Shortclick millis=224182
Saving Current EVENT: ?47 millis=232921
EVENT MENU TURN RIGHT
Booster off.
EVENT: Power-Pressed#1 millis=236923
EVENT: Power-Pressed millis=236923
EVENT: ?48 mods Power millis=236938
EVENT MENU TURN LEFT
EVENT: ?47 millis=237431
EVENT: Power-Released#1 millis=237903
EVENT: Power-Released millis=237903
EVENT: ?48 millis=238618
Battery voltage: 0.23
EVENT: Power-Pressed#1 millis=253417
EVENT: Power-Pressed millis=253417
EVENT: Power-Released#1 millis=253590
EVENT: Power-Released millis=253590
EVENT: Power-Shortclick#1 millis=253590
EVENT: Power-Shortclick millis=253590
Ignition.
unit = 0 vol = 0.00, Playing Test2/hum01.wav
unit = 1 vol = 0.50, Playing Test2/out/out01.wav
humstart: 100
EVENT: Power-Pressed#1 ON millis=255879
EVENT: Power-Pressed ON millis=255879
EVENT: Power-Held#1 ON millis=256181
EVENT: Power-Held ON millis=256181
EVENT: ?47 mods Power ON millis=256200
EVENT: Power-Released#1 ON millis=256578
EVENT: Power-Released ON millis=256578
EVENT: Power-Pressed#1 ON millis=258114
EVENT: Power-Pressed ON millis=258114
EVENT: ?48 mods Power ON millis=258294
EVENT: ?48 ON millis=258500
EVENT: Power-Released#1 ON millis=258865
EVENT: Power-Released ON millis=258865
EVENT: ?47 ON millis=259216
EVENT: Power-Pressed#1 ON millis=259940
EVENT: Power-Pressed ON millis=259940
Battery voltage: 0.13
EVENT: Power-Released#1 ON millis=260092
EVENT: Power-Released ON millis=260092
EVENT: Power-Shortclick#1 ON millis=260092
unit = 1 vol = 0.50, Playing Test2/in/in01.wav
No sounds found: pstoff
Unmounting SD Card.
Amplifier off.
EVENT: Power-Pressed#1 millis=261730
EVENT: Power-Pressed millis=261730
EVENT: ?47 mods Power millis=262008
EVENT: ?47 millis=262268
EVENT: Power-Released#1 millis=262628
EVENT: Power-Released millis=262628
EVENT: ?48 millis=262872
EVENT: ?48 millis=263849
Booster off.
What’s the style you tried?
StylePtr<Layers<
Red,
ColorSelect<EffectIncrementF<EFFECT_USER5,Int<2>>,TrFade<100>,AlphaL<Black,Int<0>>,AlphaL<Rgb<255,227,60>,SparkleF<70,800>>>,
TransitionEffectL<TrDoEffect<TrInstant,EFFECT_SOUND_LOOP,0>,EFFECT_USER5>,
InOutTrL<TrInstant,TrInstant>
I was thinking more in a TransitionEffectL<> so the mechanism to trigger is the same.
Try this instead of the ColorSelect.
TransitionEffectL<TrConcat<TrInstant,Green,TrFade<1000>>,EFFECT_USER5>
I will not be testing on this problem anymore, i have been working on my lightsaber 24/7 for three months straight now and today i finished it, with it being the first thing i ever programmed im quite burnout on anything tech. Sorry to leave you in the middle of investigating but im done with this problem for at least a month. In a few days ill upload anything from my config i deem worthy here and go afk.
Thanks again for all the help and sorry for leaving you but i have been obsessively at it for so long it is starting to significantly impact my health
