So I’m having some trouble adding blade styles to my proffieboard. So far there are two main issues. The first one is that half of the time when I turn the blade on it either has glitched lighting or it just doesn’t light up at all but I still have sound when I swing it around.
The second issue is that when I flash my board the illuminated power button doesn’t light up anymore. I have tried to upload the original files from Sabertrio and then everything works perfectly. Does anyone have any idea what might cause these issues?
I have a proffieboard V2.2 and using Arduino 1.8.19
Down under is the newest config i tried, I have had the same issue with multiple configs. Fett263config.h (8 KB)
So I tried using the config helper and when I pasted in my original blade config from sabertrio it says that my blade config contains 0 blades in it, do you see something that sticks out?
