We’ve touched on this before, but I want to add a button press to force the Proffieboard to either:
- Reboot,
- Run Blade-ID
Using SA22C’s prop, I added the lines below to the BladeID section, but it didn’t work. The aim was to press and hold Main and Aux together for X seconds until the Proffie does one of the above.
I confess I know nothing about coding, and this was really just a guess. My question now is can this be fixed by just changing this bit - and if so what do I need to add - or will it require some work deeper in the OS?
As always thoughts welcome.
Then I promise to leave you in peace for a bit! LOL!
case EVENTID(BUTTON_AUX, EVENT_HELD_LONG, MODE_OFF | BUTTON_POWER, EVENT_HELD_LONG, MODE_OFF):
blade_detected_ = false;
FindBladeAgain();
SaberBase::DoBladeDetect(false);
return true;
