Help with wiring
is this ok , is there a way to make it better ?
Add another data line for the pogo pin LEDs?
Well, it would help if you described what you want the saber to do. If your config reflects what you want you can post it.
I’m in bed now, will show the config tomorrow.
But I’m trying to do blade and pcb leds in pararel. I saw in my other saber it’s has 1 positive, 1 negative and 1 data.
I thought I was doing it right.
Is your hilt-side PCB a ShtokCustomWorx pcb like the one in the image? If so, here is a link to the manual: NPXL Connector User Manual V4.pdf - Google Drive
For blade and emitter in parallel, that’s option 2 (page 4). There should be two resistors on the PCB–that’s how they normally come, but your image doesn’t show the R1 resistor. if you don’t have an R1 resistor, you would need to add one, or run another data 1 wire to the center pad.
If you have a different maker’s hilt-side PCB, the wiring may be different.
Yes , its a ShtokCustomWorx . so I think I am going in the rigght direction ,. this is my config file , I flashed with no issues but still havent try till i wired can not know if its working .
thank you so much everyone for the tips . :slight_smile:
Update .
Did it and works perfectly ! thank you !
