When I use the ProffieOS from the repo here: GitHub - profezzorn/ProffieOS: Lightsaber Controller Software
I’m getting these errors when compiling for Teensy 4.0:
Arduino: 1.8.9 (Windows 10), TD: 1.53, Board: “Teensy 4.0, Serial, 600 MHz, Faster, US English”
In file included from C:\Users\tomti\AppData\Local\Temp\arduino_build_78389\sketch\sound/hybrid_font.h:3:0,
from C:\Users\tomti\AppData\Local\Temp\arduino_build_78389\sketch\sound/sound.h:77,
from C:\Users\tomti\OneDrive\Desktop\5X Micom\ProffieOS\ProffieOS.ino:366:
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:305:22: error: ‘ACCEL_MEASUREMENTS_PER_SECOND’ was not declared in this scope
Extrapolator<Vec3, ACCEL_MEASUREMENTS_PER_SECOND/filter_hz> accel_extrapolator_;
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:305:61: error: template argument 2 is invalid
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:306:22: error: ‘GYRO_MEASUREMENTS_PER_SECOND’ was not declared in this scope
Extrapolator<Vec3, GYRO_MEASUREMENTS_PER_SECOND/filter_hz> gyro_extrapolator_;
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:306:60: error: template argument 2 is invalid
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h: In member function ‘void Fusor::DoMotion(const Vec3&, bool)’:
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:68:26: error: request for member ‘clear’ in ‘((Fusor*)this)->Fusor::gyro_extrapolator_’, which is of non-class type ‘int’
gyro_extrapolator_.clear(gyro);
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:70:26: error: request for member ‘push’ in ‘((Fusor*)this)->Fusor::gyro_extrapolator_’, which is of non-class type ‘int’
gyro_extrapolator_.push(gyro);
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h: In member function ‘void Fusor::DoAccel(const Vec3&, bool)’:
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:76:27: error: request for member ‘clear’ in ‘((Fusor*)this)->Fusor::accel_extrapolator_’, which is of non-class type ‘int’
accel_extrapolator_.clear(accel);
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:79:27: error: request for member ‘push’ in ‘((Fusor*)this)->Fusor::accel_extrapolator_’, which is of non-class type ‘int’
accel_extrapolator_.push(accel);
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h: In member function ‘virtual void Fusor::Loop()’:
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:85:30: error: request for member ‘ready’ in ‘((Fusor*)this)->Fusor::accel_extrapolator_’, which is of non-class type ‘int’
if (!accel_extrapolator_.ready()) return;
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:86:29: error: request for member ‘ready’ in ‘((Fusor*)this)->Fusor::gyro_extrapolator_’, which is of non-class type ‘int’
if (!gyro_extrapolator_.ready()) return;
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:87:35: error: request for member ‘last_time’ in ‘((Fusor*)this)->Fusor::accel_extrapolator_’, which is of non-class type ‘int’
if (now - accel_extrapolator_.last_time() > 1000000) return;
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:88:34: error: request for member ‘last_time’ in ‘((Fusor*)this)->Fusor::gyro_extrapolator_’, which is of non-class type ‘int’
if (now - gyro_extrapolator_.last_time() > 1000000) return;
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:94:34: error: request for member ‘get’ in ‘((Fusor*)this)->Fusor::accel_extrapolator_’, which is of non-class type ‘int’
accel_ = accel_extrapolator_.get(now);
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:96:32: error: request for member ‘get’ in ‘((Fusor*)this)->Fusor::gyro_extrapolator_’, which is of non-class type ‘int’
gyro_ = gyro_extrapolator_.get(now);
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:134:34: error: request for member ‘slope’ in ‘((Fusor*)this)->Fusor::accel_extrapolator_’, which is of non-class type ‘int’
wGyro += accel_extrapolator_.slope().len() * 1000;
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h: In member function ‘Vec3 Fusor::gyro_slope()’:
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:276:31: error: request for member ‘slope’ in ‘((Fusor*)this)->Fusor::gyro_extrapolator_’, which is of non-class type ‘int’
return gyro_extrapolator_.slope() * 1000000;
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h: In member function ‘void Fusor::dump()’:
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:296:25: error: request for member ‘dump’ in ‘((Fusor*)this)->Fusor::accel_extrapolator_’, which is of non-class type ‘int’
accel_extrapolator_.dump();
c:\users\tomti\appdata\local\temp\arduino_build_78389\sketch\common\fuse.h:298:24: error: request for member ‘dump’ in ‘((Fusor*)this)->Fusor::gyro_extrapolator_’, which is of non-class type ‘int’
gyro_extrapolator_.dump();
Error compiling for board Teensy 4.0.
