The way I see and understand OLED, there are two possibilities:
- in ProffieOS.ino
#ifdef ENABLE_SSD1306
#include "display/ssd1306.h"
#ifndef DISPLAY_POWER_PINS
#define DISPLAY_POWER_PINS PowerPINS<>
StandardDisplayController<128,uint32_t> display_controller;
SSD1306Template<128,uint32_t,DISPLAY_POWER_PINS> display(&display_controller);
or 2) in ProffieOS.ino
#ifdef INCLUDE_SSD1306
& also 2) in myconfig.h
#ifdef CONFIG_BOTTOM
DisplayHelper<128,uint32_t,
BaseLayerOp<StandardDisplayController>,
ClearRectangleOp<10,80,8,24>,
WriteBulletCountOp<10,20,5> >
SSD1306Template<128,uint32_t> display(&display_controller);
#endif // CONFIG_BOTTOM
And my question is:
about 2):
// ... some code here ...
but without in … some code here …
Is there something else (other than “bullet counts”) that already exit in your ProffieOS “official code” & also “initialize the display & can go in CONFIG_BOTTOM or somewhere else” that I can test with my code to see if everything that is working with your code, still works with my code ?
Not “me” but does “your code” has other possibilities.
No.
No. I just want to know if there something else that would use #define INCLUDE_SSD1306 in myconfig.h and some other bits of code “somewhere else” (in myconfig.h or other than myconfig.h) that I can test with my code to see if it still works as you intended despite my workarounds in my ProffieOS version of your code ?
