Firstly, chill. For some reason it didn’t pastebin well because I had a second look at what was copied and it cut off too much. I’ll just upload it directly here.
[Aniflex.h (598.9 KB)](https://www.dropbox.com/scl/fi/usymlch16vm30e4ib0nmv/Aniflex.h?rlkey=givu3ykaqfd2ntlt52liav4x2&st=l2m5bymc&dl=0)
Second, I always include fett’s info when transferring bc 1. it’s included in the copy-paste and 2. It helps me remember what that line of code is. Anything else, is something I either wrote myself and edited via the style-editor, or it’s just a duplicate to match blade count with the first add given the info.
Third, if you had read earlier, this config worked fine on 3.6 and is still working fine on the board being used. If I had 2 blades instead of 3, the complier would’ve caught that immediately.
Preset 5 has 3 blades even as posted. Look at it again.
