I can’t figure out why this layer is not showing. Works on 5.9.
Using stock saber.h prop. This is the Lockup:
TransitionEffectL<TrConcat<TrInstant,Strobe<GreenYellow,Black,20,30>,TrFade<200>,BrownNoiseFlickerL<AlphaL<White,Int<16000>>,Int<5000>>,TrJoinR<TrWipe<200>,TrWipeIn<200>,TrFade<300>>>,EFFECT_LOCKUP_END>,
LockupTrL<Layers<
// Bottom Layer Bump - random width
AlphaL<Blinking<Tomato,Strobe<Yellow,Black,15,30>,60,500>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<8000>,Int<18000>>>>,
// Top Layer bump - fixed width
AlphaL<Blinking<BrownNoiseFlicker<White,Black,50>,BrownNoiseFlicker<Yellow,Tomato,50>,100,500>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<9000>>>>,
// Begin Lockup Transition
TrConcat<TrInstant,AlphaL<Blinking<White,Strobe<BrownNoiseFlicker<Yellow,Black,500>,Black,15,30>,60,500>,Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Scale<SlowNoise<Int<3000>>,Int<25000>,Int<32000>>>>,TrFade<500>>,
// End Lockup Transition
TrSmoothFade<900>,SaberBase::LOCKUP_NORMAL>,
TransitionEffectL<TrConcat<TrInstant,AlphaL<Strobe<GreenYellow,Black,20,30>, Bump<Scale<BladeAngle<5000,28000>,Scale<BladeAngle<8000,16000>,Int<3000>,Int<44000>>,Int<3000>>,Int<15000>>>,TrFade<600>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<Strobe<AlphaL<White,Int<20000>>,Black,20,30>,30>,TrSmoothFade<250>>,EFFECT_LOCKUP_BEGIN>,
TransitionEffectL<TrConcat<TrInstant,GreenYellow,TrDelay<25>>,EFFECT_LOCKUP_BEGIN>
Serial monitor is no help here. Any idea what to look for? Could someone test it?
The first line, the EFFECT_LOCKUP_END should show a flash of GreenYellow with a BrownNoiseFlicker being Wiped from center.
All I’m getting is the TrSmoothfade<900> of the impact location bump.
EFFECT_LOCKUP_BEGINs all showing fine.
Thanks.
-Stumped
