default_proffieboard_config.h (29.1 KB)
What is this?
#define PROPS_SABER_FETT263_BUTTONS_H
This doesn’t belong in your config, remove.
I would review the Set Up Requirements and defines
You’re missing required “common” folder and you have several defines that don’t do anything or are incomplete.
Where do I add the common folder? I’ve put it in my config before and I have it, but every time I use my saber it says “file directory not found” I think I have it in the wrong spot
You need to get the Voice Pack as described in the Set Up instructions and add as “common” in the root on your SD card. It’s all covered on the linked page.
When I add it to the root directory proffie os can’t find it.
Update, I got it to work! Thank you so much I know this was a long process
Glad to hear. Enjoy.
