MacOS 10.14.6 Mojave. ProffieOS6beta, Proffieboard v3.7.
While I’ve seen weirdness in the past as far as files showing over USB, but not via card reader, I couldn’t put my finger on the process to recreate what was happening, and there was also strange filename corruption. However, no corruption today, just complete missing files.
For some reason, I see all files normally, then see none at all depending on how the SD is mounted. While it’s certainly possible that the issue is my computer OS, what’s odd is that this has ALSO happened to at least 2 other people using Mass Storage and they are using Windows.
So I thought i’d bring it up as it seems it might NOT be computer OS related.
- Mass Storage enabled, copied over a font. BlakStar for example.
Confirm copy is complete by listening to a wav or 2 from the font ON THE SD card.
Also list files in Terminal to see they’re there. (Yes I’m aware of the invisible resource files, not an issue ever before and I believe unrelated here)
BCmini-2:~ bconner$ cd /Volumes/PB37B/BlakStar
BCmini-2:BlakStar bconner$ ls -al
total 8384
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 11:14 .
drwxrwxrwx@ 1 bconner admin 32768 Nov 28 23:23 ..
-rwxrwxrwx@ 1 bconner admin 6148 Nov 23 18:04 .DS_Store
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._.DS_Store
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._bgndrag
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._bgnlock
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._blst
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._boot01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._clsh
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._drag01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._enddrag
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._endlock
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._font01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._hum01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._in01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._lock01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._menter.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._mexit.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._mselect.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._out01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._slsh01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._spin01.wav
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._stab
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._swingh
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._swingl
-rwxrwxrwx 1 bconner admin 4096 Nov 28 23:14 ._swng
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 03:36 bgndrag
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 03:52 bgnlock
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 00:46 blst
-rwxrwxrwx@ 1 bconner admin 138064 Oct 3 2019 boot01.wav
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 05:40 clsh
-rwxrwxrwx@ 1 bconner admin 733232 Oct 3 2019 drag01.wav
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 05:40 enddrag
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 05:43 endlock
-rwxrwxrwx@ 1 bconner admin 138064 Oct 3 2019 font01.wav
-rwxrwxrwx@ 1 bconner admin 651584 Jan 9 2020 hum01.wav
-rwxrwxrwx@ 1 bconner admin 65978 Jan 8 2020 in01.wav
-rwxrwxrwx@ 1 bconner admin 702284 Oct 3 2019 lock01.wav
-rwxrwxrwx@ 1 bconner admin 81632 Oct 3 2019 menter.wav
-rwxrwxrwx@ 1 bconner admin 74384 Oct 3 2019 mexit.wav
-rwxrwxrwx@ 1 bconner admin 54414 Oct 3 2019 mselect.wav
-rwxrwxrwx@ 1 bconner admin 139632 Oct 3 2019 out01.wav
-rwxrwxrwx@ 1 bconner admin 40024 Oct 3 2019 slsh01.wav
-rwxrwxrwx@ 1 bconner admin 53036 Oct 3 2019 spin01.wav
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 08:29 stab
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 10:56 swingh
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 10:55 swingl
drwxrwxrwx@ 1 bconner admin 32768 Aug 25 01:15 swng
Eject the drive from the computer, cycle presets to the new font…beep. Just beep.
‘effects’ in Serial monitor simply says “Done listing effects”.
Confirm no sounds by turning on blade, shows “No sounds found: hum” etc…
So far, the computer thinks it copied the files fine, but the board thinks it’s an empty directory.
- Remove SD from board, use card reader.
Take a listing in Terminal
total 128
drwxrwxrwx 1 bconner admin 32768 Dec 31 1969 .
Take a look in Finder file explorer. Zero items.
Now in the past @profezzorn, you have mentioned maybe the computer is caching or otherwise somehow “holding on” to what it thought it did as a file transfer, which I’m not sure what could be done about that…but the weird thing is how the computer actually PLAYS the files from the SD card directly. So some sort of strangeness with the “table of contents” header information on the volume of the drive? or…?
Is there some inherent thing that Mass Storage uses a very basic drive mount-unmount system that it’s not playing nicely?
Weirdest thing is that this does not happen all the time at all. Usually it’s fine, but here today I can recreate this over and over.
In the meanwhile, I’ll test on another board and SD with another ProffieOS etc…
