Hi all,
so I noticed that if I try to connect my proffieboard without the sdcard I get this error.
I hit the cancel but it keeps on popping up.
now I believe it is because I uploaded the config to have serial + mass storage which means that if i use an sdcard reader I will then need to have the sd card mounted to the proffieboard. right?
This is a known problem. It hasn’t been very high priority to fix it because most people do have an sd card in the proffie when programming it.
Workarounds include:
- Put the sd card back in the proffie before attaching to a computer.
- Reprogram the proffie without the mass storage option.
- Ignore the error as programming works anyways.
I wasn’t sure if it was known but thanks that’s what I do.
