Just picked up a new hilt running the V3 board and BT-909 Bluetooth so I can play with Force Sync.
The fist thing I noticed is how instinctual the setup is.
The second thing I noticed is that while selecting clash that it does not disengage like other effects will like with lockup or drag where you simply tap that again to end the effect. tapping clash a second time doesn’t end the effect. Only tapping drag will.
*Not sure if this is specific to iPhone’s and the latest Apple iOS or something inherent in the app.
- Hilt Details: Sabertrio Senza, but as usual I am running standard ProffieOS. In this case 8.x
Lemme know and thanks in advance!
Only Lockup and Drag effects can be stopped by a second tap because only these two effects are infinite, they play until you stop them. All other effects are short and stop by itself, so second tap only plays them again. So what you are experiencing is all correct in both iOS and Android app versions.
Also it’s worth to mention that ForceSync app on iOS is very old (5 years old) so it’s missing a lot of new improvements I have added recently to the Android version, I’m currently working on updating the iOS app to the same level as the Android app and even further.
Ahhh, I totally didn’t factor the effect duration bit in. So I guess tapping drag it-is then.
Thanks Man!
I’m down to definitely play with an updated version for the Apple phones. Lemme know what support you may want from me. I’m always happy to throw some time in to assist with testing to get an update out quickly.
MTFBWY!
Relating to the OS8 thread FWIW if using Force Sync it now pairs after non-use (but still Bluetooth listed on the phone) to an iPhone way faster and you get a few more feet of range to mess with people.
Can’t wait to try out the revised App.
