Force Push Not Working
Force gesture doenst work when using sa22c buttons, while outside of battle mode. Using ProffieOS7.7. Any help would be appreciated, thanks.
severance_config2023.h (9.1 KB)
That seems to be how it’s designed to work:
I suppose you could try changing that to true, but I’m not sure if that is a good idea or not.
Sa22c’s prop uses the OS5 versions of gestures and Battle Mode from my old prop, where Force Push was only enabledin Battle Mode. I merged his with mine for 1 button operation in OS6.
To use Force Push outside of Battle Mode use my prop with this define.
#define
FETT263_FORCE_PUSH_ALWAYS_ON
Just read through setup instructions here
Or you can use this tool to help set your defines and produce a custom Control/Button list.
