Font directory not found
So I got my first proffie lightsaber from Sabertrio and I was really excited to customize it.
I followed pretty much every tutorial I can find. The uploading and stuff goes perfectly fine.
But when I boot up my lightsaber and select the soundfont, I get a sound that says ‘Font directory not found’
I can still select it, the actual LED lighting somewhat works (it doesn’t seem to be 100% accurate, more like 90%) but there is absolutely no sound.
So I’m just curious what I did wrong as despite this, the pre-installed soundfonts that came with the blade installed by Sabertrio are working perfectly fine.
This is the code I added to the s3config_v3
   { "Mercenary;common", "common/tracks/venus.wav",
	StylePtr<Layers<
  //Base Fett263 Smoke Blade style
  StripesX<Sin<Int<12>,Int<3000>,Int<7000>>,Scale<SwingSpeed<100>,Int<75>,Int<125>>,StripesX<Sin<Int<10>,Int<1000>,Int<3000>>,Scale<SwingSpeed<100>,Int<75>,Int<100>>,Pulsing<RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<15,14,0>>,1200>,Mix<SwingSpeed<200>,RotateColorsX<Variation,Rgb<90,87,0>>,Black>>,RotateColorsX<Variation,Rgb<40,40,0>>,Pulsing<RotateColorsX<Variation,Rgb<36,33,0>>,StripesX<Sin<Int<10>,Int<2000>,Int<3000>>,Sin<Int<10>,Int<75>,Int<100>>,RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<60,58,0>>>,2000>,Pulsing<RotateColorsX<Variation,Rgb<90,88,0>>,RotateColorsX<Variation,Rgb<5,5,0>>,3000>>,
  //Underlying Fett263 Smoke Blade Fire layer
  AlphaL<StyleFire<RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<2,2,0>>,0,1,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<10,2000,2>,FireConfig<0,0,25>>,Int<10000>>,
  //Fett263 Ripple swing effect
  AlphaL<Stripes<2500,-3000,RotateColorsX<Variation,Yellow>,RotateColorsX<Variation,Rgb<44,42,0>>,Pulsing<RotateColorsX<Variation,Rgb<22,20,0>>,Black,800>>,SwingSpeed<375>>,
  //Fett263 Bright hard swing effect
  AlphaL<RotateColorsX<Variation,LemonChiffon>,Scale<IsLessThan<SwingSpeed<675>,Int<13600>>,Scale<SwingSpeed<750>,Int<-17300>,Int<32768>>,Int<0>>>,
  //Fett263 Responsive Intensity Lockup
  TrConcat<TrInstant,AlphaL<RgbArg<LOCKUP_COLOR_ARG,White>,Int<0>>,TrWaveX<RgbArg<LOCKUP_COLOR_ARG,White>,Int<300>,Int<100>,Int<400>,Scale<BladeAngle<>,Scale<BladeAngle<0,16000>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<-12000>>,Sum<IntArg<LOCKUP_POSITION_ARG,16000>,Int<10000>>>,Scale<SwingSpeed<100>,Int<14000>,Int<18000>>>>>,SaberBase::LOCKUP_NORMAL>,
  //Fett263 Sparking Emitter Flare
  AlphaL<RotateColorsX<Variation,LemonChiffon>,SmoothStep<Scale<SlowNoise<Int<2750>>,Int<1750>,Int<3750>>,Int<-4000>>>,
  //Responsive Stab
  ResponsiveStabL<AudioFlickerL<RgbArg<STAB_COLOR_ARG,DeepPink>>,TrWipeInX<Percentage<WavLen<EFFECT_STAB>,50>>,TrFadeX<Percentage<WavLen<EFFECT_STAB>,50>>>,
  //Fett263 Real Clash
  //Fett263 Unstable bright ignition effect
  TransitionEffectL<TrConcat<TrInstant,Stripes<3000,-3500,RotateColorsX<Variation,Rgb<100,100,150>>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<60,60,80>>,Black>,BrownNoiseFlicker<RotateColorsX<Variation,Rgb<110,115,140>>,RotateColorsX<Variation,Rgb<60,60,80>>,200>,RandomPerLEDFlicker<RotateColorsX<Variation,Rgb<128,128,128>>,RotateColorsX<Variation,Rgb<60,60,80>>>>,TrFadeX<Percentage<WavLen<>,65>>>,EFFECT_IGNITION>,
  //Fett263 Bright Humpflicker retraction effect
  TransitionEffectL<TrConcat<TrInstant,HumpFlickerL<White,40>,TrFadeX<Percentage<WavLen<>,125>>>,EFFECT_RETRACTION>,
  //Fett263 Intensity Drag
  //Fett263 Power Save, if using Fett263's prop file hold AUX and click PWR while ON (pointing up) to dim blade in 25% increments.
