Doing fresh proffie install and config. Nuking the unnecessarily modified Sabertrio OS and starting from zero. Slight learning curve since factory ProffieOS and S3s OS are not 1 to 1 and they modded it a lot.
Some eyes on the config would be great. I’m almost there. Using Fett builder. Simple nothing crazy style for teensy soundfont. I just want ONE working for proof of concept, then I can play with preconfigs, etc.
2 blades:
-Sabertrio 32" neo-pixel
-Activation button led ring (single color red LED is on/awake when saber on, off in deep sleep. No change with blade activation) I believe this is the issue
I have tried using the S3 StylePtr white code without success, so I tried an on/off power save single pixel in the builder. Probably got it wrong.
Also have blade plug, but that’s probably irrelevant at this time
