Are you sure it’s copying the preset and not changing the font? Change Font is similar to Battery Level control. Try adding this define.
I’m not sure. I’ll try that, thanks. Also, how do I change cross-fade between ignition and hum sounds?
Nope. That define didn’t work. Well, I still managed to replace a preset with another one somehow by trying to adjust the volume. The buttons on this hilt are finicky. The last soundfont in the list keeps replacing the first soundfont in the list but the blade style stays on the original setting. So all the sounds are changing but not the blade. That may help you understand what I’m doing wrong. I’m using all these defines -
// ProffieOS6 Config File
#define NUM_BLADES 2
#define VOLUME 1000
#define CLASH_THRESHOLD_G 6.0
#define FETT263_TWIST_ON
#define FETT263_THRUST_ON
#define FETT263_STAB_ON
#define FETT263_STAB_ON_NO_BM
#define FETT263_FORCE_PUSH
Those defines are for OS7, it looks like you’re uploading OS6. Get OS7 and upload.
I tried using the defines disable change style and preset etc,and when I press aux and twist hilt it still says select preset thought I was disabling that.
Probably want to review the controls. Scroll Presets isn’t an editing function it just let’s you scroll through the presets you have by turning the hilt rather than doing multiple button presses.
Review the controls here:
So is there not anyway to turn that feature off then ?
You’d have to modify the prop.
But it may be easier to just not do that control.
How do I modify im not trying to do that control on purpose,I have 2 sabers in a carry bag and the buttons get mashed when carrying the bag.
See here: ProffieOS Documentation: Making your own prop file
Or maybe power off the sabers before putting them in the bag? That will probably be better for them overall anyway if I’m being honest. If the buttons getting pressed while you’re transporting them you’re probably going to still run into presets changing and batteries being drained unnecessarily, etc. I think you’re trying to solve the wrong problem in this scenario.
I’d try a mechanical solution. Turning them completely off as Fett263 suggested is a good move. Take out the battery, or use a kill switch/key.
If you need them powered up and ready, maybe make/find a cover for the buttons.
That’s a lot easier than modding a prop, unless the code is familiar ![]()