  //Fett263 White Spark Tip ignition and Color Cycle retraction
  InOutTrL<TrJoin<TrWipeX<Percentage<WavLen<EFFECT_IGNITION>,8>>,TrWaveX<White,Percentage<WavLen<EFFECT_IGNITION>,25>,Int<300>,Percentage<WavLen<EFFECT_IGNITION>,8>,Int<0>>>,TrColorCycle<950,7500>>,
  //Absorby charge-up preon
  TransitionEffectL<TrConcat<TrDelayX<Percentage<WavLen<>,33>>,TransitionLoopL<TrJoin<TrWipeIn<142>,TrSparkX<RotateColorsX<Variation,LemonChiffon>,Int<425>,Int<142>,Int<32768>>>>,TrDelayX<Percentage<WavLen<>,67>>>,EFFECT_PREON>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<Mix<Trigger<EFFECT_PREON,Percentage<WavLen<>,33>,Percentage<WavLen<>,67>,Int<0>>,BrownNoiseFlicker<Black,RotateColorsX<Variation,HotPink>,100>,RandomPerLEDFlicker<RotateColorsX<Variation,LightPink>,RotateColorsX<Variation,LemonChiffon>>,BrownNoiseFlicker<Mix<NoisySoundLevel,RotateColorsX<Variation,DeepPink>,RotateColorsX<Int<4000>,RotateColorsX<Variation,Yellow>>>,RotateColorsX<Variation,LemonChiffon>,50>>,SmoothStep<Scale<NoisySoundLevel,Int<-350>,Int<17500>>,Int<-4000>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>,
  TransitionEffectL<TrConcat<TrInstant,AlphaL<Black,SmoothStep<Sin<Int<10>,Int<16500>,Int<14500>>,Sin<Int<7>,Int<10500>,Int<9500>>>>,TrDelayX<WavLen<>>>,EFFECT_PREON>
Do you have a directory called Mercenary on your SD card?
Do you have a directory called common on your SD card?
Yea, the ‘common’ folder was already on the Sabetrio SD card.
This is all the folders on there
Looks like you’re missing the name of the preset that comes just before the bracket at the end of the style.
…(), “YourPresetNameHere”},
So the original code did indeed have the name at the end.
Only issue; I can’t upload it when the preset name is at the end of the style.
Arduino gives the following error with the preset name at the end of the style:
h:997:8: error: cannot convert ‘const char*’ to ‘StyleFactory*’ in initialization
997 | >>(),“Mercenary”},
| const char*
Compilation error: cannot convert ‘const char*’ to ‘StyleFactory*’ in initialization
Maybe it’s the quotation marks you used. I made that mistake a lot at first. They need to be simple text, not “fancy”. Switch in your text editor or copy paste from another preset.
Need to see the whole config to verify, but since it’s SaberTrio, you most likely have 2 blades defined and need a 2nd style in your preset.
That means it expects another style before the name… how many styles do you have per preset? What is your NUM BLADES set to?
Technically this isn’t required. IMO it’s good practice to put it there, but it’s not required and everything will compile just fine without it, assuming all else is correct.
Fun fact: If the compiler recognizes that the name is a const char* (as the error message indicates) then the correct quotes are being used (and they’ve just been formatted on the crucible). Incorrect quotes will typically trigger a “stray Unicode” error or something of the sort.
Here’s the full code https://pastebin.com/sy3ZG4pJ
Never mind guys! I just solved it.
Turns out that for some reason, the actual sound files weren’t transferred to the SD card.
The const char* error persists when uploading, but when I remove the preset name at the end, it seems to work just fine
If it works and you’re fine with it, that works, however this is odd, because you only have a single blade style for your last preset, but you should have two.
This tracks with getting an error w/ the name at the end, because it’s expecting another blade style before the name. It’s weird that it would work if you don’t provide enough blade styles.
@profezzorn could you comment on this? I wouldn’t expect it to compile if blades is set to 2 but only one style is provided…
C++ allows you to initialize only some members of a struct. Any omitted members will be initialized to zero or null. This is exactly why it’s good practice to put the string at the end of the preset, because it will cause a compilation error if you have the wrong number of styles in your preset.
Omitted styles will generate some run-time errors in the serial monitor, but will otherwise behave as if they were set to StylePtr<Black>().
I didn’t realize you had those members set to be null initialized… I see.
EDIT: This was bugging me so I played with it. I could’ve sworn that if members were const it was a compile-time error to not initialize them, but I guess not… not even a warning for a ptr not being initialized. Huh, interesting.
